pfc886
823|0
 楼主| 34af9uc 发表于 2021-9-29 21:22 | 显示全部楼层 |阅读模式
PFC, LED, go, se, rc, TI
#include        "extern.h"
led1                bit                pb.6;
led2                bit                pb.7;
key1                bit                pb.1;
key2                bit                pb.2;
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
//        Insert Initial Code
pmode        Program_Mode;                        //        if has more FPPAs than 2
fppen        =        0xFF;
$                led1                out;                //输出
$                led2                out;
$                key1                in,pull;                //输入,上拉电阻
$                key2                in,pull;
while (1)
if(led2){led2 =0;}
else{led2 =1;}
.delay 500000;
void        FPPA1 (void)
while(1)
        if(key1==0){led1 =0;}
        if(key2==0){led1 =1;}
void        FPPA2 (void)
        goto        $;
void        FPPA3 (void)
        goto        $;
void        FPPA4 (void)
        goto        $;
void        FPPA5 (void)
        goto        $;
void        FPPA6 (void)
        goto        $;
void        FPPA7 (void)
        goto        $;
void        Interrupt (void)
        pushaf;
        if (Intrq.T16)
        {        //        T16 Trig
                //        User can add code
                Intrq.T16        =        0;
        popaf;
319
