GD32外接16Mhz晶振,计算后倍频是小数,如何解决?
4682|1
 楼主| HCFll 发表于 2021-10-5 17:29 | 显示全部楼层 |阅读模式
#if (defined(GD32F10X_MD) || defined(GD32F10X_HD) || defined(GD32F10X_XD))
    /* select HXTAL/2 as clock source */
    RCU_CFG0 &= ~(RCU_CFG0_PLLSEL | RCU_CFG0_PREDV0);
    RCU_CFG0 |= (RCU_PLLSRC_HXTAL | RCU_CFG0_PREDV0);
    /* CK_PLL = (CK_HXTAL/2) * 27 = 108 MHz */
    RCU_CFG0 &= ~(RCU_CFG0_PLLMF | RCU_CFG0_PLLMF_4);
    //RCU_CFG0 |= RCU_PLL_MUL27;
//这里CK_HXTAL为16MHz,所以计算倍频得13.5,那么应该选RCU_PLL_MUL13还是RCU_PLL_MUL14呢?
                RCU_CFG0 |= RCU_PLL_MUL13;//??RCU_PLL_MUL14??
呐咯密密 发表于 2021-10-8 11:55 | 显示全部楼层
之前是8M,2分频再倍频27,得到108。换了16M,你就4分频然后在27倍频,这不就OK了吗搜索
复制
