可以直接当评估板用,可以插到面包板或者洞洞板上当核心板搭建项目原型。
MicroUSB接口供电,引出5V和3.3V电源,24M有源晶振输入,引出26个IO。
资料已经发布在github:https://github.com/xjtuecho/AgmPill
- dimension: 41x23mm.
- 2x16 2.54mm PIN header, 26 user IO.
- 2x5 PIN standard Altera USB-Blaster port.
- 24MHz dedicated clock input on PIN_13.
- 1280 LUTs.
- 10 Kbits Distributed RAM.
- 68 Kbits EBR SRAM.
- 1xPLL
- EDA Tool:Quartus and Supra.
