F149模拟I2C总线驱动BH1750的问题
4091|3
 楼主| acer4736 发表于 2012-3-17 22:47 | 显示全部楼层 |阅读模式
BH1750FVI是光强度传感器,支持IIC接口。小弟最近欲做一个简单的光强度检测程序,将光强度用数码管显示出来,不过调试了好久一直无法工作。请各位大虾帮忙看下IIC的模拟哪里有错,不胜感激!
 楼主| acer4736 发表于 2012-3-17 22:48 | 显示全部楼层
#include<msp430x14x.h>
#define uchar unsigned char
#define uint unsigned int
#define SDA_1  P3OUT|=BIT1 // P3.1为SDA
#define SDA_0  P3OUT&=~BIT1
#define SCL_1 P3OUT |= BIT0 //P3.0为SCL
#define SCL_0 P3OUT &= ~BIT0
#define DIR_IN P3DIR &= ~BIT1
#define DIR_OUT P3DIR |= BIT1
#define SDA_IN ((P3IN >> 1) & 0x01)
#define dis_data  P5OUT  //数码管输出
#define TIME 5
#define SlaveAddress   0xA6
uchar seg_bcd[] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; //数码管
void delay_nms(unsigned int k)//延时k毫秒
  unsigned int i,j;
  for(i=0;i<k;i++)
      for(j=0;j<121;j++)
void Delay(unsigned int n)    //延时
   unsigned int i;
   for(i = 0;i < n;i++)
void BH1750_Start()         //起始信号
    DIR_OUT;
    SDA_1;
    delay_nms(5);
    SCL_1;
    Delay(TIME);
    SDA_0;
    Delay(TIME);
    SCL_0;
void BH1750_Stop()        //结束信号
    DIR_OUT;
    SDA_0;
    Delay(TIME);
    SCL_1;
    Delay(TIME);
    SDA_1;                    }
void BH1750_SendACK()       //发送Ack
    SCL_0;
    DIR_OUT;
    SDA_0;
    Delay(TIME);
    SCL_1;
    Delay(TIME);
    SCL_0;
void BH1750_RecvACK()         //接受ACK
{   SCL_1;
    Delay(TIME);
    DIR_IN;
    while(SDA_IN);
    DIR_OUT;
    SCL_0;
    Delay(TIME);
void BH1750_SendByte(uchar dat)     //发送一个字节
{   DIR_OUT;
    unsigned int i;
    for(i = 0;i < 8;i++)
    SCL_0;
    Delay(TIME);
    if((dat >> 7) & 0x01) SDA_1;
    else SDA_0;
    Delay(TIME);
    SCL_1;
    Delay(TIME);
    dat <<= 1; //数据左移一位,进入下一轮送数
    Delay(TIME);
uchar BH1750_RecvByte()         //接受一个字节
    uchar i;
    uchar dat = 0;
    uchar datbit=0;
    SCL_0;
    Delay(TIME);
    SDA_1;
    DIR_IN;
    for (i=0; i<8; i++)
        SCL_1;
        Delay(TIME);
        datbit = SDA_IN;
        Delay(TIME);
        dat = ((dat << 1) | datbit);
        SCL_0;
        Delay(TIME);
    return dat;
void Single_Write_BH1750(uchar REG_Address)  //写入
    BH1750_Start();
    BH1750_SendByte(SlaveAddress);
    BH1750_SendByte(REG_Address);
   // BH1750_SendByte(REG_data);
    BH1750_Stop();
void main()
{ uchar tmp;
  float temp;
  int t;
  WDTCTL = WDTPW + WDTHOLD;
  P5DIR |= 0Xff;
  P4DIR |= 0x01;
  P5OUT |= 0x00;
  delay_nms(200);
  Single_Write_BH1750(0x01);
  Single_Write_BH1750(0x10);
  while(1)
   { Single_Write_BH1750(0x01);
     delay_nms(180);
     tmp=BH1750_RecvByte();
     temp=(float)tmp;
     t=temp/100;
     dis_data=seg_bcd[t];
jinpaidianzi 发表于 2012-3-17 22:57 | 显示全部楼层
BH1750FVI这个东西真的不了解。看看有没有了解的人。
个人一点看法:不要简单的贴代码。很少有人会有耐心看既不知道原理图又不知道具体应用的代码,对大家来说是个挑战。
teabottle 发表于 2012-3-17 23:11 | 显示全部楼层
我建议您可以这样,描述一下您再做I2C测试时遇到的现象。
1 硬件连接有没有问题?检查下BH1750FVI外围电路正常否。
2 比如做了哪些实验?有什么现象?
3 IIC通信的地址波特率设置正确否?
3 用示波器抓图看看波形。
唠叨了很多,希望对您有所帮助。
