- #include "stm32f10x_lib.h"
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- vu16 CCR1_Val = 32768;
- vu16 CCR2_Val = 16384;
- vu16 CCR3_Val = 8192;
- vu16 CCR4_Val = 4096;
- ErrorStatus HSEStartUpStatus;
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void NVIC_Configuration(void);
- int main(void)
- #ifdef DEBUG
- debug();
- #endif
- RCC_Configuration();
- NVIC_Configuration();
- GPIO_Configuration();
- TIM_TimeBaseStructure.TIM_Period = 65535; //这里必须是65535
- TIM_TimeBaseStructure.TIM_Prescaler = 2;
- TIM_TimeBaseStructure.TIM_ClockDivision = 0;
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
- TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle; //管脚输出模式:翻转(TIM输出比较触发模式)
- TIM_OCInitStructure.TIM_Channel = TIM_Channel_1;
- TIM_OCInitStructure.TIM_Pulse = CCR1_Val; //翻转周期
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//TIM输出比较极性低
- TIM_OCInit(TIM2, &TIM_OCInitStructure);
- TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable);//失能TIMx在CCR1上的预装载寄存器
- TIM_OCInitStructure.TIM_Channel = TIM_Channel_2;
- TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
- TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Disable);
- TIM_OCInitStructure.TIM_Channel = TIM_Channel_3;
- TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
- TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Disable);
- TIM_OCInitStructure.TIM_Channel = TIM_Channel_4;
- TIM_OCInitStructure.TIM_Pulse = CCR4_Val;
- TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Disable);
- TIM_Cmd(TIM2, ENABLE);
- TIM_ITConfig(TIM2, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 | TIM_IT_CC4, ENABLE);
- while (1)
- RCC_DeInit();
- RCC_HSEConfig(RCC_HSE_ON);
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- FLASH_SetLatency(FLASH_Latency_2);
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- RCC_PCLK2Config(RCC_HCLK_Div1);
- RCC_PCLK1Config(RCC_HCLK_Div4);
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
- RCC_PLLCmd(ENABLE);
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- while(RCC_GetSYSCLKSource() != 0x08)
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- NVIC_InitTypeDef NVIC_InitStructure;
- #ifdef VECT_TAB_RAM
- NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
- #else
- NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
- #endif
- NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- #ifdef DEBUG
- void assert_failed(u8* file, u32 line)
- while (1)
- #endif
