HC32L190 定时器中断不进入
2966|3
 楼主| l459829634 发表于 2021-10-30 14:23 | 显示全部楼层 |阅读模式
使用华大单片机碰到一些问题,不知道有人能帮我解决吗?
void time0_Init(void)
        uint16_t                  u16ArrValue;
        uint16_t                  u16CntValue;
        stc_bt_mode0_cfg_t     stcBtBaseCfg;
        DDL_ZERO_STRUCT(stcBtBaseCfg);
        Sysctrl_SetPeripheralGate(SysctrlPeripheralBaseTim, TRUE);
        stcBtBaseCfg.enWorkMode = BtWorkMode0;
        stcBtBaseCfg.enCT       = BtTimer;
  stcBtBaseCfg.enPRS      = BtPCLKDiv16;
  stcBtBaseCfg.enCntMode  = Bt16bitArrMode;
        stcBtBaseCfg.bEnTog     = FALSE;
  stcBtBaseCfg.bEnGate    = FALSE;
        stcBtBaseCfg.enGateP    = BtGatePositive;
        Bt_Mode0_Init(TIM0, &stcBtBaseCfg);
        u16ArrValue = 0x10000 - 1600;
        Bt_M0_ARRSet(TIM0, u16ArrValue);
        u16CntValue = 0x10000 - 1600;
        Bt_M0_Cnt16Set(TIM0, u16CntValue);
        Bt_ClearIntFlag(TIM0,BtUevIrq);
        Bt_Mode0_EnableIrq(TIM0);
        EnableNvic(TIM0_IRQn, IrqLevel3, TRUE);
我开启定时中断,为什么不进入中断,而且我发现整个中断函数都不运行,不知道怎么回事,有人知道吗?
还有就是我使用模拟IIC,来读取DS1307,读到的数据全是0
void DS1302_Init(void)
        stc_gpio_cfg_t stcGpioCfg;
        Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
        stcGpioCfg.enDir = GpioDirOut;
        stcGpioCfg.enDrv = GpioDrvH;
        stcGpioCfg.enPu = GpioPuEnable;
  stcGpioCfg.enPd = GpioPdDisable;
        stcGpioCfg.enOD = GpioOdDisable;
        stcGpioCfg.enCtrlMode = GpioAHB;
        stcGpioCfg.bOutputVal = TRUE;
        Gpio_Init(GpioPortB, GpioPin3, &stcGpioCfg);
        Gpio_Init(GpioPortB, GpioPin4, &stcGpioCfg);
        if(Read_DS1302(0x08) != 0xF0)
          Write_DS1302(write_address[0], 0x30);  //Ãë
          Write_DS1302(write_address[1], 0x09);  //·Ö
          Write_DS1302(write_address[2], 0x15);  //ʱ
          Write_DS1302(write_address[3], 0x29);  //ÈÕ
          Write_DS1302(write_address[4], 0x09);  //ÔÂ
          Write_DS1302(write_address[5], 0x03);  //ÖÜ
          Write_DS1302(write_address[6], 0x21);  //Äê
          Write_DS1302(0x08, 0xF0);
这是什么原因
橘子阿小 发表于 2021-10-30 16:44 | 显示全部楼层
总中断是否打开?
 楼主| l459829634 发表于 2021-11-1 08:53 | 显示全部楼层
中断打开了,问题出在库函数定义的弱函数问题,问题解决了,谢谢
 楼主| l459829634 发表于 2021-11-1 08:55 | 显示全部楼层
现在就剩下模拟IIC为什么不能读取
