[PIC®/AVR®/dsPIC®产品] 调用读写程序没有实现功能
2351|14
 楼主| chuxh 发表于 2021-11-5 21:38 | 显示全部楼层 |阅读模式
使用PIC12F1571作为项目的主控MCU,现需要**功能保存按键档位状态。
我使用了MCC已生成memory的文件,但实际调用读写程序没有实现功能
supernan 发表于 2021-11-5 21:41 | 显示全部楼层
使用上有问题
zhenykun 发表于 2021-11-5 21:43 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
 楼主| chuxh 发表于 2021-11-5 21:45 | 显示全部楼层
#define Addr 0X0010                 //memory地址
#define savevalue  0X00AA           //memory测试数据
unsigned int keysaveaddr;                   //存储地址定义
unsigned int Buf[ERASE_FLASH_BLOCKSIZE];    //定义指向擦除flash块大小的指针
unsigned int Writedata;                     //写入数据
unsigned int readword;                      //读取数据
void Lowlight()
    Highflag = 0;
    Lowflag = 1;
    if(keyvalue == 1)                   //低亮档a
    {                                   //输出1:5% 其他:0
        light_timer = 0;                //5%使用PWM产生,20ms
        PWM_EN = 1;
        PWMduty = Lowlight1;
        output2_SetLow();
        output3_SetLow();
        output4_SetLow();
        //memory        数据存储
        Writedata = savevalue;
        keysaveaddr = Addr;
        FLASH_EraseBlock(keysaveaddr);                               //memory 擦除
        delay(10);
        FLASH_WriteWord(keysaveaddr, Buf, Writedata);         //memory   写数据
        delay(10);
    else if(keyvalue == 2)                   //低亮档b
    {                                   //输出2:100% 其他:0
        output2_SetHigh();
        PWM_EN = 0;
        light_timer = 0;
        output1_SetLow();
        output3_SetLow();
        output4_SetLow();
    else if(keyvalue == 3)                   //低亮档c
    {                                   //输出3:100% 其他:0
        output3_SetHigh();
        output1_SetLow();
        output2_SetLow();
        output4_SetLow();
    else if(keyvalue == 4)                   //低亮档d
    {                                   //输出4:100% 其他:0
        output4_SetHigh();
        output1_SetLow();
        output2_SetLow();
        output3_SetLow();
    if(keyvalue == 5)                   //低亮档e
    {                                   //输出1:爆闪8Hz(占空80%) 其他0
        light_timer = 0;                //100ms输出high,25ms输出low
        //Pwm_timer = 0;                //
        //T0125ms = 0;
        //PWM_EN = 1;
        //PWMduty = Lowlight5;
        // PWM8Hz = 1;
        P8Hz_EN = 1;
        output2_SetLow();
        output3_SetLow();
        output4_SetLow();
void main(void)
    // initialize the device
    SYSTEM_Initialize();
    keyvalue = 1;
    keysaveaddr == Addr;
    readword = FLASH_ReadWord(keysaveaddr);        //memory  读
    if(readword == savevalue)
        output2_SetHigh();
        output1_SetLow();
        output3_SetLow();
        output4_SetLow();
    else
        Highlight();
dengdc 发表于 2021-11-5 21:46 | 显示全部楼层
HEF是程序区的最后128个地址的低字节。你设定#define Addr 0X0010, 这是自杀式的代码啊,把自己写的程序都擦了
dingy 发表于 2021-11-5 21:49 | 显示全部楼层
针对1571来说,地址应该是0380h-03FFh
huangchui 发表于 2021-11-5 21:51 | 显示全部楼层
应该用Flash编程吧?
songqian17 发表于 2021-11-5 21:54 | 显示全部楼层
heweibig 发表于 2021-11-5 21:57 | 显示全部楼层
操作flash要特别小心
huangchui 发表于 2021-11-5 22:03 | 显示全部楼层
要清楚编译器生成的代码占用的空间是什么范围;
wyjie 发表于 2021-11-5 22:06 | 显示全部楼层
要清楚, 你自己要放的数据是什么范围;
dingy 发表于 2021-11-5 22:08 | 显示全部楼层
上面这2个范围一定不能重合;
dingy 发表于 2021-11-5 22:11 | 显示全部楼层
你需要看一下编译器手册(http://www.microchip.com.cn/newc ... 3/5e65e2ef6e8ab.pdf), 4.8.50 --ROM:调整ROM 范围, 这个章节来熟悉一下怎么实现。。
 楼主| chuxh 发表于 2021-11-5 22:13 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家
pzsh 发表于 2021-11-8 16:57 | 显示全部楼层
对照一下数据手册的memory部分看看
