DSP TMS320F28016 事件管理模块定时器问题
3440|5
 楼主| acer4736 发表于 2012-3-19 20:05 | 显示全部楼层 |阅读模式
我用的是f28016,只开了eva的定时器,但发生中断的时候TBPRD TBCTR不相等,TBCTR总比TBPRD小,请问这是哪里有问题,程序如下:
void init_eva_time1(void)
// Setup TBCLK
// TBCLK=SYSCLKOUT/(HSPCLKDIV*CLKDIV)=60M/(2*2)=15M
// PWM FREQUENCY=15M/(EPWM1_TIMER_TBPRD*2)=15M/(750*2)=10K
EPwm1Regs.TBCTL.bit.CTRMODE = 2; // up down
EPwm1Regs.TBPRD = 750; / t period
EPwm1Regs.TBCTL.bit.PHSEN = 0; // Disable phase loading Clearing the TBCTL[PHSEN] bit configures the ePWM to ignore the synchronization input pulse
EPwm1Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm1Regs.TBCTR = 0x0000; // Clear counter
EPwm1Regs.TBCTL.bit.HSPCLKDIV =1; // /2
EPwm1Regs.TBCTL.bit.CLKDIV = 1; // /2
// Setup shadow register load on PERIOD
// EPwm1Regs.CMPCTL.bit.SHDWAMODE = 0; //Shadow mode
// EPwm1Regs.CMPCTL.bit.LOADAMODE = 1; //Load on CTR = PRD
// Set Compare values
// EPwm1Regs.CMPA.half.CMP_A = 300; // Set Compare A value
// EPwm1Regs.CMPB = 300; // Set Compare B value
// EPwm1Regs.AQCTLA.bit.CAU=1;//force low,when incrementing
// EPwm1Regs.AQCTLA.bit.CAD=2;//force high,when decrementing
// EPwm1Regs.AQCTLB.bit.CBU=1;//force low,when incrementing
// EPwm1Regs.AQCTLB.bit.CBD=2;//force high,when decrementing
// set deadband
EPwm1Regs.DBCTL.bit.OUT_MODE = 3; //deadband enabled for both rising-edge and falling-edge
EPwm1Regs.DBCTL.bit.POLSEL = 0; //AH mode
EPwm1Regs.DBCTL.bit.IN_MODE = 3; //EPWMB is the source
EPwm1Regs.DBRED = 35; //rising-edge delay
EPwm1Regs.DBFED = 35; //falling-edge delay
EPwm1Regs.ETSEL.bit.INTSEL = 2; // period interrupt TBCTR = TBPRD
EPwm1Regs.ETSEL.bit.INTEN = 1; // enable interrupt
EPwm1Regs.ETPS.bit.INTPRD = 1; // Generate INT on first event
interrupt void eva_time1_isr(void)
// Clear INT flag for this timer
EPwm1Regs.ETCLR.bit.INT = 1;
// Acknowledge this interrupt to receive more interrupts from group 3
PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;
谁知道哪里有问题啊
jinpaidianzi 发表于 2012-3-19 20:13 | 显示全部楼层
TBCTR不会比TBPRD大,他们是包含关系.
teabottle 发表于 2012-3-19 20:24 | 显示全部楼层
进入中断的条件不应该是两个相等么,怎么不相等的时候就进入中断了?
wangjinlili 发表于 2012-3-19 20:47 | 显示全部楼层
楼主是怎么看的?楼主在中断子程序中添加一句:
kkk=EPwm1Regs.TBCTR;
保存一下进入到中断子程序时候的 EPwm1Regs.TBCTR;
的值。
楼主设置的是:CTRMODE = 2; 上升下降模式,从发生中断到进入中断子程序需要一些时间,我估计kkk的值和周期只相差并不大20来个时钟周期吧。
meishizhaoshi 发表于 2012-3-19 20:53 | 显示全部楼层
我是同时把这两个值加入watch,在中断中设断点看的,并没有像楼主那样间接的赋值,我等会儿用楼主的方法再看看,而且改变TBPRD,TBCTR总比TBPRD小4,为什么从发生中断到进入中断子程序需要时间,即使有,这个应该微乎其微到可以忽略吧,我只是粗浅的这么觉得.这个有没有文档说明啊,小弟刚入手dsp,求指教.
