[产品供应]
AT24C512BN-SH25-T
1840|0
yxfhxe|  楼主 | 2012-3-20 12:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Two-wire Serial, Electrically Erasable and Programmable Read-only Memory  512K (65,536 x 8)
Atmel AT24C512C  with Three Device Address Inputs
Features
? Low-voltage and standard-voltage operation
– M for VCC from 1.7V to 3.6V
– D for VCC from 2.5V to 5.5V
? Internally organized 65,536 x 8
? Two-wire serial interface
? Schmitt triggers, filtered inputs for noise suppression
? Bidirectional data transfer protocol
? 1MHz (2.5V, 5.5V), 400kHz (1.7V) compatibility
? Write protect pin for hardware and software data protection
? 128-byte page write mode (partial page writes allowed)
? Self-timed write cycle (5ms max)
? High reliability
– Endurance: 1,000,000 write cycles
– Data retention: 40 years
? Lead-free/halogen-free devices
? 8-lead JEDEC SOIC, 8-lead EIAJ SOIC, 8-lead TSSOP, 8-lead UDFN, and
8-ball VFBGA packages
? Die sales: wafer form, waffle pack and bumped die
Description
The Atmel
? AT24C512C provides 524,288 bits of serial, electrically erasable and
program-
mable read-only memory (EEPROM) organized as 65,536 words of eight bits
each. The
device’s cascadable feature allows up to eight devices to share a common
two-wire bus.
The device is optimized for use in many industrial and commercial
applications where low-
power and low-voltage operation are essential. The devices are available in
space-saving 8-
lead JEDEC SOIC, 8-lead EIAJ SOIC, 8-lead TSSOP, 8-lead UDFN, and 8-ball
VFBGA pack-
ages. The M voltage range devices operate from 1.7V to 3.6V.  The D voltage
range devices
operate from 2.5V to 5.5V.
AT24C512BN-SH25-T  AT24C512C-SSHD-T  we have in stock!!!
YXF INTERNATIONAL (HK) CO., LIMITED
Contact Person:   Nina Huang
Mobile phone:     086-15013553132
QQ:              1354906433
MSN/E-mail :  zoe_hxe@hotmail.com
www.yxfic.com     www.yxfic.net   www.yuanxinfeng.com
Top Hot Optocoupler:
LTV-247          LITEON代用Toahiba   TLP281-4GB
LTV-846          LITEON代用Toahiba   TLP521-4GB
LTV-816          LITEON代用Toahiba   TLP521-1GB
LTV356T-B        LITEON代用Toahiba   TLP181GB
Top Hot components:
LTV817STA-V          6N137S               A6801SLW
ACS710KLATR-12CB-T   ACS758KCB-150B-PFF   ACS758LCB-100B-PFF
ACS758LCB-050B-PFF   ACS758ECB-200B-PFF   ACS710KLATR-25CB-T
ACS712ELCTR-20A-T    ACS712ELCTR-05B-T    ACS712ELCTR-30A-T
LTV-816S-C-TA        LTV-816S-B-TA        LTV-816S-A-TA
LTV356T-C            A3955SB              A3987SLP-T
TB62209FG            A3212EUA             OV529-B49
A3212ELHLT           A1104EUA             6N137S
US1881KUA            A3977SED             TOP246YN
A3901SEJTR-T         MC33039DR            TLE4921-5U
TLE4935L             TLE4913              TB6560AHQ
AT24C512  AT24C512B   AT24C512BN      AT24C512BN-SH25   AT24C512BN-SH25-T
AT24C512  AT24C512C   AT24C512C-SSHD  AT24C512C-SSHD-T
个人签名:LTV247 6N137S LTV356T-B LTV-846 LTV817STA-V-B LTV-816X-B ACS712ELCTR-20A ACS712ELCTR-05A ACS712ELCTR-30A A3901SEJTR-T A3977SED
33
