[产品供应]
ST72F321AR6TAE
1624|0
yxfhxe|  楼主 | 2012-3-20 12:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ST, TI, TE, AN, ic
IC型号:ST72F321AR6T6
IC描述:64/44-PIN与8-BIT 32单片机60K FLASH/ROM,的ADC,5个定时器,SPI和SCI收录,I2C界面
IC厂商:STMicroelectronics
ST72321AR6   8-BIT MCU WITH NESTED INTERRUPTS, FLASH,10-BIT ADC, FIVE TIMERS, SPI, SCI, I2C INTERFACE
Description
The ST72F321 and ST72321 devices are members of the ST7 microcontroller family designed for mid-range applications.
All devices are based on a common industry-standard 8-bit core, featuring an enhanced instruction set and are available with FLASH or ROM
program memory.
Under software control, all devices can be placed in WAIT, SLOW, ACTIVE-HALT or HALT mode, reducing power consumption when the application is in
idle or stand-by state.
The enhanced instruction set and addressing modes of the ST7 offer both power and flexibility to software developers, enabling the design of
highly efficient and compact application code. In addition to standard 8-bit data management, all ST7 microcontrollers feature
Key Features
Memories
32K to 60K dual voltage High Density Flash (HDFlash) or ROM with read-out protection capability. In-Application Programming and In-Circuit
Programming for HDFlash devices
1K to 2K RAM
HDFlash endurance: 100 cycles, data retention: 20 years at 55 oC
Clock, Reset And Supply Management
Enhanced low voltage supervisor (LVD) for main supply and auxiliary voltage detector (AVD) with interrupt capability
Clock sources: crystal/ceramic resonator oscillators, internal RC oscillator, clock security system and bypass for external clock
PLL for 2x frequency multiplication
Four Power Saving Modes: Halt, Active-Halt,Wait and Slow
Interrupt Management
Nested interrupt controller
14 interrupt vectors plus TRAP and RESET
Top Level Interrupt (TLI) pin on 64-pin devices
15 external interrupt lines (on 4 vectors)
Up to 48 I/O Ports
48/32 multifunctional bidirectional I/O lines
34/22 alternate function lines
16/12 high sink outputs
5 Timers
Main Clock Controller with: Real time base, Beep and Clock-out capabilities
Configurable watchdog timer
Two 16-bit timers with: 2 input captures, 2 output compares, external clock input on one timer, PWM and pulse generator modes
8-bit PWM Auto-reload timer with: 2 input captures, 4 PWM outputs, output compare and time base interrupt, external clock with event detector
3 Communications Interfaces
SPI synchronous serial interface
SCI asynchronous serial interface
I2C multimaster interface
1 Analog peripheral
10-bit ADC with up to 16 input ports
Instruction Set
8-bit Data Manipulation
63 Basic Instructions
17 main Addressing Modes
8 x 8 Unsigned Multiply Instruction
Development Tools
Full hardware/software development package
In-Circuit Testing capability
Circuit Diagram
品牌销售专员:黄**
销售直线:    15013553132
QQ:          1354906433
MSN/E-mail :  zoe_hxe@hotmail.com
www.yxfic.com    www.yxfic.net  www.yuanxinfeng.com
只卖全新原装进口货,诚信第一,专为工厂配单!欢迎您随时来电洽谈
热销光耦:
LTV-247          LITEON代用Toahiba   TLP281-4GB
LTV-846          LITEON代用Toahiba   TLP521-4GB
LTV-816          LITEON代用Toahiba   TLP521-1GB
LTV356T-B        LITEON代用Toahiba   TLP181GB
热销元件:
LTV817STA-V          6N137S               A6801SLW
ACS710KLATR-12CB-T   ACS758KCB-150B-PFF   ACS758LCB-100B-PFF
ACS758LCB-050B-PFF   ACS758ECB-200B-PFF   ACS710KLATR-25CB-T
ACS712ELCTR-20A-T    ACS712ELCTR-05B-T    ACS712ELCTR-30A-T
LTV-816S-C-TA        LTV-816S-B-TA        LTV-816S-A-TA
LTV356T-C            A3955SB              A3987SLP-T
TB62209FG            A3212EUA             OV529-B49
A3212ELHLT           A1104EUA             6N137S
US1881KUA            A3977SED             TOP246YN
A3901SEJTR-T         MC33039DR            TLE4921-5U
TLE4935L             TLE4913              TB6560AHQ
ST72F321AR6 ST72F321AR6T6 ST72F321AR6TAE ST72321AR6
个人签名:LTV247 6N137S LTV356T-B LTV-846 LTV817STA-V-B LTV-816X-B ACS712ELCTR-20A ACS712ELCTR-05A ACS712ELCTR-30A A3901SEJTR-T A3977SED
33
