扎原因扎结果
1831|0
 楼主| 416112364 发表于 2021-11-30 08:49 | 显示全部楼层 |阅读模式
//代码如下
#include <pic.h>
#include <math.h>
//#include <myfuncs1.h>
//#include <seg74.h>
#include <htc.h>
#define SEG_BITSEL_PORT PORTD                   //位选端口
#define SEG_BITSEL_PORT_DIR TRISD               //位选端口的方向寄存器
#define SEG_FONT_PORT PORTC                     //字形输出端口
#define SEG_FONT_PORT_DIR TRISC                 //字形输出端口的方向寄存器
#define DLY_MS 67
const char Seg7TableN[]={0b11000000,0b11111001,0b10100100,0b10110000,0b10011001,0b10010010,0b10000010,0b11111000,0b10000000,0b10010000};
//__CONFIG(FOSC_HS & WDTE_ON & PWRTE_OFF & BOREN_ON & LVP_ON & CPD_OFF & WRT_OFF & CP_OFF);
//__CONFIG (XT & WDTDIS & LVPDIS);
unsigned int g_ADRTable[12] = {0,0,0,0,0,0,0,0,0,0,0 };
unsigned char g_Count=0;
bit OverFlag = 0;//12位转换次数完成标志位清零;
void delayms (int ms);
void DisplayData (unsigned int iData);
interrupt ISR (void)
    if ( ADIE && ADIF  )
       ADIF = 0;
       g_ADRTable[g_Count]=(((unsigned int)ADRESH)<<8)+ADRESL;
       g_Count++;
       if(g_Count==12)
           g_Count =0;
           OverFlag=1;//
       else
           GO_DONE = 1;//启动AD
    else
           while(1);
void main(void)
    //void  DisplayData();
    char i=0,j=0;
    int tmp = 0;//
    int adc_v = 0;
    TRISA0 = 1;
    SEG_BITSEL_PORT_DIR = 0;//位选端口的方向寄存器,确定输出端口
    SEG_FONT_PORT_DIR = 0;//字形输出端口的方向寄存器,确定输出端口
    ADFM = 1;
    PCFG3:PCFG0 = 0000;
    ADCON0 = 0B11000001;
    ADIE = 1;
    ADIF = 0;
    PEIE = 1;
    GIE = 1;
    for(i=0;i<15;i++)
    GO_DONE = 1;
    while(GO_DONE)
        if(OverFlag==1)
            for(i=0;i<12;i++)//冒泡法排序
                for(j=i+1;j<12;j++)
                    if(g_ADRTable > g_ADRTable[j])
                        tmp = g_ADRTable;
                        g_ADRTable = g_ADRTable[j];
                        g_ADRTable[j] = tmp;
        tmp = 0;
        for(i=2;i<10;i++)
            tmp = tmp + g_ADRTable;
        tmp = tmp >>3;//将数按照 2进制像右移动.每向右移动一位,相当于 除2的n次幂
        adc_v = tmp;
        adc_v = ((long)adc_v*5000/1023);
        OverFlag = 0;
        GO_DONE = 1;
        DisplayData(adc_v);
void DisplayData (unsigned int iData )
    char i=0,j=0;//
    char k = 0,NumStr[ 5 ]={0,0,0,0,0};
    NumStr[1]=iData / 1000;//取整
    NumStr[2]=iData % 1000/100;
    NumStr[3]=iData % 100/10;
    NumStr[4]=iData % 10;
    for(i=0;i<10;i++)
        SEG_BITSEL_PORT = k =0X01;
        for(j=0;j<=4;j++)
            SEG_BITSEL_PORT = k;
            if(j==1)
                SEG_FONT_PORT = Seg7TableN[NumStr[1]]&0b01111111;
            else
                SEG_FONT_PORT = Seg7TableN[NumStr[j]];
            delayms(5);
            k = k <<1;//把1向左移1为显示
    int i=0,j =0;
    for(i=0;i < ms;i++)
        for(j =0; j < DLY_MS;j++)
//仿真结果,单片机数码管显示全是0,与设计的测量电阻电压不对,希望大家来找茬,这原因与结果
