W806呼吸灯
706|3
 楼主| 34af9uc 发表于 2021-12-1 23:45 | 显示全部楼层 |阅读模式
/****************联盛德W806呼吸灯******************/
/****************QQ:774145445**********************/
/****************快手:共同学习stm8*****************/
/****************AboutCDK 2.10.1*******************/
//a1++  0|__ __ __ __ __ __ __ __ __ __|ff
//                  a2↑              ↑
//                  ledh(开灯)      ledl(关灯)
#define                GPIOB_DATA                        (*(volatile unsigned int*)(0x40011400+0x0000))
#define                GPIOB_DATA_EN                (*(volatile unsigned int*)(0x40011400+0X0004))
#define                GPIOB_DIR                        (*(volatile unsigned int*)(0x40011400+0X0008))
#define                wei0                0b0000000000000001
#define                wei1                0b0000000000000010
#define                wei2                0b0000000000000100
#define                wei3                0b0000000000001000
#define                wei4                0b0000000000010000
#define                wei5                0b0000000000100000
#define                wei6                0b0000000001000000
#define                wei7                0b0000000010000000
#define                wei8                0b0000000100000000
#define                wei9                0b0000001000000000
#define                wei10                0b0000010000000000
#define                wei11                0b0000100000000000
#define                wei12                0b0001000000000000
#define                wei13                0b0010000000000000
#define                wei14                0b0100000000000000
#define                wei15                0b1000000000000000
#define                led_h                GPIOB_DATA|=wei0
#define                led_l                GPIOB_DATA&=~wei0
void                yanshi();                //延时
int main(void)
unsigned char a1,a2;
unsigned char b1;
a1                =0;                //计数器
a2                =0x30;        //比较器
b1                =0;                //状态(0渐亮1渐暗)
/**************************************************/                //IO配置
GPIOB_DATA_EN                |=wei0;
GPIOB_DIR                        |=wei0;
GPIOB_DATA                        |=wei0;
led_h;                //灭灯
while (1)
if(a1 ==a2) {led_l;}                //开灯
a1                ++;
if(a1==0xff)
                led_h;                //关灯
                if(b1==0)                //渐亮
                        a2 --;
                        if(a2==10){b1=1;}
                if(b1==1)                //渐暗
                        a2 ++;
                        if(a2==0xe0){b1=0;}
yanshi();
return 0;
void                yanshi()                //延时
volatile unsigned int x;
        for(x=48,x>0;x--;);
W806呼吸灯.zip
31.67 KB, 下载次数: 5
 楼主| 34af9uc 发表于 2022-4-2 17:45 | 显示全部楼层
王栋春 发表于 2021-12-2 22:54
围观了解一下,对单片机感兴趣就是学不会呀!
已经放弃了
 楼主| 34af9uc 发表于 2021-12-5 13:30 | 显示全部楼层
可简单了就像1+1=2
王栋春 发表于 2021-12-2 22:54 | 显示全部楼层
319
