2410和linux,请帮个帮!谢谢!
2431|1
 楼主| bl20020825 发表于 2007-4-25 22:00 | 显示全部楼层 |阅读模式
我在flash中就下了vivi,和kernel zImage然后
重启2410开发平台,结果如下,为何呢?
VIVI version 0.1.4 (root@localhost.localdomain) (gcc version 2.95.2 20000516 (release)
[Rebel.com]) #0.1.4 三 4月 25 10:49:26 PHT 2007
Evacuating 1MB of Flash to DRAM at 0x33F00000
MMU table base address = 0x33DFC000
Map flash virtual section to DRAM at 0x33F00000
Succeed memory mapping.
S3C2410 flash: probing 16-bit flash bus
S3C2410 amd flash: Probing for AMD compatible flash...
S3C2410 amd flash: Found 1 x 2MiB AMD AM29LV160DB at 0x0
Could not found stored vivi parameters. Use default vivi parameters.
Press Return to start the LINUX now, any other key for vivi
Copy linux kernel from 0x00030000 to 0x30008000, size = 0x000c0000 ... done
Warning: this binary is not compressed linux kernel image
zImage magic = 0xc76a0125
Setup linux parameters at 0x30000100
linux command line is: "noinitrd root=/dev/mtdblock/3 init=/linuxrc console=ttyS0"
MACH_TYPE = 193
NOW, Booting Linux......
是否必须下载了文件系统候,才能看到镜像文件的解压,linux的运行呢?
 楼主| bl20020825 发表于 2007-4-26 14:34 | 显示全部楼层
问题已解决!
应该是MTD分区问题!
