请问有做过U盘高手,write10(scsi_2)应该怎样写好?
5075|10
 楼主| 小小电子 发表于 2007-5-3 20:03 | 显示全部楼层 |阅读模式
我用的是128M的flash,由于单片机的数据存储器容量有限,所以我有4次读写完成1 page 的操作.下面这样写可以吗?
void Write10(void)
  unsigned long int  ByteCount;
  unsigned int Transfer_Length;
  unsigned int address;
  unsigned char rank;
  unsigned long Logical_Block_Address;
  Logical_Block_Address=cbw.CBWCB[2]*0x1000000;
  Logical_Block_Address+=cbw.CBWCB[3]*0x10000;
  Logical_Block_Address+=cbw.CBWCB[4]*0x100;
  Logical_Block_Address+=cbw.CBWCB[5];
  Transfer_Length=cbw.CBWCB[7]*256+cbw.CBWCB[8];//the number of page(block).
  while(Transfer_Length--)
   for(rank=1;rank<=4;rank++)
      ByteCount=512;address=0;
      while(ByteCount>MAX_BULK_DATA_SIZE)
        read_endpoint_buff(1,MAX_BULK_DATA_SIZE,&buffer[address]);
     ByteCount-=MAX_BULK_DATA_SIZE;
        address+=MAX_BULK_DATA_SIZE;
    read_endpoint_buff(1,ByteCount,&buffer[address]);
    Flash_page_program(rank,Logical_Block_Address,&buffer);
   Flash_reflash();
   Logical_Block_Address++;
  Return_CSW(0,SUCCESS);
 楼主| 小小电子 发表于 2007-5-3 20:14 | 显示全部楼层
高手们帮帮忙,没什么时间了.
高手们帮帮忙,没什么时间了.
coke 发表于 2007-5-4 09:56 | 显示全部楼层
我用ARM做电子盘的代码.
 *               Exec_UFI_Command
 *  Mass storage UFI command
 *  Input: Non
 *  Output: None
 *  Remark: After the Houst get the get LUN comman. then requir the command
 *    1: INQUIRY    2-->READ CAPACITY  3-->Read   4-->MODE SENSE ....... N:READ
 *  Send a CSW command when complete data transimit
void Exec_UFI_Command()
    U32  cnt=0, len=0;
    U32  Addr=0, tmp=0, sum=0, old=0;
    U8*  p_buff,*p_temp,*p_save;
    Format_list *p_format_desc;
    switch(pufi1->bOpCode)
        case TEST_UNIT_READY:             //0X00 TEST UNIT READY  测试单元准备直接回复CSW
             csw1.dCSWDataResidue = 0;
             csw1.bCSWStatus = 0x00;
             USB_Send_Data(13,(U8*)&csw1);
             break;
        case Request_Sense:             //0X03 REQUEST SENSE 请求判断
             ReqSense[ 0] = 0x70;       // Response Code
               ReqSense[ 1] = 0x00;
               ReqSense[ 2] = 0x02;       // Sense Key
               ReqSense[ 3] = 0x00;
               ReqSense[ 4] = 0x00;
               ReqSense[ 5] = 0x00;
               ReqSense[ 6] = 0x00;
               ReqSense[ 7] = 0x0A;       // Additional Length
               ReqSense[ 8] = 0x00;
               ReqSense[ 9] = 0x00;
               ReqSense[10] = 0x00;
               ReqSense[11] = 0x00;
               ReqSense[12] = 0x30;       // ASC
               ReqSense[13] = 0x01;       // ASCQ
               ReqSense[14] = 0x00;
               ReqSense[15] = 0x00;
               ReqSense[16] = 0x00;
               ReqSense[17] = 0x00;
             USB_Send_Data(18,ReqSense);
             break;
        case INQUIRY:                    //0x12 INQUIRY 查询
             USB_Send_Data(36,query_ret);
             csw1.dCSWDataResidue = cbw1.dCBWDataTransferLength - 0x24;
             break;
        case FORMAT_UNIT:             //FORMAT
             if((pufi1->bLun & 0x1F!=0x17)    || (cbw1.bCBWLUN > Disk_number))
                     csw1.bCSWStatus = 0x01;
             else
                     sum  = pufi1->wLength[1];
                     sum  = sum << 8;
                     sum += pufi1->wLength[0];
                     p_buff=RX_BUFF;
                     while(!(event_table & EVT_USB_BULK_RX));          //waitting for the RX flag
                        clear_event(EVT_USB_BULK_RX);                      //clear the RX flag ordor to receive the data in loop
                        USB_bulk_fast_read(TX_BULK_EP_FIFO_SIZE,p_buff);
                        p_format_desc=(Format_list*)p_buff;
                        if((p_format_desc->Number_block != partition_table[cbw1.bCBWLUN]->total_sector)||(p_format_desc->Block_length != partition_table[cbw1.bCBWLUN]->fs->bpb.byte_per_sector))
                         ReqSense[2] = 0x01;     //sense data : SENSE
                     else
                         ReqSense[2] = 0x00;     //sense data : NO SENSE
                         FAT_FORMAT(cbw1.bCBWLUN);
             break;
        case MODE_SELECT6:             //MODE SELECT
             break;
        case MODE_SENSE6:              //0x1A
                USB_Send_Data(4,MODE00_RET);
             csw1.dCSWDataResidue = cbw1.dCBWDataTransferLength - DevModePage.MediumType[1] - 2;
             break;
        case MODE_SENSE10:             //0x5A MODE SENSE(10)     模式判别
               SendBuf[ 0] = 0x00;
               SendBuf[ 1] = 0x06;    //Mode data length in byte(not include itself)
               SendBuf[ 2] = 0x00;    //Medium type code
               SendBuf[ 3] = 0x00;
               SendBuf[ 4] = 0x00;
               SendBuf[ 5] = 0x00;
               SendBuf[ 6] = 0x00;
               SendBuf[ 7] = 0x00;
             USB_Send_Data(8,SendBuf);
             break;
        case Read_Format_Capacity:     //0x23 READ FORMAT CAPACITIES 读格式化容量
             SendBuf[0] = 0x00;        //reserved
             SendBuf[1] = 0x00;        //reserved
             SendBuf[2] = 0x00;        //reserved
             SendBuf[3] = 0x08;        //Capacity List Length
             // Block Count
             SendBuf[4] = ((partition_table[cbw1.bCBWLUN]->total_sector ) >> 24) & 0xFF;            //BIT[4..7] number of sector
             SendBuf[5] = ((partition_table[cbw1.bCBWLUN]->total_sector ) >> 16) & 0xFF;
             SendBuf[6] = ((partition_table[cbw1.bCBWLUN]->total_sector ) >>  8) & 0xFF;
             SendBuf[7] = ((partition_table[cbw1.bCBWLUN]->total_sector ) >>  0) & 0xFF;
             SendBuf[8] = 0x02;     //Descriptor Code: Formatted Media
              // Block Length
             SendBuf[9]  = (partition_table[cbw1.bCBWLUN]->fs->bpb.byte_per_sector >> 16) & 0xFF;;     //bytes per sector
             SendBuf[10] = (partition_table[cbw1.bCBWLUN]->fs->bpb.byte_per_sector >>  8) & 0xFF;;
             SendBuf[11] = (partition_table[cbw1.bCBWLUN]->fs->bpb.byte_per_sector >>  0) & 0xFF;;
             USB_Send_Data(12,(U8*)SendBuf);
             csw1.dCSWDataResidue = cbw1.dCBWDataTransferLength - 12;
             break;
        case READ_CAPACITY:         //0x25 读容量 SendBuf[0-3]:returned logic block address  SendBuf[4-7]: Block length in byte
             SendBuf[0] = ((partition_table[cbw1.bCBWLUN]->total_sector - 1) >> 24) & 0xFF;
             SendBuf[1] = ((partition_table[cbw1.bCBWLUN]->total_sector - 1) >> 16) & 0xFF;
             SendBuf[2] = ((partition_table[cbw1.bCBWLUN]->total_sector - 1) >>  8) & 0xFF;
             SendBuf[3] = ((partition_table[cbw1.bCBWLUN]->total_sector - 1) >>  0) & 0xFF;     //max block number is 0xfff.暂时使用K9K1G nand flash=128M bytes = 128*1024/32(每蔟=64扇*1page)=0x1000
             SendBuf[4] = (partition_table[cbw1.bCBWLUN]->fs->bpb.byte_per_sector >> 24) & 0xFF;
             SendBuf[5] = (partition_table[cbw1.bCBWLUN]->fs->bpb.byte_per_sector >> 16) & 0xFF;
             SendBuf[6] = (partition_table[cbw1.bCBWLUN]->fs->bpb.byte_per_sector >>  8) & 0xFF;
             SendBuf[7] = (partition_table[cbw1.bCBWLUN]->fs->bpb.byte_per_sector >>  0) & 0xFF;         //Block length 每block = 512bytes
             USB_Send_Data(8,(U8*)SendBuf);
             csw1.dCSWDataResidue = cbw1.dCBWDataTransferLength - 0x08;
             break;
        case PREVENT_ALLOW:         //PREVENT-ALLOW MEDIUM REMOVAL 直接回复CSW.
             break;
        case READ10:         //0x28 READ(10)                          //把相应地址的数据一直发送完,最后送一个CSW
             if(MSC_RWSetup())
                 old  =  Length * (partition_table[cbw1.bCBWLUN]->fs->bpb.byte_per_sector);            //length of data to receive (in byte)
                 p_buff=A_malloc(old);
                 p_save=p_buff;
                 p_temp=p_buff;
                 sum=Offset + partition_table[cbw1.bCBWLUN]->offset_sector;
                 fnIDE_BufferSector((WORD*)p_save,sum,Length);
                 for(len=0;len < Length<<3; len++)
                       USB_Send_Data(64,p_temp);                        //写数据到端点2
                       p_temp += 64;
                   A_free(p_buff);
                csw1.dCSWDataResidue = cbw1.dCBWDataTransferLength - old;
                USB_Send_Data(13,(U8*)&csw1);                        //send CSW command and complite this SCSI
            else
            break;
        case WRITE10: //0x2A  WRITE(10)
             if(MSC_RWSetup())
                 p_save=p_buff;
                 p_temp=p_buff;
                            USB_bulk_fast_read(64,p_save);
                           p_save += 64;
                   fnIDE_WriteBufferSector((WORD*)p_temp,sum,Length);
                   A_free(p_buff);
                 csw1.dCSWDataResidue = cbw1.dCBWDataTransferLength - sum;
             else
             break;
        case Verify: //0x2F 验证
             if(MSC_RWSetup())
             else
             break;
        case REZERO_UNIT:         //REZERO UNIT
             break;
        case SEEK10:             //SEEK
             break;
        case SEND_DIAGNOSTIC:     //SEND DIAGNOSTIC
             break;
        case Star_Stop:         //START-STOP UNIT
             break;
        default://Error
             break;
262063258 发表于 2007-5-4 19:24 | 显示全部楼层
请问一下coke:
你用的方法是查询的还是中断的?
read10,write10,中未传数据通过返回CSW给host后,要求HOST再传送吗?
那处理函数是另外在写,还是也用read10/write10呢?
nand flash 在写操作之前不是要察除吗?
我就是在write10这些操作上有点问题,能否给点意见!
谢谢!!
coke 发表于 2007-5-5 08:52 | 显示全部楼层
RE
你用的方法是查询的还是中断的?
read10. write10命令是主机用USB发命令给slave的. 在USB接收中断中设标志位.在主程序中查询该标志.
不需要
不明白你的意思. read10就是host要读你slave的存储盘的资料信息和数据. write10就是要将数据和信息写到你的存储器中. 读写地址.大小都在host发给slave的信息中.你根据你的BPB/MBR转换就可以操作你的nand flash了.
是. 以扇为单位察除
262063258 发表于 2007-5-5 10:53 | 显示全部楼层
谢谢你(coke)的回答.我还有些问题请教.
请问:
1.程序中
  和
  得出的结果csw1.dCSWDataResidue都为0吗?
  如果不为0,host会怎样处理呢?
2.在逻辑地址转物理地址上有点弄不清楚:
  sum就是存储起的实际地址吗?offset是文件系统占用的扇区吗?
  你说的根据BPB/MBR转换的,可以说清楚点吗?打个比方.
谢谢!!!
262063258 发表于 2007-5-6 11:17 | 显示全部楼层
帮帮
请问:
1.程序中
  和
  如果不为0,host会怎样处理呢?
谢谢!!!
zhiwei 发表于 2012-7-21 20:58 | 显示全部楼层
最近做U盘控制器遇到一个问题,bulk-out写U盘的时候数据过快,控制器没有写完毕,缓冲区也没有了,该发哪种sensekey给主机以阻塞主机一下呢?
okbohetang 发表于 2014-6-29 16:47 | 显示全部楼层
你好,请问bCBWLUN这个字段的用法是什么,如果有多个逻辑单元,要怎么处理?谢谢!
sandy_ 发表于 2015-6-11 15:27 | 显示全部楼层
最近做U盘控制器遇到一个问题,bulk-out写U盘的时候数据过快,控制器没有写完毕,缓冲区也没有了,该发哪种 ...
这个问题现在知道答案了么,我也遇到同样的问题不知道怎么办
john_lee 发表于 2015-6-14 00:42 | 显示全部楼层
USB 协议本身就是自带流控的,你不设置应答,那么 USB device 控制器是不会接收下一个packet的(会自动向host返回NAK),host 则会在下一个 frame 再次发送这个 packet,直到你设置了应答让 device 接收为止。
