W801流水灯
499|0
 楼主| 34af9uc 发表于 2021-12-26 00:32 | 显示全部楼层 |阅读模式
#define                wei0                0b00000000000000000000000000000001
#define                wei1                0b00000000000000000000000000000010
#define                wei2                0b00000000000000000000000000000100
#define                wei3                0b00000000000000000000000000001000
#define                wei4                0b00000000000000000000000000010000
#define                wei5                0b00000000000000000000000000100000
#define                wei6                0b00000000000000000000000001000000
#define                wei7                0b00000000000000000000000010000000
#define                wei8                0b00000000000000000000000100000000
#define                wei9                0b00000000000000000000001000000000
#define                wei10                0b00000000000000000000010000000000
#define                wei11                0b00000000000000000000100000000000
#define                wei12                0b00000000000000000001000000000000
#define                wei13                0b00000000000000000010000000000000
#define                wei14                0b00000000000000000100000000000000
#define                wei15                0b00000000000000001000000000000000
#define                wei16                0b00000000000000010000000000000000
#define                wei17                0b00000000000000100000000000000000
#define                wei18                0b00000000000001000000000000000000
#define                wei19                0b00000000000010000000000000000000
#define                wei20                0b00000000000100000000000000000000
#define                wei21                0b00000000001000000000000000000000
#define                wei22                0b00000000010000000000000000000000
#define                wei23                0b00000000100000000000000000000000
#define                wei24                0b00000001000000000000000000000000
#define                wei25                0b00000010000000000000000000000000
#define                wei26                0b00000100000000000000000000000000
#define                wei27                0b00001000000000000000000000000000
#define                wei28                0b00010000000000000000000000000000
#define                wei29                0b00100000000000000000000000000000
#define                wei30                0b01000000000000000000000000000000
#define                wei31                0b10000000000000000000000000000000
#define                GPIOB_DATA                        (*(volatile unsigned int*)(0x40011400+0x0000))
#define                GPIOB_DATA_EN                (*(volatile unsigned int*)(0x40011400+0X0004))
#define                GPIOB_DIR                        (*(volatile unsigned int*)(0x40011400+0X0008))
#define                led1_l                GPIOB_DATA        |=wei5;
#define                led1_h                GPIOB_DATA        &=~wei5;
#define                led2_l                GPIOB_DATA        |=wei25;
#define                led2_h                GPIOB_DATA        &=~wei25;
#define                led3_l                GPIOB_DATA        |=wei26;
#define                led3_h                GPIOB_DATA        &=~wei26;
#define                led4_l                GPIOB_DATA        |=wei18;
#define                led4_h                GPIOB_DATA        &=~wei18;
#define                led5_l                GPIOB_DATA        |=wei17;
#define                led5_h                GPIOB_DATA        &=~wei17;
#define                led6_l                GPIOB_DATA        |=wei16;
#define                led6_h                GPIOB_DATA        &=~wei16;
#define                led7_l                GPIOB_DATA        |=wei11;
#define                led7_h                GPIOB_DATA        &=~wei11;
void                xianshi();                //显示
void                yanshi_1s();        //延时1秒
unsigned char                liushui_a1;
int main(void)
unsigned char                liushui_b1;
GPIOB_DATA_EN                |=wei5+wei25+wei26+wei18+wei17+wei16+wei11;                //使能
GPIOB_DIR                        |=wei5+wei25+wei26+wei18+wei17+wei16+wei11;                //输出
GPIOB_DATA                        |=wei5+wei25+wei26+wei18+wei17+wei16+wei11;                //输出高
while (1)
liushui_a1                =0x01;
liushui_b1                =7;
while(liushui_b1--)
xianshi();                                        //显示
yanshi_1s();
liushui_a1                <<=1;                //左移一位
liushui_a1                =0x20;
liushui_b1                =5;
while(liushui_b1--)
xianshi();                                        //显示
yanshi_1s();
liushui_a1                >>=1;                //左移一位
    return 0;
void                xianshi()                //显示
if(liushui_a1&0x01){led1_h;}        else{led1_l;}
if(liushui_a1&0x02){led2_h;}        else{led2_l;}
if(liushui_a1&0x04){led3_h;}        else{led3_l;}
if(liushui_a1&0x08){led4_h;}        else{led4_l;}
if(liushui_a1&0x10){led5_h;}        else{led5_l;}
if(liushui_a1&0x20){led6_h;}        else{led6_l;}
if(liushui_a1&0x40){led7_h;}        else{led7_l;}
void                yanshi_1s()        //延时1秒
volatile unsigned int                x,y;
        for(x=1000;x>0;x--)
                for(y=10000;y>0;y--);
