[DemoCode下载] [M032] USB Composite Device of Virtual COM Port and Multimedia Key
621|0
 楼主| 奔跑的牛 发表于 2021-12-28 15:50 | 显示全部楼层 |阅读模式
  • Application: This sample code demonstrates how to implement a USB HID composite device (Virtual COM Port and Multimedia Key).
  • BSP Version: M031 BSP CMSIS V3.03.000
  • Hardware: NuMaker-M032KI Ver1.0
A USB Composite Device is a peripheral device that supports more than one device class at the same time. This example code consists of Virtual Com port and HID media key in one USB device. The HID class is for reporting the key buttons inputs to control the mute, brightness, keyboard brightness and volume up/down of multimedia functions through the USB protocol.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1105113443
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
