调试GD32F407xx分享(六)
924|0
 楼主| QQ2224043166 发表于 2021-12-30 13:17 | 显示全部楼层 |阅读模式
SPI/* SPI1 init function */
#define SPI_TIME_OUT  100
void GD_SPI_Init(uint32_t spi_periph)
    spi_parameter_struct spi_init_struct;
        if(spi_periph == SPI0)
                /* SPI parameter config */
                spi_init_struct.trans_mode           = SPI_TRANSMODE_FULLDUPLEX;
                spi_init_struct.device_mode          = SPI_MASTER;
                spi_init_struct.frame_size           = SPI_FRAMESIZE_8BIT;
                spi_init_struct.clock_polarity_phase = SPI_CK_PL_LOW_PH_1EDGE;
                spi_init_struct.nss                  = SPI_NSS_SOFT;
                spi_init_struct.prescale                          = SPI_PSC_8;
                spi_init_struct.endian               = SPI_ENDIAN_MSB;
                GD_SPI_CsInit(SPI0);
                GD_SPI_MspInit(SPI0);
                spi_init(SPI0, &spi_init_struct);
                spi_enable(SPI0);
void GD_SPI_MspInit(uint32_t spi_periph)
                spi_disable(SPI0);
                spi_i2s_deinit(SPI0);
                rcu_periph_clock_enable(RCU_GPIOA);
                rcu_periph_clock_enable(RCU_GPIOB);
                /**SPI0 GPIO Configuration
                PA5     ------> SPI0_SCK
                PA6     ------> SPI0_MISO
                PB5     ------> SPI0_MOSI
                /* SPI0 clock enable */
                rcu_periph_clock_enable(RCU_SPI0);
                /* SPI0 GPIO config */
                gpio_af_set(GPIOB, GPIO_AF_5, GPIO_PIN_5);
                gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_5);
                gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_5);
                gpio_af_set(GPIOA, GPIO_AF_5, GPIO_PIN_5 | GPIO_PIN_6);
                gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_5 | GPIO_PIN_6);
                gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_5 | GPIO_PIN_6);
void GD_SPI_MspDeInit(uint32_t spi_periph)
                spi_disable(SPI0);
                /* Peripheral clock disable */
                rcu_periph_clock_disable(RCU_SPI0);
                gpio_mode_set(GPIOB, GPIO_MODE_INPUT, GPIO_PUPD_PULLDOWN, GPIO_PIN_5);
                gpio_mode_set(GPIOA, GPIO_MODE_INPUT, GPIO_PUPD_PULLDOWN, GPIO_PIN_5 | GPIO_PIN_6);
uint8_t SPI0_ReadWriteByte(uint8_t TxData)
    uint8_t retry = 0;
    while( spi_i2s_flag_get( SPI0, SPI_FLAG_TBE) == RESET )
        retry++;
        if( retry > SPI_TIME_OUT )
            return 0;
    spi_i2s_data_transmit( SPI0, TxData );
    retry = 0;
    while( spi_i2s_flag_get( SPI0, SPI_FLAG_RBNE) == RESET )
        retry++;
            return 0;
    return spi_i2s_data_receive( SPI0 );
