请大家帮忙看看这些错误是咋回事
3589|1
 楼主| pbwy123123 发表于 2012-3-22 16:53 | 显示全部楼层 |阅读模式
ce, AC, CAN, AN, TE
EPM7128SLC84-15   是俺用的CPLD
Warning: Macrocell buffer inserted after node "dataout[53]~reg0"
Warning: Macrocell buffer inserted after node "dataout[55]~reg0"
Warning: Macrocell buffer inserted after node "dataout[56]~reg0"
Error: Can't pack LABs
Error: Can't place node "jsq.state_bit_0" of type max_mcell
Error: Can't place node "outbit" of type max_mcell
Error: Can't place node "data[1]" of type max_mcell
Error: Can't place node "jsq.state_bit_1" of type max_mcell
Error: Can't place node "data[3]" of type max_mcell
Error: Can't place node "jsq.state_bit_2" of type max_mcell
Error: Can't place node "data[0]" of type max_mcell
Error: Can't place node "data[2]" of type max_mcell
Error: Can't place node "data[4]" of type max_mcell
Error: Can't place node "data[5]" of type max_mcell
Error: Can't place node "temp2[3]" of type max_mcell
Error: Can't place node "temp2[2]" of type max_mcell
Error: Can't place node "temp2[1]" of type max_mcell
Error: Can't place node "temp2[0]" of type max_mcell
Error: Can't place node "temp1[3]" of type max_mcell
Error: Can't place node "temp1[2]" of type max_mcell
Error: Can't place node "temp1[1]" of type max_mcell
Error: Can't place node "temp1[0]" of type max_mcell
Error: Can't place node "dataout[53]~reg0" of type max_mcell
Error: Can't place node "dataout[55]~reg0" of type max_mcell
Error: Can't place node "dataout[56]~reg0" of type max_mcell
Error: Can't place node "Selector4~27" of type max_mcell
Error: Can't place node "Selector2~23" of type max_mcell
Error: Can't place node "Selector4~35" of type max_mcell
Error: Can't place node "Selector2~31" of type max_mcell
Error: Can't find fit
Error: Quartus II Fitter was unsuccessful. 27 errors, 3 warnings
Error: Peak virtual memory: 161 megabytes
Error: Processing ended: Thu Mar 22 16:41:34 2012
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 29 errors, 3 warnings
梅花望青竹 发表于 2012-3-23 11:42 | 显示全部楼层
看到别人更改一下原代码,合并了一些相同的进程,这样就解决了
