ARM cortex-M 系列 HardFault的诊断
2150|9
 楼主| keer_zu 发表于 2022-1-26 11:20 | 显示全部楼层 |阅读模式
(转自 aozima)rt-thread问答。
ARM cortex-M上面的fault想必大家都不陌生,我相信还没有谁从来没有出现过fault。
但出现fault后如何排查,相信很多人都是一筹莫展。
在我的项目中加了一些代码,Fault 后可以打印出更多的信息。
  1. #define SCB_CFSR        (*(volatile const unsigned *)0xE000ED28) /* Configurable Fault Status Register */
  2. #define SCB_HFSR        (*(volatile const unsigned *)0xE000ED2C) /* HardFault Status Register */
  3. #define SCB_MMAR        (*(volatile const unsigned *)0xE000ED34) /* MemManage Fault Address register */
  4. #define SCB_BFAR        (*(volatile const unsigned *)0xE000ED38) /* Bus Fault Address Register */
  5. #define SCB_CFSR_MFSR   (*(volatile const unsigned char*)0xE000ED28)  /* Memory-management Fault Status Register */
  6. #define SCB_CFSR_BFSR   (*(volatile const unsigned char*)0xE000ED29)  /* Bus Fault Status Register */
  7. #define SCB_CFSR_UFSR   (*(volatile const unsigned short*)0xE000ED2A) /* Usage Fault Status Register */
  8. static void usage_fault_track(void)
  9. {
  10.     rt_kprintf("usage fault:
  11. ");
  12.     rt_kprintf("SCB_CFSR_UFSR:0x%02X ", SCB_CFSR_UFSR);
  13.     if(SCB_CFSR_UFSR & (1<<0))
  14.     {
  15.         /* [0]:UNDEFINSTR */
  16.         rt_kprintf("UNDEFINSTR ");
  17.     }
  18.     if(SCB_CFSR_UFSR & (1<<1))
  19.     {
  20.         /* [1]:INVSTATE */
  21.         rt_kprintf("INVSTATE ");
  22.     }
  23.     if(SCB_CFSR_UFSR & (1<<2))
  24.     {
  25.         /* [2]:INVPC */
  26.         rt_kprintf("INVPC ");
  27.     }
  28.     if(SCB_CFSR_UFSR & (1<<3))
  29.     {
  30.         /* [3]:NOCP */
  31.         rt_kprintf("NOCP ");
  32.     }
  33.     if(SCB_CFSR_UFSR & (1<<8))
  34.     {
  35.         /* [8]:UNALIGNED */
  36.         rt_kprintf("UNALIGNED ");
  37.     }
  38.     if(SCB_CFSR_UFSR & (1<<9))
  39.     {
  40.         /* [9]:DIVBYZERO */
  41.         rt_kprintf("DIVBYZERO ");
  42.     }
  43.     rt_kprintf("
  44. ");
  45. }
  46. static void bus_fault_track(void)
  47. {
  48.     rt_kprintf("bus fault:
  49. ");
  50.     rt_kprintf("SCB_CFSR_BFSR:0x%02X ", SCB_CFSR_BFSR);
  51.     if(SCB_CFSR_BFSR & (1<<0))
  52.     {
  53.         /* [0]:IBUSERR */
  54.         rt_kprintf("IBUSERR ");
  55.     }
  56.     if(SCB_CFSR_BFSR & (1<<1))
  57.     {
  58.         /* [1]:PRECISERR */
  59.         rt_kprintf("PRECISERR ");
  60.     }
  61.     if(SCB_CFSR_BFSR & (1<<2))
  62.     {
  63.         /* [2]:IMPRECISERR */
  64.         rt_kprintf("IMPRECISERR ");
  65.     }
  66.     if(SCB_CFSR_BFSR & (1<<3))
  67.     {
  68.         /* [3]:UNSTKERR */
  69.         rt_kprintf("UNSTKERR ");
  70.     }
  71.     if(SCB_CFSR_BFSR & (1<<4))
  72.     {
  73.         /* [4]:STKERR */
  74.         rt_kprintf("STKERR ");
  75.     }
  76.     if(SCB_CFSR_BFSR & (1<<7))
  77.     {
  78.         rt_kprintf("SCB->BFAR:%08X
  79. ", SCB_BFAR);
  80.     }
  81.     else
  82.     {
  83.         rt_kprintf("
  84. ");
  85.     }
  86. }
  87. static void mem_manage_fault_track(void)
  88. {
  89.     rt_kprintf("mem manage fault:
  90. ");
  91.     rt_kprintf("SCB_CFSR_MFSR:0x%02X ", SCB_CFSR_MFSR);
  92.     if(SCB_CFSR_MFSR & (1<<0))
  93.     {
  94.         /* [0]:IACCVIOL */
  95.         rt_kprintf("IACCVIOL ");
  96.     }
  97.     if(SCB_CFSR_MFSR & (1<<1))
  98.     {
  99.         /* [1]:DACCVIOL */
  100.         rt_kprintf("DACCVIOL ");
  101.     }
  102.     if(SCB_CFSR_MFSR & (1<<3))
  103.     {
  104.         /* [3]:MUNSTKERR */
  105.         rt_kprintf("MUNSTKERR ");
  106.     }
  107.     if(SCB_CFSR_MFSR & (1<<4))
  108.     {
  109.         /* [4]:MSTKERR */
  110.         rt_kprintf("MSTKERR ");
  111.     }
  112.     if(SCB_CFSR_MFSR & (1<<7))
  113.     {
  114.         /* [7]:MMARVALID */
  115.         rt_kprintf("SCB->MMAR:%08X
  116. ", SCB_MMAR);
  117.     }
  118.     else
  119.     {
  120.         rt_kprintf("
  121. ");
  122.     }
  123. }
  124. static void hard_fault_track(void)
  125. {
  126.     if(SCB_HFSR & (1UL<<1))
  127.     {
  128.         /* [1]:VECTBL, Indicates hard fault is caused by failed vector fetch. */
  129.         rt_kprintf("failed vector fetch
  130. ");
  131.     }
  132.     if(SCB_HFSR & (1UL<<30))
  133.     {
  134.         /* [30]:FORCED, Indicates hard fault is taken because of bus fault,
  135.                         memory management fault, or usage fault. */
  136.         if(SCB_CFSR_BFSR)
  137.         {
  138.             bus_fault_track();
  139.         }
  140.         if(SCB_CFSR_MFSR)
  141.         {
  142.             mem_manage_fault_track();
  143.         }
  144.         if(SCB_CFSR_UFSR)
  145.         {
  146.             usage_fault_track();
  147.         }
  148.     }
  149.     if(SCB_HFSR & (1UL<<31))
  150.     {
  151.         /* [31]:DEBUGEVT, Indicates hard fault is triggered by debug event. */
  152.         rt_kprintf("debug event
  153. ");
  154.     }
  155. }
  156. /**
  157. * fault exception handling
  158. */
  159. void rt_hw_hard_fault_exception(struct stack_context* contex)
  160. {
  161.     rt_kprintf("psr: 0x%08x
  162. ", contex->psr);
  163.     rt_kprintf(" pc: 0x%08x
  164. ", contex->pc);
  165.     rt_kprintf(" lr: 0x%08x
  166. ", contex->lr);
  167.     rt_kprintf("r12: 0x%08x
  168. ", contex->r12);
  169.     rt_kprintf("r03: 0x%08x
  170. ", contex->r3);
  171.     rt_kprintf("r02: 0x%08x
  172. ", contex->r2);
  173.     rt_kprintf("r01: 0x%08x
  174. ", contex->r1);
  175.     rt_kprintf("r00: 0x%08x
  176. ", contex->r0);
  177.     hard_fault_track();
  178.     rt_kprintf("hard fault on thread: %s
  179. ", rt_current_thread->name);
  180. #ifdef RT_USING_FINSH
  181.     list_thread();
  182. #endif
  183.     while (1);
  184. }
 楼主| keer_zu 发表于 2022-1-26 11:23 | 显示全部楼层
再写了两个测试代码,以手动触发fault。
  1. void div0_test(void)
  3.     volatile int * SCB_CCR = (volatile int *)0xE000ED14; // SCB->CCR
  4.     int x,y,z;
  5.     *SCB_CCR |= (1 << 4); /* bit4: DIV_0_TRP. */
  6.     x = 10;
  7.     y = 0;
  8.     z = x / y;
  9.     rt_kprintf("z:%d
  10. ", z);
  11. }
  12. void unalign_test(void)
  13. {
  14.     volatile int * SCB_CCR = (volatile int *)0xE000ED14; // SCB->CCR
  15.     volatile int * p;
  16.     volatile int value;
  17.     *SCB_CCR |= (1 << 3); /* bit3: UNALIGN_TRP. */
  18.     p = (int *)0x00;
  19.     value = *p;
  20.     rt_kprintf("addr:0x%02X value:0x%08X
  21. ", (int)p, value);
  22.     p = (int *)0x04;
  23.     value = *p;
  24.     rt_kprintf("addr:0x%02X value:0x%08X
  25. ", (int)p, value);
  26.     p = (int *)0x03;
  27.     value = *p;
  28.     rt_kprintf("addr:0x%02X value:0x%08X
  29. ", (int)p, value);
  30. }
  31. #ifdef  RT_USING_FINSH
  32. #include <finsh.h>
  33. FINSH_FUNCTION_EXPORT(div0_test, div0_test)
  34. FINSH_FUNCTION_EXPORT(unalign_test, unalign_test)
  35. #endif /* RT_USING_FINSH */
测试访问末授权区域
  1. finsh>>int * p //声明一个指针变量
  2.         0, 0x00000000
  3. finsh>>p = 0xDFFFFFF0 // 指向片上外设区结束处,一般不可能用完,所以此处一般不可访问。
  4.         -536870928, 0xdffffff0
  5. finsh>>*p // 读取指针处数据
  6. psr: 0x01000000
  7. pc: 0x00000e3e
  8. lr: 0x0000451d
  9. r12: 0x00000000
  10. r03: 0x00000000
  11. r02: 0x1fff0180
  12. r01: 0x1fff0814
  13. r00: 0xdffffff0
  14. bus fault:
  15. SCB_CFSR_BFSR:0x82 PRECISERR SCB->BFAR:DFFFFFF0
  16. hard fault on thread: tshell
  17. thread  pri  status      sp     stack size max used   left tick  error
  18. -------- ---- ------- ---------- ---------- ---------- ---------- ---
  19. tidle    0x1f ready   0x00000040 0x00000100 0x00000060 0x00000015 000
  20. tshell   0x14 ready   0x00000088 0x00000400 0x00000218 0x00000009 000
 楼主| keer_zu 发表于 2022-1-26 11:24 | 显示全部楼层
非对齐访问测试
  1. finsh>>unalign_test()
  2. addr:0x00 value:0x20001B80
  3. addr:0x04 value:0x0800DE81
  4. psr: 0x21000000
  5. r00: 0x00000000
  6. r01: 0x40013800
  7. r02: 0x20000690
  8. r03: 0x00000000
  9. r04: 0x00000003
  10. r05: 0xe000ed14
  11. r06: 0xdeadbeef
  12. r07: 0x20002678
  13. r08: 0xdeadbeef
  14. r09: 0xdeadbeef
  15. r10: 0xdeadbeef
  16. r11: 0xdeadbeef
  17. r12: 0x08000a95
  18. lr: 0x08002eb5
  19. pc: 0x08000386
  20. usage fault:
  21. SCB_CFSR_UFSR:0x100 UNALIGNED
  22. hard fault on thread: tshell
  23. thread  pri  status      sp     stack size max used   left tick  error
  24. -------- ---- ------- ---------- ---------- ---------- ---------- ---
  25. tidle    0x1f ready   0x00000040 0x00000100 0x0000005c 0x00000009 000
  26. tshell   0x14 ready   0x00000088 0x00000800 0x000001b0 0x0000000a 000
  27. led      0x14 suspend 0x00000078 0x00000200 0x00000078 0x00000005 000
除零异常测试
  1. finsh>>div0_test()
  2. psr: 0x41000000
  3. r00: 0x00000010
  4. r01: 0x08000337
  5. r02: 0x20000bb7
  6. r03: 0x20000130
  7. r04: 0xe000ed14
  8. r05: 0x00000000
  9. r06: 0xdeadbeef
  10. r07: 0x0000000a
  11. r08: 0xdeadbeef
  12. r09: 0xdeadbeef
  13. r10: 0xdeadbeef
  14. r11: 0xdeadbeef
  15. r12: 0x00000000
  16. lr: 0x08008d91
  17. pc: 0x08000348
  18. usage fault:
  19. SCB_CFSR_UFSR:0x200 DIVBYZERO
  20. hard fault on thread: tshell
  21. thread  pri  status      sp     stack size max used   left tick  error
  22. -------- ---- ------- ---------- ---------- ---------- ---------- ---
  23. tidle    0x1f ready   0x00000058 0x00000100 0x0000005c 0x0000000f 000
  24. tshell   0x14 ready   0x00000088 0x00000800 0x000001b0 0x0000000a 000
  25. led      0x14 suspend 0x00000078 0x00000200 0x00000078 0x00000005 000
问题追踪
上面测试出了问题,是我们人为设置的故障,但在平时调试中出了问题如何追综呢?
以非对齐访问为例,开发环境使用MDK。
进入JTAG仿真状态,并触发非对齐异常。
此时串口会打印出异常时的寄存器值,此时停止仿真器发现程序停在rt_hw_hard_fault_exception中。
根据上面打印出来的寄存器,提取出关键值是 pc: 0x08000386
我们在MDK的command窗口中输入 pc = 0x08000386
 楼主| keer_zu 发表于 2022-1-26 11:25 | 显示全部楼层
可以把PC指针临时设回问题发生时的场景,我们看到出现问题的指令是
  1.    239:     p = (int *)0x03;
  2. 0x08000384 2403      MOVS     r4,#0x03
  3.    240:     value = *p;
  4. 0x08000386 6820      LDR      r0,[r4,#0x00]
  5. 0x08000388 9000      STR      r0,[sp,#0x00]
分析 #386 这条指令从 R4+0 的问题读取4字节到R0中,
先前打印出的R4的值为 r04: 0x00000003
因此可以确定为这是因为地址不对齐造成的。
 楼主| keer_zu 发表于 2022-1-26 11:26 | 显示全部楼层
当然,具体情况要具体分析,有时候某个步骤出现问题并不会马上崩溃,
而是过一段时间以后才出问题,因此要结合上下文综合分析。
比如上面这个案例真正有问题的指令是 0x08000384。
根据以上的案例,并结合实际调试经验,相信大家可以更快地找出问题。
下面是ST研究会上面的PPT,供参考。
stm32Hard Fault的诊断.pdf
1497
