[技术问答] 在IDCard.dll中无法找到SDT_OpenPort
1604|3
 楼主| 更多更合适ii 发表于 2022-1-29 11:15 | 显示全部楼层 |阅读模式
AD, ar, dc, pen, sd
函数名没问题,可以编译,在进入运行后,使用该功能会中断运行,说在IDCard.dll中无法找到SDT_OpenPort的入口点?
   [DllImport("IDCard.dll", EntryPoint = "SDT_GetCOMBaud", CharSet = CharSet.Ansi)]
  1. <div><div>    public static extern int SDT_GetCOMBaud(int iPort, ref uint puiBaudRate);</div><div>    [DllImport("IDCard.dll", EntryPoint = "SDT_OpenPort", CharSet = CharSet.Ansi)]</div><div>    public static extern int SDT_OpenPort(int iPort);</div><div> </div><div>            [DllImport("IDCard.dll", EntryPoint = "SDT_SetCOMBaud (int iPort, uint uiCurrBaud, uint uiSetBaud)SDT_OpenPort", CharSet = CharSet.Ansi)]</div><div>    public static extern int SDT_SetCOMBaud(int iPort);</div><div>    [DllImport("IDCard.dll", EntryPoint = "SDT_ClosePort", CharSet = CharSet.Ansi)]</div><div>    public static extern int SDT_ClosePort(int iPort);</div></div><div></div>
 楼主| 更多更合适ii 发表于 2022-1-29 11:16 | 显示全部楼层
  1. private void button4_Click(object sender, EventArgs e)
  2.         {
  3.             IDCardData CardMsg = new IDCardData();
  4.             int nRet, nPort;
  5.             string stmp;
  6.             byte[] cPath = new byte[255];
  7.             byte[] pucIIN = new byte[4];
  8.             byte[] pucSN = new byte[8];
  9.             nPort = m_iPort;
  10.                     if (SDT_OpenPort(nPort) == 0)
  11.          }
 楼主| 更多更合适ii 发表于 2022-1-29 11:17 | 显示全部楼层
究竟是哪里出了问题
littlelida 发表于 2022-2-22 11:14 | 显示全部楼层
