[PCB] Qualcomm-Atheros IPQ6010 Support OpenWRT QCN9074 WiFi 6E Card DR6018 V4
1393|0
 楼主| wirelesswifi6 发表于 2022-2-9 13:18 | 显示全部楼层 |阅读模式
DR6018 V4
Support OpenWRT, Support:QUECTEL RM500Q-GL&Support:QCN9074 WiFi 6E Card
Support OpenWRT IPQ6010 802.11ax 2x2 2.4G&5G 2.5Gbps Ethernet Port
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
BY Wallys Communications (Suzhou) Co LTD
