[PCB设计资料] Wallys 17dBi Dual Polarized Micro strip Antenna Array 5GHz of frequency
1058|0
 楼主| wirelesswifi6 发表于 2022-2-17 15:44 | 显示全部楼层 |阅读模式
DR5G17
support 802.11ac/ax, mmcx connector
5G 17dBi panel antenna
1. Feature
* 17dBi Dual Polarized Micro strip  Antenna Array
* 5GHz of frequency
* MMCX connector
* Support 802.3 11AX/AC/AN
* RoHS compliance
2. Application
* 5GHz Wireless Communication
* WLAN device, WLAN Router, e.g., AP, PIC Wireless Card
3. Description
This antenna array is designed for 5GHz applications and can be easily built-in portable devices with MHF processes. It has excellent stability and sensitivity to consistently provide high signal reception efficiency.
BY Wallys Communications (Suzhou) Co LTD
