GD32F103C8T6的AD转换失败问题!!!
1119|0
 楼主| loongerwey 发表于 2022-2-21 13:55 | 显示全部楼层 |阅读模式
void timer2_config(u16 arr,u16 psc)
        timer_parameter_struct timer_initpara;
        timer_deinit(TIMER2);
        rcu_periph_clock_enable(RCU_TIMER2);
        timer_initpara.prescaler         = psc;
        timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
        timer_initpara.counterdirection  = TIMER_COUNTER_UP;
        timer_initpara.period            = arr;
        timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
        timer_initpara.repetitioncounter = 0;
        timer_init(TIMER2, &timer_initpara);
        timer_master_output_trigger_source_select(TIMER2,TIMER_TRI_OUT_SRC_UPDATE);
        timer_auto_reload_shadow_enable(TIMER2);
        timer_enable(TIMER2);
void ADC_Init()
        adc_deinit(ADC0);
        rcu_periph_clock_enable(RCU_ADC0);
        rcu_periph_clock_enable(RCU_GPIOA);
        gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2);
        rcu_adc_clock_config(RCU_CKADC_CKAPB2_DIV8);
        /* ADC scan mode function enable */
        adc_special_function_config(ADC0, ADC_SCAN_MODE, ENABLE);
        adc_special_function_config(ADC0, ADC_CONTINUOUS_MODE, DISABLE);
        /* ADC trigger config */
        adc_external_trigger_source_config(ADC0, ADC_REGULAR_CHANNEL, ADC0_1_EXTTRIG_REGULAR_T2_TRGO);
        /* ADC data alignment config */
        adc_data_alignment_config(ADC0, ADC_DATAALIGN_RIGHT);
        /* configure the ADC sync mode */
        adc_mode_config(ADC_MODE_FREE);
        /* ADC channel length config */
        adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 3);
        /* ADC regular channel config */
        adc_regular_channel_config(ADC0, 0, ADC_CHANNEL_2, ADC_SAMPLETIME_28POINT5);
        adc_regular_channel_config(ADC0, 1, ADC_CHANNEL_1, ADC_SAMPLETIME_28POINT5);
        adc_regular_channel_config(ADC0, 2, ADC_CHANNEL_0, ADC_SAMPLETIME_28POINT5);
        /* ADC external trigger enable */
        adc_external_trigger_config(ADC0, ADC_REGULAR_CHANNEL, ENABLE);
        /* enable ADC interface */
        adc_enable(ADC0);
        delay_1ms(10);
        /* ADC calibration and reset calibration */
        adc_calibration_enable(ADC0);
        /* ADC DMA function enable */
        adc_dma_mode_enable(ADC0);
        adc_software_trigger_enable(ADC0,ADC_REGULAR_CHANNEL);
void dma_config(u32 maddr, u32 paddr,u16 datalength)
        /* ADC_DMA_channel configuration */
        dma_parameter_struct dma_data_parameter;
        rcu_periph_clock_enable(RCU_DMA0);
        /* ADC_DMA_channel deinit */
        dma_deinit(DMA0, DMA_CH0);
        /* initialize DMA single data mode */
        dma_data_parameter.periph_addr  = (uint32_t)paddr;
        dma_data_parameter.periph_inc   = DMA_PERIPH_INCREASE_DISABLE;
        dma_data_parameter.memory_addr  = (uint32_t)(maddr);
        dma_data_parameter.memory_inc   = DMA_MEMORY_INCREASE_ENABLE;
        dma_data_parameter.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;
        dma_data_parameter.memory_width = DMA_MEMORY_WIDTH_16BIT;
        dma_data_parameter.direction    = DMA_PERIPHERAL_TO_MEMORY;
        dma_data_parameter.number       = datalength;
        dma_data_parameter.priority     = DMA_PRIORITY_HIGH;
        dma_init(DMA0, DMA_CH0, &dma_data_parameter);
        dma_interrupt_enable(DMA0, DMA_CH0,DMA_INT_FTF);
        dma_interrupt_flag_clear(DMA0,DMA_CH0,DMA_INT_FLAG_G | DMA_INT_FLAG_FTF | DMA_INT_FLAG_HTF | DMA_INT_FLAG_ERR);
        dma_circulation_enable(DMA0, DMA_CH0);
        /* enable DMA channel */
        dma_channel_enable(DMA0, DMA_CH0);
extern void user_adc_deal_func(void);
void DMA0_Channel0_IRQHandler()
        if(dma_interrupt_flag_get(DMA0,DMA_CH0,DMA_INT_FLAG_FTF) != RESET)
                user_adc_deal_func();
拟采用timer2的更新触发AD进行采样,APB2时钟频率为72MHz,当ADC0的时钟被RCU_CKADC_CKAPB2_DIV6时,DMA不能够转换成功,无法进入DMA中断。当ADC被RCU_CKADC_CKAPB2_DIV8分频时,偶尔芯片复位能够开始转换,有时候芯片板卡复位无法正常转换,大家遇到过这种情况吗???
