Arduino:1.8.12 (Windows 7), 开发板:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200" In file included from c:\users\administrator.sky-20210428oxp\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.0-newlib4.0.0-gnu23-48f7b08\xtensa-lx106-elf\include\c++\10.2.0\cstdlib:41,
from c:\users\administrator.sky-20210428oxp\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.0-newlib4.0.0-gnu23-48f7b08\xtensa-lx106-elf\include\c++\10.2.0\stdlib.h:36,
from C:\Users\Administrator.SKY-20210428OXP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0\cores\esp8266/Arduino.h:27,
from sketch\Blink.ino.cpp:1:
c:\users\administrator.sky-20210428oxp\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.0-newlib4.0.0-gnu23-48f7b08\xtensa-lx106-elf\include\c++\10.2.0\xtensa-lx106-elf\bits\c++config.h:518:10: fatal error: bits/os_defines.h: No such file or directory
518 | #include <bits/os_defines.h>
compilation terminated. exit status 1
为开发板 NodeMCU 1.0 (ESP-12E Module) 编译时出错。 在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
