[技术问答] [USB] NUC240 的 USB 做 HID device, Set Idle 會被 stall
758|1
 楼主| flycamelaaa 发表于 2022-2-25 15:03 | 显示全部楼层 |阅读模式
請教, 我用 NUC240 的 USB 做 HID device, 但是一直在 init 過不了, 是什麼原因呢 ?
Set Idle 會被 stall,
而設定完 ReportDescriptor 後, Endpoint 就被 Reset 掉,
Why ?
    CTL    80 06 00 01  00 00 12 00  GET DESCRIPTOR     11sc
18  IN     12 01 10 01  00 00 00 08  ........          252us
           cd ab 18 51  00 01 01 02  ...Q....
           00 01                     ..
    CTL    80 06 00 02  00 00 09 00  GET DESCRIPTOR     42us
9  IN     09 02 22 00  01 01 00 80  ..".....          953us
           32                        2
    CTL    80 06 00 02  00 00 22 00  GET DESCRIPTOR     37us
34  IN     09 02 22 00  01 01 00 80  ..".....          947us
           32 09 04 03  00 01 03 00  2.......
           00 00 09 21  01 02 00 01  ...!....
           22 1f 00 07  05 81 03 08  ".......
           00 14                     ..
    CTL    00 09 01 00  00 00 00 00  SET CONFIG         51us
    CTL    21 0a 00 00  03 00 00 00  SET IDLE           29ms
    USTS   c0000004                  stall pid         112us
    CTL    81 06 00 22  03 00 5f 00  GET DESCRIPTOR     11us
31  IN     05 8b 09 01  a1 01 09 01  ........          2.1ms
           15 00 25 ff  75 08 95 40  ..%.u..@
           81 02 09 20  15 00 25 ff  ... ..%.
           75 08 95 40  91 02 c0     u..@...
    USTS   c0000004                  stall pid         6.7ms
    USTS   c0000030                  endpoint halted   1.0ms
    RESET                                               16us
    ok                                                 168ms
    RESET                                               16us
yangjiaxu 发表于 2023-8-3 15:01 | 显示全部楼层
端点被复位掉?不是很理解啊
