[PCB] wallys Antenna/DRA2G5G5D001 Dipole antenna 5dbi dual band 2.4GHz 5GHz 802.11ax
760|0
 楼主| wirelesswifi6 发表于 2022-2-28 10:49 | 显示全部楼层 |阅读模式
DRA2G5G5D001
5dBi .Dipole Antenna
2.4GHz/5GHz of frequency
* External type dipole antenna
* 2.4GHz/5GHz of frequency
* SMA Pluginterface
* Plastic rod of black
* RoHS compliance
2. Application
* 2.4GHz/5GHz Wireless Communication
* WLAN device, WLAN Router, e.g., AP, PIC Wireless Card
3. Description
This miniature antenna is designed for 2.4GHz/5GHz applications and can be easily built-in portable devices with MHF processes. It has excellent stability and sensitivity to consistently provide high signal reception efficiency.
    General Data
    Product Name
    5dBi Dual band Dipole Antenna
    Part No.
    DRA2G5G5D001
    Frequency
    2.4~2.5GHz&5.15~5.85GHz
    V.S.W.R
    <2.0
    Gain (dBi)
    2.4GHz@3.0dBi 5GHz@5.0dBi
    Polarization
    Linear,Vertical
    Storage Temp
    -10°C +70°C
    Operating Temperature
    -10°C +60°C
    Impedance with Matching
    50Q
    Weight
    21.5 g
    Antenna Type
    SMAPLUG
    Dimension
    L195X φ 13 (mm)
      wifi6 router
      wifi 6E
      Wi-Fi 6E
      Wi-Fi 6
      WiFi 6
      802.11ax
      802.11ac
      wireless
      QCN9074/QCN9024/QCN9072/QCA9882/QCA9880
      IPQ6010/IPQ6018/IPQ6000/IPQ8072/IPQ5018
      IPQ4029/IPQ4019
      Dipole Antenna
      pannel antenna
      Smart antenna
      omni  antenna
      BY Wallys Communications (Suzhou) Co LTD
      EMAIL:sales@wallystech.com
      WEB:https://www.wallystech.com/
