[STM32F4] 中断向量表长度
969|9
 楼主| wuhany 发表于 2022-3-2 21:00 | 显示全部楼层 |阅读模式
Cortex-M0/M0+/M3/M4/M7中断向量表长度怎么看呢?
午夜粪车 发表于 2022-3-2 21:03 | 显示全部楼层
看内核手册
wyjie 发表于 2022-3-2 21:04 | 显示全部楼层
还有就是看 start_upxxx.s 里面有 DCD 指令?
 楼主| wuhany 发表于 2022-3-2 21:08 | 显示全部楼层
__vector_table
        DCD     sfe(CSTACK)
        DCD     Reset_Handler             ; Reset Handler
        DCD     NMI_Handler               ; NMI Handler
        DCD     HardFault_Handler         ; Hard Fault Handler
        DCD     MemManage_Handler         ; MPU Fault Handler
        DCD     BusFault_Handler          ; Bus Fault Handler
        DCD     UsageFault_Handler        ; Usage Fault Handler
        DCD     0                         ; Reserved
        DCD     0                         ; Reserved
        DCD     0                         ; Reserved
        DCD     0                         ; Reserved
        DCD     SVC_Handler               ; SVCall Handler
        DCD     DebugMon_Handler          ; Debug Monitor Handler
        DCD     0                         ; Reserved
        DCD     PendSV_Handler            ; PendSV Handler
        DCD     SysTick_Handler           ; SysTick Handler
         ; External Interrupts
        DCD     WWDG_IRQHandler                   ; Window WatchDog
        DCD     PVD_IRQHandler                    ; PVD through EXTI Line detection
        DCD     TAMP_STAMP_IRQHandler             ; Tamper and TimeStamps through the EXTI line
        DCD     RTC_WKUP_IRQHandler               ; RTC Wakeup through the EXTI line
        DCD     FLASH_IRQHandler                  ; FLASH
        DCD     RCC_IRQHandler                    ; RCC
        DCD     EXTI0_IRQHandler                  ; EXTI Line0
        DCD     EXTI1_IRQHandler                  ; EXTI Line1
        DCD     EXTI2_IRQHandler                  ; EXTI Line2
        DCD     EXTI3_IRQHandler                  ; EXTI Line3
        DCD     EXTI4_IRQHandler                  ; EXTI Line4
        DCD     DMA1_Stream0_IRQHandler           ; DMA1 Stream 0
        DCD     DMA1_Stream1_IRQHandler           ; DMA1 Stream 1
        DCD     DMA1_Stream2_IRQHandler           ; DMA1 Stream 2
        DCD     DMA1_Stream3_IRQHandler           ; DMA1 Stream 3
        DCD     DMA1_Stream4_IRQHandler           ; DMA1 Stream 4
        DCD     DMA1_Stream5_IRQHandler           ; DMA1 Stream 5
        DCD     DMA1_Stream6_IRQHandler           ; DMA1 Stream 6
        DCD     ADC_IRQHandler                    ; ADC1, ADC2 and ADC3s
        DCD     CAN1_TX_IRQHandler                ; CAN1 TX
        DCD     CAN1_RX0_IRQHandler               ; CAN1 RX0
        DCD     CAN1_RX1_IRQHandler               ; CAN1 RX1
        DCD     CAN1_SCE_IRQHandler               ; CAN1 SCE
        DCD     EXTI9_5_IRQHandler                ; External Line[9:5]s
        DCD     TIM1_BRK_TIM9_IRQHandler          ; TIM1 Break and TIM9
        DCD     TIM1_UP_TIM10_IRQHandler          ; TIM1 Update and TIM10
        DCD     TIM1_TRG_COM_TIM11_IRQHandler     ; TIM1 Trigger and Commutation and TIM11
        DCD     TIM1_CC_IRQHandler                ; TIM1 Capture Compare
        DCD     TIM2_IRQHandler                   ; TIM2
        DCD     TIM3_IRQHandler                   ; TIM3
        DCD     TIM4_IRQHandler                   ; TIM4
        DCD     I2C1_EV_IRQHandler                ; I2C1 Event
        DCD     I2C1_ER_IRQHandler                ; I2C1 Error
        DCD     I2C2_EV_IRQHandler                ; I2C2 Event
        DCD     I2C2_ER_IRQHandler                ; I2C2 Error
        DCD     SPI1_IRQHandler                   ; SPI1
        DCD     SPI2_IRQHandler                   ; SPI2
        DCD     USART1_IRQHandler                 ; USART1
        DCD     USART2_IRQHandler                 ; USART2
        DCD     USART3_IRQHandler                 ; USART3
        DCD     EXTI15_10_IRQHandler              ; External Line[15:10]s
        DCD     RTC_Alarm_IRQHandler              ; RTC Alarm (A and B) through EXTI Line
        DCD     OTG_FS_WKUP_IRQHandler            ; USB OTG FS Wakeup through EXTI line
        DCD     TIM8_BRK_TIM12_IRQHandler         ; TIM8 Break and TIM12
        DCD     TIM8_UP_TIM13_IRQHandler          ; TIM8 Update and TIM13
        DCD     TIM8_TRG_COM_TIM14_IRQHandler     ; TIM8 Trigger and Commutation and TIM14
        DCD     TIM8_CC_IRQHandler                ; TIM8 Capture Compare
        DCD     DMA1_Stream7_IRQHandler           ; DMA1 Stream7
        DCD     FSMC_IRQHandler                   ; FSMC
        DCD     SDIO_IRQHandler                   ; SDIO
        DCD     TIM5_IRQHandler                   ; TIM5
        DCD     SPI3_IRQHandler                   ; SPI3
        DCD     UART4_IRQHandler                  ; UART4
        DCD     UART5_IRQHandler                  ; UART5
        DCD     TIM6_DAC_IRQHandler               ; TIM6 and DAC1&2 underrun errors
        DCD     TIM7_IRQHandler                   ; TIM7
        DCD     DMA2_Stream0_IRQHandler           ; DMA2 Stream 0
        DCD     DMA2_Stream1_IRQHandler           ; DMA2 Stream 1
        DCD     DMA2_Stream2_IRQHandler           ; DMA2 Stream 2
        DCD     DMA2_Stream3_IRQHandler           ; DMA2 Stream 3
        DCD     DMA2_Stream4_IRQHandler           ; DMA2 Stream 4
        DCD     ETH_IRQHandler                    ; Ethernet
        DCD     ETH_WKUP_IRQHandler               ; Ethernet Wakeup through EXTI line
        DCD     CAN2_TX_IRQHandler                ; CAN2 TX
        DCD     CAN2_RX0_IRQHandler               ; CAN2 RX0
        DCD     CAN2_RX1_IRQHandler               ; CAN2 RX1
        DCD     CAN2_SCE_IRQHandler               ; CAN2 SCE
        DCD     OTG_FS_IRQHandler                 ; USB OTG FS
        DCD     DMA2_Stream5_IRQHandler           ; DMA2 Stream 5
        DCD     DMA2_Stream6_IRQHandler           ; DMA2 Stream 6
        DCD     DMA2_Stream7_IRQHandler           ; DMA2 Stream 7
        DCD     USART6_IRQHandler                 ; USART6
        DCD     I2C3_EV_IRQHandler                ; I2C3 event
        DCD     I2C3_ER_IRQHandler                ; I2C3 error
        DCD     OTG_HS_EP1_OUT_IRQHandler         ; USB OTG HS End Point 1 Out
        DCD     OTG_HS_EP1_IN_IRQHandler          ; USB OTG HS End Point 1 In
        DCD     OTG_HS_WKUP_IRQHandler            ; USB OTG HS Wakeup through EXTI
        DCD     OTG_HS_IRQHandler                 ; USB OTG HS
        DCD     DCMI_IRQHandler                   ; DCMI
        DCD     0                                 ; Reserved
        DCD     HASH_RNG_IRQHandler               ; Hash and RNG
        DCD     FPU_IRQHandler                    ; FPU
上面是 STM32F407 的中断向量共98个;
那么 CM4 中断向量表就是98 ??
songqian17 发表于 2022-3-2 21:10 | 显示全部楼层
这也看不懂啊
renyaq 发表于 2022-3-2 21:12 | 显示全部楼层
STM32各个系列的中断向量表 在各个系列的参考手册里有介绍
huangchui 发表于 2022-3-2 21:15 | 显示全部楼层
比如以32f4部分系列为例:Table 61. Vector table for STM32F405xx/07xx and STM32F415xx/17xx
zhanghqi 发表于 2022-3-2 21:18 | 显示全部楼层
这个表格是基于内核对中断矢量表的约定,除了少部分中断矢量外,各个芯片制造商可以自行灵活填写向量表中各个中断矢量对应的中断事件。
dengdc 发表于 2022-3-2 21:20 | 显示全部楼层
 楼主| wuhany 发表于 2022-3-2 21:23 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家
