DR40x9
IPQ4019 IPQ4029 ,802.11AC 2x2 2.4G&5G Support all the modules of Quectel
IPQ4019/IPQ4029 2x2 2.4Ghz&5G Support HTTPS
Featuring with industrial-grade IPQ4019/IPQ4029 chipset Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module Support 4.940GHz to 5.825GHz Frequency Range Support 2.400GHz to 2.482GHz Support 2 x 5G MMCX Connectors and 2x2.4G MMCX Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth Support 11ABGN/AC Support fixed data rate RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals Our Firmware supports all the modules of Quectel
Parameter | Rating | Unit | Supply Voltage | 24V~48 | V | Operating Temperature Range | -40 to +70 | ºC | Storage Temperature Range | -45 to +105 | ºC | Operating Humidity Range | 5 to +95 (non-condensing) | % | Storage Humidity Range | 0 to +90 (non-condensing) | % |
Symbol | Parameter | CPU | IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz) | Antenna Connector | 2 x 5G MMCX connectors;2x2.4G MMCX | 10/100/1000Mbps Gigabit Ethernet | 2xRJ45 | SFP connector | 1xSFP fiber module connector (optional) | 3G/4G connector | 1xminipcie 3G/4G connector support with two sim card | USB connector | 1xUSB 3.0 connector | POE | 24V~48V passive POE | DC Jack | 24V~48V power supply | ROHS Compliance | YES | Dimension | 115mm x 105mm x 16mm | Max Power | 48.1V x 0.180A= 8.658W | Nor Flash | 2MB~32MB | Nand Flash | 128MB | DDR | 256MB~512MB |
| | Radio TX Specifications(5180MHz-5825MHz) |
Operating Mode | Data Rate | Power | Tolerance | 1 Chain | 2 Chains | 802.11a | 6 Mbps | 27dBm | 30dbm | ±2dB | 54 Mbps | 23dBm | 26dbm | ±2dB | 802.11n HT20 | MCS0, MCS8 | 26dBm | 29dbm | ±2dB | MCS7, MCS15 | 22dBm | 25dbm | ±2dB | 802.11n HT40 | MCS0, MCS8 | 25dBm | 28dbm | ±2dB | MCS7, MCS15 | 21dBm | 24dbm | ±2dB | 802.11ac | MCS0, MCS10,MCS20 | 25dBm | 28dbm | ±2dB | MCS9,MCS19,MCS29 | 19dBm | 22dbm | ±2dB |
| | Radio RX Specifications(5180MHz-5825MHz)
Operating Mode | Data Rate | Sensitivity | 802.11a | 6 Mbps | -96dBm | 54 Mbps | -78dBm | 802.11n HT20 | MCS0, MCS8 | -93dBm | MCS7, MCS15 | -73dBm | 802.11n HT40 | MCS0, MCS8 | -90dBm | MCS7, MCS15 | -70dBm | 802.11AC HT40 | MCS0, MCS10,MCS20 | -90dBm | MCS9,MCS19,MCS29 | -67dBm | 802.11AC HT80 | MCS0, MCS10,MCS20 | -88dBm | MCS9,MCS19,MCS29 | -62dBm |
