脱机ISP
988|18
wangpe|  楼主 | 2022-3-4 19:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
原来用来做生产用的,脱机ISP。
后面工人反映说,烧不了。给我看,我拿回来插上电脑,竟然一点反应都没有
zwll| | 2022-3-4 19:04 | 只看该作者
还有什么现象?能再详细描述下吗?
wangpe|  楼主 | 2022-3-4 19:07 | 只看该作者
灯也不亮
chenho| | 2022-3-4 19:10 | 只看该作者
电脑设备管理器里面呢?
wangpe|  楼主 | 2022-3-4 19:12 | 只看该作者
电脑设备管理器里面也没有什么反应。
jlyuan| | 2022-3-4 19:14 | 只看该作者
固件升级?
juventus9554| | 2022-3-4 19:17 | 只看该作者
以我的经验如果换台电脑试试还是没任何反映,估计要给厂家维修了。
dengdc| | 2022-3-4 19:19 | 只看该作者
那没办法了。。
zhanghqi| | 2022-3-4 19:21 | 只看该作者
如楼主所说的现象,应该是ISP 工具坏了,可以联系厂家维修。
jiaxw| | 2022-3-4 19:23 | 只看该作者
应该是工具有问题了
午夜粪车| | 2022-3-4 19:29 | 只看该作者
这种时间久了厂家管吗?关键可能是淘宝之类的买到的、
zhaoxqi| | 2022-3-4 19:29 | 只看该作者
SSD1351 display driver library[size=1.4]The SSD1351 display controller is supported by the RAMTEX SSD1339 display driver library package.
Full GUI display driver C source code. Processor and C compiler independent.
[size=1.3]Graphic library for SSD1351
SSD1351 display controller characteristics
Below is a brief introduction to the main characteristics for the SSD1351 RGBdisplay controller (seen from a software driver design viewpoint).
For information about the SSD1351 driver software support please go to the library description.
SSD1351 device type
COG RGB color display controller for use in small embedded systems with on-chip frame buffer and OLED screen driver .
The SSD1351 supports OLED screens with a size up to 128 x 128 pixels (WxH)
On-chip OLED driver with voltage generator and software controlled intensity regulation.
Frame buffer
RGB pixel resolution (bits per pixel): 16-bit, 18-bit.
SSD1351 frame buffer organization: 128 RGB pixels on scan line, 128 lines.
Processor interfaces on SSD1351
SSD1351 parallel bus interface
Parallel bus types: 8080 bus type and 6800 bus type
Parallel bus size: 8-bit, 16-bit, 18 (32)-bit.
Addressing concept: Indexed bus interface (1 chip select pin + 1 address bit pin (Data/Command))
Serial bus interfaces on SSD1351
SPI bus: 4-wire: /CS, DC, SDIN, SCLK
SPI bus: 3-wire: /CS, SDIN, SCLK
In SPI bus there is no read-back of frame buffer memory
The bus interfaces are all supported by the SSD1351 display driver software package.
Special SSD1351 hardware features:
0-180 degree frame buffer rotation with hardware support
Support for screen driver intensity (contrast) requlation in hardware.
Full driver software support.
wangpe|  楼主 | 2022-3-4 19:31 | 只看该作者
嗯,预料中的结果,多谢大家啦
tpgf| | 2022-4-3 15:34 | 只看该作者
是不是升级了啊
drer| | 2022-4-3 15:50 | 只看该作者
没有用过脱机isp啊
qcliu| | 2022-4-3 15:57 | 只看该作者
电路板换批次了吗
coshi| | 2022-4-3 16:05 | 只看该作者
是不是烧写器烧掉了啊
kxsi| | 2022-4-3 16:13 | 只看该作者
打开看看里边电路还完好吗
wiba| | 2022-4-3 16:21 | 只看该作者
查到主机后边的试试看
