- void I2cInit(void)
- gpio_init_type gpio_init_structure;
- /* i2c periph clock enable */
- crm_periph_clock_enable(CRM_I2C1_PERIPH_CLOCK, TRUE);
- crm_periph_clock_enable(CRM_GPIOB_PERIPH_CLOCK, TRUE);
- /* gpio configuration */
- gpio_pin_mux_config(GPIOB, GPIO_PINS_SOURCE6, GPIO_MUX_1);
- gpio_pin_mux_config(GPIOB, GPIO_PINS_SOURCE7, GPIO_MUX_1);
- /* configure i2c pins: scl */
- gpio_init_structure.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
- gpio_init_structure.gpio_mode = GPIO_MODE_MUX;
- gpio_init_structure.gpio_out_type = GPIO_OUTPUT_OPEN_DRAIN;
- gpio_init_structure.gpio_pull = GPIO_PULL_UP;
- gpio_init_structure.gpio_pins = GPIO_PINS_6;
- gpio_init(GPIOB, &gpio_init_structure);
- /* configure i2c pins: sda */
- gpio_init_structure.gpio_pins = GPIO_PINS_7;
- /* reset i2c peripheral */
- i2c_reset(I2C1);
- /* config i2c */
- i2c_init(I2C1, 0, 0x80E03030); //0x80E06565 0x80E03030
- i2c_own_address1_set(I2C1, I2C_ADDRESS_MODE_7BIT, I2C_OWN_ADDRESS7);
- /* i2c peripheral enable */
- i2c_enable(I2C1, TRUE);
(2)I2C写
分写命令和写数据。
- void OledWriteCmd(uint8_t var)
- /* wait for the busy falg to be reset */
- while(i2c_flag_get(I2C1, I2C_BUSYF_FLAG) );
- /* start transfer */
- i2c_transmit_set(I2C1, I2C_SLAVE_ADDRESS7, 2, I2C_AUTO_STOP_MODE, I2C_GEN_START_WRITE);
- while(!i2c_flag_get(I2C1, I2C_TDIS_FLAG) );
- i2c_data_send(I2C1, 0x00);
- i2c_data_send(I2C1, var);
- while(!i2c_flag_get(I2C1, I2C_STOPF_FLAG) );
- i2c_flag_clear(I2C1, I2C_STOPF_FLAG);
- void OledWriteData(uint8_t var)
- i2c_data_send(I2C1, 0x40);
(3)OLED相关驱动
- //坐标设置:也就是在哪里显示
- void OledSetPos(uint8_t x, uint8_t y)
- //以下3个寄存器只在页寻址的模式下有效
- SSD1306_WriteCmd(0xb0+y); //页地址设置 0xb0~0xb7
- SSD1306_WriteCmd(((x&0xf0)>>4)|0x10); //列高位地址设置
- SSD1306_WriteCmd((x&0x0f)); //列低位地址设置
- //开启Oled显示
- void OledDisplayOn(void)
- SSD1306_WriteCmd(0X8D); //SET DCDC命令
- SSD1306_WriteCmd(0X14); //DCDC ON
- SSD1306_WriteCmd(0XAF); //DISPLAY ON
- //关闭Oled显示
- void OledDisplayOff(void)
- SSD1306_WriteCmd(0X10); //DCDC OFF
- SSD1306_WriteCmd(0XAE); //DISPLAY OFF
- //清屏函数,清完屏,整个屏幕是黑色的!和没点亮一样
- void OledClear(void)
- uint8_t i,n;
- for(i=0;i<8;i++)
- SSD1306_WriteCmd (0xb0+i); //设置页地址(0~7)
- SSD1306_WriteCmd (0x00); //设置显示位置—列低地址
- SSD1306_WriteCmd (0x10); //设置显示位置—列高地址
- for(n=0;n<128;n++)
- SSD1306_WriteData(0);
- } //更新显示
- //在指定位置显示一个字符,包括部分字符
- //x:0~127,y:0~7
- //Char_Size:选择字体 16/12
- void OledShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
- uint8_t c=0,i=0;
- c=chr-' ';//得到偏移后的值
- if(x>MAX_COLUMN-1)
- x=0;
- y=y+2;
- if(Char_Size ==16)
- OledSetPos(x,y);
- for(i=0;i<8;i++)
- SSD1306_WriteData(F8X16[c*16+i]);//先写上半部分
- OledSetPos(x,y+1);
- for(i=0;i<8;i++)
- SSD1306_WriteData(F8X16[c*16+i+8]);//后写下半部分
- else
- OledSetPos(x,y);
- for(i=0;i<6;i++)
- SSD1306_WriteData(F6x8[c][i]);
- //显示一个字符串
- void OledShowString(uint8_t x,uint8_t y,char *str,uint8_t Char_Size)
- unsigned char j=0;
- while (str[j]!='\0')
- OledShowChar(x,y,str[j],Char_Size);
- x+=8;
- if(x>120)
- x=0;
- y+=2;
- j++;//移动一次就是一个page,取值0-7
- //显示汉字
- //由于汉字是16*16大小的,所以最多显示4行汉字
- //index:在汉字取模中的索引
- void OledShowCN(uint8_t x,uint8_t y,uint8_t index)
- uint8_t t;
- OledSetPos(x,y);
- for(t=0;t<16;t++)
- SSD1306_WriteData(Hzk[index][t]);
- for(t=0;t<16;t++)
- SSD1306_WriteData(Hzk[index][t+16]);
(4)OLED初始化
- void OledInit(void)
- delay_ms(300);
- delay_ms(300);
- //SSD1306复位之后,默认的是页寻址方式
- SSD1306_WriteCmd(0xAE);//--display off
- SSD1306_WriteCmd(0x00);//--set low column address
- SSD1306_WriteCmd(0x10);//--set high column address
- SSD1306_WriteCmd(0x40);//--set start line address
- SSD1306_WriteCmd(0xB0);//--set page address
- SSD1306_WriteCmd(0x81);// contract control
- SSD1306_WriteCmd(0xFF);//--128
- SSD1306_WriteCmd(0xA1);//set segment re-map 0 to 127
- SSD1306_WriteCmd(0xA6);//set normal display
- SSD1306_WriteCmd(0xA8);//set multiplex ratio(1 to 64)
- SSD1306_WriteCmd(0x3F);//--1/32 duty
- SSD1306_WriteCmd(0xC8);//Com scan direction
- SSD1306_WriteCmd(0xD3);//set display offset
- SSD1306_WriteCmd(0x00);//no offset
- SSD1306_WriteCmd(0xD5);//set display clock divide ratio/oscillator frequency
- SSD1306_WriteCmd(0x80);//
- SSD1306_WriteCmd(0xD8);//set area color mode off
- SSD1306_WriteCmd(0x05);//
- SSD1306_WriteCmd(0xD9);//Set Pre-Charge Period
- SSD1306_WriteCmd(0xF1);//
- SSD1306_WriteCmd(0xDA);//set com pin hardware configuartion
- SSD1306_WriteCmd(0x12);//
- SSD1306_WriteCmd(0xDB);//set Vcomh
- SSD1306_WriteCmd(0x30);//0x20,0.77xVcc
- SSD1306_WriteCmd(0x8D);//set charge pump enable
- SSD1306_WriteCmd(0x14);//
- SSD1306_WriteCmd(0xAF);//--turn on Oled panel
(5)显示测试
- void OledDisplayTest(void)
- I2cInit();
- OledInit();
- OledClear();
- OledShowString(48,0,(char *)("21ic"),16);
- OledShowCN(40,2,4);
- OledShowCN(56,2,5);
- OledShowCN(72,2,6);
- OledShowString(40,4,(char *)("2022"),16);
- OledShowCN(24,6,0);
- OledShowCN(40,6,1);
- OledShowCN(56,6,2);
- OledShowCN(72,6,3);
5、现象
