STM32 F4 MCU 配置SBSFU的加密模式升级程序怎么配置调整参数
1257|0
 楼主| 昱枫 发表于 2022-3-8 15:09 | 显示全部楼层 |阅读模式
[tr=transparent][td]
/ swap region (128 kbytes) / //#define REGION_SWAP_START 0x08020000 //#define REGION_SWAP_END 0x0803FFFF
define REGION_SWAP_START (EXTERNAL_FLASH_ADDRESS + 0x300000)define REGION_SWAP_END (REGION_SWAP_START + FWIMG_SIZE - 1)
/ slot 0 region (128 kbytes) 128+64=192KB /
define REGION_SLOT_0_START 0x08020000define REGION_SLOT_0_END (REGION_SLOT_0_START + FWIMG_SIZE - 1) //0x0804FFFF
/ slot 1 region (128 kbytes) /
define REGION_SLOT_1_START (REGION_SLOT_0_END + 1)//0x08050000define REGION_SLOT_1_END (REGION_SLOT_1_START + FWIMG_SIZE - 1)//0x0807FFFF
之前配置交换分区SWAP,slot0, slot1 都是0x20000 byte大小,目前由于应用程序变大,想通过调整slot0, slot1的空间大小,缩小SWAP的空间,来实现支持较大应用程序存储,看文档说明SWAP可以多次交换,只要是几次能过完整包升级程序更新过来就可以了,但目前看存储参数对其这块还是不好分配,不能按照我在想的这样,SWAP 50K ,slot0 150K , slot1 150K 这样,想知道这块可以调整改变么,保证slot0 slot1 稍微大些,
= [SBOOT] System Security Check successfully passed. Starting... = [FWIMG] Slot #0 @: 802c000 / Slot #1 @: 8050000 / Swap @: 8020000 = [FWIMG] slot 0 (802c000) is not properly aligned: please tune your settingsFWIMG INIT COMPLETED ...
[/td][/tr]
