GD32F103VET6移植STM的API,引脚操作比GD的API慢
1541|1
 楼主| BHFCHARGE 发表于 2022-3-15 13:09 | 显示全部楼层 |阅读模式
按要求修改了flash启动时间,时钟频率为72MHZ,分频方式也是按照GD库的分频强制分的72MHZ,但就是GUI刷屏显示明显慢,但使用GD的API则正常。对比过RCC配置寄存器及引脚配置寄存器,配置的内容是一样的
 楼主| BHFCHARGE 发表于 2022-3-15 13:11 | 显示全部楼层
void RCC_Config(void)
        ErrorStatus HSEStartUpStatus;
        /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration -----------------------------*/
        /* RCC system reset(for debug purpose) */
        RCC_DeInit();
        /* Enable HSE */
        RCC_HSEConfig(RCC_HSE_ON);
        /* Wait till HSE is ready */
        HSEStartUpStatus = RCC_WaitForHSEStartUp();
        if(HSEStartUpStatus == SUCCESS)
                /* Enable Prefetch Buffer */
                FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
                /* Flash 2 wait state */
                FLASH_SetLatency(FLASH_Latency_2);
                /* HCLK = SYSCLK */
                RCC_HCLKConfig(RCC_SYSCLK_Div1);
                /* PCLK2 = HCLK */
                RCC_PCLK2Config(RCC_HCLK_Div1);
                /* PCLK1 = HCLK/4 */
                RCC_PCLK1Config(RCC_HCLK_Div2);
                /* PLLCLK = 8MHz * 9 = 72 MHz */
                RCC_PLLConfig(RCC_PLLSource_HSE_Div2, RCC_PLLMul_9);
                /* Enable PLL */
                RCC_PLLCmd(ENABLE);
                /* Wait till PLL is ready */
                while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
                /* Select PLL as system clock source */
                RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
                /* Wait till PLL is used as system clock source */
                while(RCC_GetSYSCLKSource() != 0x08)
void RCC_PLLConfig(u32 RCC_PLLSource, u32 RCC_PLLMul)
  u32 tmpreg = 0;
  /* Check the parameters */
  assert_param(IS_RCC_PLL_SOURCE(RCC_PLLSource));
  assert_param(IS_RCC_PLL_MUL(RCC_PLLMul));
  tmpreg = RCC->CFGR;
  /* Clear PLLSRC, PLLXTPRE and PLLMUL[3:0] bits */
  tmpreg &= CFGR_PLL_Mask;
  /* Set the PLL configuration bits */
  tmpreg |= RCC_PLLSource |  0X08070000;//RCC_PLLMul;// 0X08070000;//;
  /* Store the new value */
  RCC->CFGR = tmpreg;
