[活动专区] 【AT-START-F425测评】驱动中景园1.8寸TFT LCD测试
1154|0
 楼主| abner_ma 发表于 2022-3-17 22:17 | 显示全部楼层 |阅读模式
      买到一块中景园的彩屏,1.8寸TFT LCD SPI TFT彩屏st7735驱动128x160,拿出来驱动一下。正直抗疫时期,向发一下抗疫有关的题材。屏的原理图如下:
接口的定义:
1 GND
Ground of Logic Circuit
This is a ground pin. It acts as a reference for the logic pins. It must be connected to external ground
2 VCC
Power Supply for Logic This is a voltage supply pin. It must be connected to external source
3 SCL The serial clock input
4 SDA The serial data input
5 RES Power Reset for Controller and Driver
This pin is reset signal input. When the pin is low, initialization of the chip is executed. Keep this pin pull high during normal operation
6 DC Data/Command Control
This pin is Data/Command control pin. When the pin is pulled high,the input at SDA is treated as display data. When the pin is pulled low, the input at SDA will be transferred to the command register.
7 CS Chip Select
This pin is the chip select input. The chip is enabled for MCU communication only when CS# is pulled low.
8 BL Backlight control pin
When the pin is pulled high turn on backlight, When the pin is pulled low turn off backlig
SPI时序
对于这种小屏,SPI和模拟,对于AT425主频:96 MHz工作频率,也是高速刷屏了。相差不大。先上效果图:图片显示+汉子。
图片16位真彩,占ROM太大了。MAP文件分析:几乎快把64KB占满了。
    Total RO  Size (Code + RO Data)                40944 (  39.98kB)
    Total RW  Size (RW Data + ZI Data)              1688 (   1.65kB)
    Total ROM Size (Code + RO Data + RW Data)      40996 (  40.04kB)
   汉子取模
关键代码:跟ST的库函数是兼容的。
  1. <blockquote>#define OLED_PORT_IS  <span style="white-space:pre">        </span>(GPIO_PINS_2|GPIO_PINS_3|GPIO_PINS_4|GPIO_PINS_5|GPIO_PINS_6|GPIO_PINS_7)
ST7735驱动
  1. #include "lcd.h"
  2. #include "lcd_init.h"
  3. #include "lcdfont.h"
  4. /******************************************************************************
  5.       函数说明:在指定区域填充颜色
  6.       入口数据:xsta,ysta   起始坐标
  7.                 xend,yend   终止坐标
  8.        color       要填充的颜色
  9.       返回值:  无
  10. ******************************************************************************/
  11. void LCD_Fill(u16 xsta,u16 ysta,u16 xend,u16 yend,u16 color)
  12. {
  13.         u16 i,j;
  14.         LCD_Address_Set(xsta,ysta,xend-1,yend-1);//设置显示范围
  15.         for(i=ysta;i<yend;i++)
  16.         {
  17.                 for(j=xsta;j<xend;j++)
  18.                 {
  19.                         LCD_WR_DATA(color);
  20.                 }
  21.         }
  22. }
  23. /******************************************************************************
  24.       函数说明:在指定位置画点
  25.       入口数据:x,y 画点坐标
  26.                 color 点的颜色
  27.       返回值:  无
  28. ******************************************************************************/
  29. void LCD_DrawPoint(u16 x,u16 y,u16 color)
  30. {
  31.         LCD_Address_Set(x,y,x,y);//设置光标位置
  32.         LCD_WR_DATA(color);
  33. }
  34. /******************************************************************************
  35.       函数说明:画线
  36.       入口数据:x1,y1   起始坐标
  37.                 x2,y2   终止坐标
  38.                 color   线的颜色
  39.       返回值:  无
  40. ******************************************************************************/
  41. void LCD_DrawLine(u16 x1,u16 y1,u16 x2,u16 y2,u16 color)
  42. {
  43.         u16 t;
  44.         int xerr=0,yerr=0,delta_x,delta_y,distance;
  45.         int incx,incy,uRow,uCol;
  46.         delta_x=x2-x1; //计算坐标增量
  47.         delta_y=y2-y1;
  48.         uRow=x1;//画线起点坐标
  49.         uCol=y1;
  50.         if(delta_x>0)incx=1; //设置单步方向
  51.         else if (delta_x==0)incx=0;//垂直线
  52.         else {incx=-1;delta_x=-delta_x;}
  53.         if(delta_y>0)incy=1;
  54.         else if (delta_y==0)incy=0;//水平线
  55.         else {incy=-1;delta_y=-delta_y;}
  56.         if(delta_x>delta_y)distance=delta_x; //选取基本增量坐标轴
  57.         else distance=delta_y;
  58.         for(t=0;t<distance+1;t++)
  59.         {
  60.                 LCD_DrawPoint(uRow,uCol,color);//画点
  61.                 xerr+=delta_x;
  62.                 yerr+=delta_y;
  63.                 if(xerr>distance)
  64.                 {
  65.                         xerr-=distance;
  66.                         uRow+=incx;
  67.                 }
  68.                 if(yerr>distance)
  69.                 {
  70.                         yerr-=distance;
  71.                         uCol+=incy;
  72.                 }
  73.         }
  74. }
  75. /******************************************************************************
  76.       函数说明:画矩形
  77.       入口数据:x1,y1   起始坐标
  78.                 x2,y2   终止坐标
  79.                 color   矩形的颜色
  80.       返回值:  无
  81. ******************************************************************************/
  82. void LCD_DrawRectangle(u16 x1, u16 y1, u16 x2, u16 y2,u16 color)
  83. {
  84.         LCD_DrawLine(x1,y1,x2,y1,color);
  85.         LCD_DrawLine(x1,y1,x1,y2,color);
  86.         LCD_DrawLine(x1,y2,x2,y2,color);
  87.         LCD_DrawLine(x2,y1,x2,y2,color);
  88. }
  89. /******************************************************************************
  90.       函数说明:画圆
  91.       入口数据:x0,y0   圆心坐标
  92.                 r       半径
  93.                 color   圆的颜色
  94.       返回值:  无
  95. ******************************************************************************/
  96. void Draw_Circle(u16 x0,u16 y0,u8 r,u16 color)
  97. {
  98.         int a,b;
  99.         a=0;b=r;
  100.         while(a<=b)
  101.         {
  102.                 LCD_DrawPoint(x0-b,y0-a,color);             //3
  103.                 LCD_DrawPoint(x0+b,y0-a,color);             //0
  104.                 LCD_DrawPoint(x0-a,y0+b,color);             //1
  105.                 LCD_DrawPoint(x0-a,y0-b,color);             //2
  106.                 LCD_DrawPoint(x0+b,y0+a,color);             //4
  107.                 LCD_DrawPoint(x0+a,y0-b,color);             //5
  108.                 LCD_DrawPoint(x0+a,y0+b,color);             //6
  109.                 LCD_DrawPoint(x0-b,y0+a,color);             //7
  110.                 a++;
  111.                 if((a*a+b*b)>(r*r))//判断要画的点是否过远
  112.                 {
  113.                         b--;
  114.                 }
  115.         }
  116. }
  117. /******************************************************************************
  118.       函数说明:显示汉字串
  119.       入口数据:x,y显示坐标
  120.                 *s 要显示的汉字串
  121.                 fc 字的颜色
  122.                 bc 字的背景色
  123.                 sizey 字号 可选 16 24 32
  124.                 mode:  0非叠加模式  1叠加模式
  125.       返回值:  无
  126. ******************************************************************************/
  127. void LCD_ShowChinese(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
  128. {
  129.         while(*s!=0)
  130.         {
  131.                 if(sizey==12) LCD_ShowChinese12x12(x,y,s,fc,bc,sizey,mode);
  132.                 else if(sizey==16) LCD_ShowChinese16x16(x,y,s,fc,bc,sizey,mode);
  133.                 else if(sizey==24) LCD_ShowChinese24x24(x,y,s,fc,bc,sizey,mode);
  134.                 else if(sizey==32) LCD_ShowChinese32x32(x,y,s,fc,bc,sizey,mode);
  135.                 else return;
  136.                 s+=2;
  137.                 x+=sizey;
  138.         }
  139. }
  140. /******************************************************************************
  141.       函数说明:显示单个12x12汉字
  142.       入口数据:x,y显示坐标
  143.                 *s 要显示的汉字
  144.                 fc 字的颜色
  145.                 bc 字的背景色
  146.                 sizey 字号
  147.                 mode:  0非叠加模式  1叠加模式
  148.       返回值:  无
  149. ******************************************************************************/
  150. void LCD_ShowChinese12x12(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
  151. {
  152.         u8 i,j,m=0;
  153.         u16 k;
  154.         u16 HZnum;//汉字数目
  155.         u16 TypefaceNum;//一个字符所占字节大小
  156.         u16 x0=x;
  157.         TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
  158.
  159.         HZnum=sizeof(tfont12)/sizeof(typFNT_GB12);        //统计汉字数目
  160.         for(k=0;k<HZnum;k++)
  161.         {
  162.                 if((tfont12[k].Index[0]==*(s))&&(tfont12[k].Index[1]==*(s+1)))
  163.                 {
  164.                         LCD_Address_Set(x,y,x+sizey-1,y+sizey-1);
  165.                         for(i=0;i<TypefaceNum;i++)
  166.                         {
  167.                                 for(j=0;j<8;j++)
  168.                                 {
  169.                                         if(!mode)//非叠加方式
  170.                                         {
  171.                                                 if(tfont12[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
  172.                                                 else LCD_WR_DATA(bc);
  173.                                                 m++;
  174.                                                 if(m%sizey==0)
  175.                                                 {
  176.                                                         m=0;
  177.                                                         break;
  178.                                                 }
  179.                                         }
  180.                                         else//叠加方式
  181.                                         {
  182.                                                 if(tfont12[k].Msk[i]&(0x01<<j))        LCD_DrawPoint(x,y,fc);//画一个点
  183.                                                 x++;
  184.                                                 if((x-x0)==sizey)
  185.                                                 {
  186.                                                         x=x0;
  187.                                                         y++;
  188.                                                         break;
  189.                                                 }
  190.                                         }
  191.                                 }
  192.                         }
  193.                 }
  194.                 continue;  //查找到对应点阵字库立即退出,防止多个汉字重复取模带来影响
  195.         }
  196. }
  197. /******************************************************************************
  198.       函数说明:显示单个16x16汉字
  199.       入口数据:x,y显示坐标
  200.                 *s 要显示的汉字
  201.                 fc 字的颜色
  202.                 bc 字的背景色
  203.                 sizey 字号
  204.                 mode:  0非叠加模式  1叠加模式
  205.       返回值:  无
  206. ******************************************************************************/
  207. void LCD_ShowChinese16x16(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
  208. {
  209.         u8 i,j,m=0;
  210.         u16 k;
  211.         u16 HZnum;//汉字数目
  212.         u16 TypefaceNum;//一个字符所占字节大小
  213.         u16 x0=x;
  214.   TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
  215.         HZnum=sizeof(tfont16)/sizeof(typFNT_GB16);        //统计汉字数目
  216.         for(k=0;k<HZnum;k++)
  217.         {
  218.                 if ((tfont16[k].Index[0]==*(s))&&(tfont16[k].Index[1]==*(s+1)))
  219.                 {
  220.                         LCD_Address_Set(x,y,x+sizey-1,y+sizey-1);
  221.                         for(i=0;i<TypefaceNum;i++)
  222.                         {
  223.                                 for(j=0;j<8;j++)
  224.                                 {
  225.                                         if(!mode)//非叠加方式
  226.                                         {
  227.                                                 if(tfont16[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
  228.                                                 else LCD_WR_DATA(bc);
  229.                                                 m++;
  230.                                                 if(m%sizey==0)
  231.                                                 {
  232.                                                         m=0;
  233.                                                         break;
  234.                                                 }
  235.                                         }
  236.                                         else//叠加方式
  237.                                         {
  238.                                                 if(tfont16[k].Msk[i]&(0x01<<j))        LCD_DrawPoint(x,y,fc);//画一个点
  239.                                                 x++;
  240.                                                 if((x-x0)==sizey)
  241.                                                 {
  242.                                                         x=x0;
  243.                                                         y++;
  244.                                                         break;
  245.                                                 }
  246.                                         }
  247.                                 }
  248.                         }
  249.                 }
  250.                 continue;  //查找到对应点阵字库立即退出,防止多个汉字重复取模带来影响
  251.         }
  252. }
  253. /******************************************************************************
  254.       函数说明:显示单个24x24汉字
  255.       入口数据:x,y显示坐标
  256.                 *s 要显示的汉字
  257.                 fc 字的颜色
  258.                 bc 字的背景色
  259.                 sizey 字号
  260.                 mode:  0非叠加模式  1叠加模式
  261.       返回值:  无
  262. ******************************************************************************/
  263. void LCD_ShowChinese24x24(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
  264. {
  265.         u8 i,j,m=0;
  266.         u16 k;
  267.         u16 HZnum;//汉字数目
  268.         u16 TypefaceNum;//一个字符所占字节大小
  269.         u16 x0=x;
  270.         TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
  271.         HZnum=sizeof(tfont24)/sizeof(typFNT_GB24);        //统计汉字数目
  272.         for(k=0;k<HZnum;k++)
  273.         {
  274.                 if ((tfont24[k].Index[0]==*(s))&&(tfont24[k].Index[1]==*(s+1)))
  275.                 {
  276.                         LCD_Address_Set(x,y,x+sizey-1,y+sizey-1);
  277.                         for(i=0;i<TypefaceNum;i++)
  278.                         {
  279.                                 for(j=0;j<8;j++)
  280.                                 {
  281.                                         if(!mode)//非叠加方式
  282.                                         {
  283.                                                 if(tfont24[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
  284.                                                 else LCD_WR_DATA(bc);
  285.                                                 m++;
  286.                                                 if(m%sizey==0)
  287.                                                 {
  288.                                                         m=0;
  289.                                                         break;
  290.                                                 }
  291.                                         }
  292.                                         else//叠加方式
  293.                                         {
  294.                                                 if(tfont24[k].Msk[i]&(0x01<<j))        LCD_DrawPoint(x,y,fc);//画一个点
  295.                                                 x++;
  296.                                                 if((x-x0)==sizey)
  297.                                                 {
  298.                                                         x=x0;
  299.                                                         y++;
  300.                                                         break;
  301.                                                 }
  302.                                         }
  303.                                 }
  304.                         }
  305.                 }
  306.                 continue;  //查找到对应点阵字库立即退出,防止多个汉字重复取模带来影响
  307.         }
  308. }
  309. /******************************************************************************
  310.       函数说明:显示单个32x32汉字
  311.       入口数据:x,y显示坐标
  312.                 *s 要显示的汉字
  313.                 fc 字的颜色
  314.                 bc 字的背景色
  315.                 sizey 字号
  316.                 mode:  0非叠加模式  1叠加模式
  317.       返回值:  无
  318. ******************************************************************************/
  319. void LCD_ShowChinese32x32(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
  320. {
  321.         u8 i,j,m=0;
  322.         u16 k;
  323.         u16 HZnum;//汉字数目
  324.         u16 TypefaceNum;//一个字符所占字节大小
  325.         u16 x0=x;
  326.         TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
  327.         HZnum=sizeof(tfont32)/sizeof(typFNT_GB32);        //统计汉字数目
  328.         for(k=0;k<HZnum;k++)
  329.         {
  330.                 if ((tfont32[k].Index[0]==*(s))&&(tfont32[k].Index[1]==*(s+1)))
  331.                 {
  332.                         LCD_Address_Set(x,y,x+sizey-1,y+sizey-1);
  333.                         for(i=0;i<TypefaceNum;i++)
  334.                         {
  335.                                 for(j=0;j<8;j++)
  336.                                 {
  337.                                         if(!mode)//非叠加方式
  338.                                         {
  339.                                                 if(tfont32[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
  340.                                                 else LCD_WR_DATA(bc);
  341.                                                 m++;
  342.                                                 if(m%sizey==0)
  343.                                                 {
  344.                                                         m=0;
  345.                                                         break;
  346.                                                 }
  347.                                         }
  348.                                         else//叠加方式
  349.                                         {
  350.                                                 if(tfont32[k].Msk[i]&(0x01<<j))        LCD_DrawPoint(x,y,fc);//画一个点
  351.                                                 x++;
  352.                                                 if((x-x0)==sizey)
  353.                                                 {
  354.                                                         x=x0;
  355.                                                         y++;
  356.                                                         break;
  357.                                                 }
  358.                                         }
  359.                                 }
  360.                         }
  361.                 }
  362.                 continue;  //查找到对应点阵字库立即退出,防止多个汉字重复取模带来影响
  363.         }
  364. }
  365. /******************************************************************************
  366.       函数说明:显示单个字符
  367.       入口数据:x,y显示坐标
  368.                 num 要显示的字符
  369.                 fc 字的颜色
  370.                 bc 字的背景色
  371.                 sizey 字号
  372.                 mode:  0非叠加模式  1叠加模式
  373.       返回值:  无
  374. ******************************************************************************/
  375. void LCD_ShowChar(u16 x,u16 y,u8 num,u16 fc,u16 bc,u8 sizey,u8 mode)
  376. {
  377.         u8 temp,sizex,t,m=0;
  378.         u16 i,TypefaceNum;//一个字符所占字节大小
  379.         u16 x0=x;
  380.         sizex=sizey/2;
  381.         TypefaceNum=(sizex/8+((sizex%8)?1:0))*sizey;
  382.         num=num-' ';    //得到偏移后的值
  383.         LCD_Address_Set(x,y,x+sizex-1,y+sizey-1);  //设置光标位置
  384.         for(i=0;i<TypefaceNum;i++)
  385.         {
  386.                 if(sizey==12)temp=ascii_1206[num][i];                       //调用6x12字体
  387.                 else if(sizey==16)temp=ascii_1608[num][i];                 //调用8x16字体
  388.                 else if(sizey==24)temp=ascii_2412[num][i];                 //调用12x24字体
  389.                 else if(sizey==32)temp=ascii_3216[num][i];                 //调用16x32字体
  390.                 else return;
  391.                 for(t=0;t<8;t++)
  392.                 {
  393.                         if(!mode)//非叠加模式
  394.                         {
  395.                                 if(temp&(0x01<<t))LCD_WR_DATA(fc);
  396.                                 else LCD_WR_DATA(bc);
  397.                                 m++;
  398.                                 if(m%sizex==0)
  399.                                 {
  400.                                         m=0;
  401.                                         break;
  402.                                 }
  403.                         }
  404.                         else//叠加模式
  405.                         {
  406.                                 if(temp&(0x01<<t))LCD_DrawPoint(x,y,fc);//画一个点
  407.                                 x++;
  408.                                 if((x-x0)==sizex)
  409.                                 {
  410.                                         x=x0;
  411.                                         y++;
  412.                                         break;
  413.                                 }
  414.                         }
  415.                 }
  416.         }
  417. }
  418. /******************************************************************************
  419.       函数说明:显示字符串
  420.       入口数据:x,y显示坐标
  421.                 *p 要显示的字符串
  422.                 fc 字的颜色
  423.                 bc 字的背景色
  424.                 sizey 字号
  425.                 mode:  0非叠加模式  1叠加模式
  426.       返回值:  无
  427. ******************************************************************************/
  428. void LCD_ShowString(u16 x,u16 y,const u8 *p,u16 fc,u16 bc,u8 sizey,u8 mode)
  429. {
  430.         while(*p!='\0')
  431.         {
  432.                 LCD_ShowChar(x,y,*p,fc,bc,sizey,mode);
  433.                 x+=sizey/2;
  434.                 p++;
  435.         }
  436. }
  437. /******************************************************************************
  438.       函数说明:显示数字
  439.       入口数据:m底数,n指数
  440.       返回值:  无
  441. ******************************************************************************/
  442. u32 mypow(u8 m,u8 n)
  443. {
  444.         u32 result=1;
  445.         while(n--)result*=m;
  446.         return result;
  447. }
  448. /******************************************************************************
  449.       函数说明:显示整数变量
  450.       入口数据:x,y显示坐标
  451.                 num 要显示整数变量
  452.                 len 要显示的位数
  453.                 fc 字的颜色
  454.                 bc 字的背景色
  455.                 sizey 字号
  456.       返回值:  无
  457. ******************************************************************************/
  458. void LCD_ShowIntNum(u16 x,u16 y,u16 num,u8 len,u16 fc,u16 bc,u8 sizey)
  459. {
  460.         u8 t,temp;
  461.         u8 enshow=0;
  462.         u8 sizex=sizey/2;
  463.         for(t=0;t<len;t++)
  464.         {
  465.                 temp=(num/mypow(10,len-t-1))%10;
  466.                 if(enshow==0&&t<(len-1))
  467.                 {
  468.                         if(temp==0)
  469.                         {
  470.                                 LCD_ShowChar(x+t*sizex,y,' ',fc,bc,sizey,0);
  471.                                 continue;
  472.                         }else enshow=1;
  473.
  474.                 }
  475.                  LCD_ShowChar(x+t*sizex,y,temp+48,fc,bc,sizey,0);
  476.         }
  477. }
  478. /******************************************************************************
  479.       函数说明:显示两位小数变量
  480.       入口数据:x,y显示坐标
  481.                 num 要显示小数变量
  482.                 len 要显示的位数
  483.                 fc 字的颜色
  484.                 bc 字的背景色
  485.                 sizey 字号
  486.       返回值:  无
  487. ******************************************************************************/
  488. void LCD_ShowFloatNum1(u16 x,u16 y,float num,u8 len,u16 fc,u16 bc,u8 sizey)
  489. {
  490.         u8 t,temp,sizex;
  491.         u16 num1;
  492.         sizex=sizey/2;
  493.         num1=num*100;
  494.         for(t=0;t<len;t++)
  495.         {
  496.                 temp=(num1/mypow(10,len-t-1))%10;
  497.                 if(t==(len-2))
  498.                 {
  499.                         LCD_ShowChar(x+(len-2)*sizex,y,'.',fc,bc,sizey,0);
  500.                         t++;
  501.                         len+=1;
  502.                 }
  503.                  LCD_ShowChar(x+t*sizex,y,temp+48,fc,bc,sizey,0);
  504.         }
  505. }
  506. /******************************************************************************
  507.       函数说明:显示图片
  508.       入口数据:x,y起点坐标
  509.                 length 图片长度
  510.                 width  图片宽度
  511.                 pic[]  图片数组
  512.       返回值:  无
  513. ******************************************************************************/
  514. void LCD_ShowPicture(u16 x,u16 y,u16 length,u16 width,const u8 pic[])
  515. {
  516.         u16 i,j;
  517.         u32 k=0;
  518.         LCD_Address_Set(x,y,x+length-1,y+width-1);
  519.         for(i=0;i<length;i++)
  520.         {
  521.                 for(j=0;j<width;j++)
  522.                 {
  523.                         LCD_WR_DATA8(pic[k*2]);
  524.                         LCD_WR_DATA8(pic[k*2+1]);
  525.                         k++;
  526.                 }
  527.         }
  528. }
ST7735S.pdf (4.05 MB, 下载次数: 19)
DS_AT32F425_CH.pdf (2.07 MB, 下载次数: 35)
认证:项目经理
简介:资深嵌入式开发工程师
105
