[资料分享] LT6911GX是一款高性能HDMI2.1到MIPI-DSI/CSI芯片
1154|1
 楼主| JLKJ18338421851 发表于 2022-3-22 09:18 | 显示全部楼层 |阅读模式
1.描述
LT6911GX是一款高性能HDMI2.1到MIPI-DSI/CSI芯片,适用于VR/Display应用.HDCP RX作为HDCP中继器的上游,可以与其他芯片的HDCP TX配合实现该中继器对于MIPI输出,LT6911GX具有可配置的单端口或双端口或四端口MIPIDSI/CSI与高速时钟通道和1~4个高速数据通道,最大工作速率为2.5Gb/s/通道支持总带宽高达40Gbps。或C-PHY支持5.7Gb/s/lane,可支持总容量  带宽可达68.4Gbps。
LT6911GX内部集成了8位OCM和SPI闪存(堆叠模)来运行程序。 在线软件
LT6911GX也支持升级。
LT6911GX采用先进的CMOS工艺制作,在9mmx9mm BGA169封装中实现。 这
封装符合RoHS标准,可在-40°C至+85°C范围内工作。
2.特性
•HDMI2.1接收机
•单/双/四端口MIPI-DSI/CSI发射器
•杂项
3.应用程序
•显示
•虚拟现实
1. Description
The LT6911GX is a high performance HDMI2.1 to MIPI or LVDS chip for VR/Display application.
HDCP RX as the upstream of HDCP repeater, can cooperate with HDCP TX of other chips to realize the repeater function.
For HDMI2.1 input, LT6911GX can be configured as 3/4 lane. Adaptive equalization makes it suitable for long cable application and the maximum bandwidth is up to 32Gbps.
For MIPI output, LT6911GX features configurable single-port or dual-port or quad-port MIPI®DSI/CSI with 1 high-speed clock lane and 1~4 high-speed data lanes operating at maximum 2.5Gbps/lane with D-PHY, which can support a total bandwidth of up to 40Gbps for four port. Also support 5.7Gbps/lane with C-PHY, which can support a total bandwidth of up to 68.4Gbps for four port.
For LVDS output, LT6911GX can be configured as single, dual or quad-port LVDS with 1 high-speed clock lane, and 3~5 high-speed data lanes, operating at maximum 1.2Gbps per lane, which can support a total bandwidth of up to 24Gbps. LT6911GX supports flexible video data mapping path for 2D and 3D applications.
Two digital audio output interfaces are available, I2S and SPDIF. The I2S interface supports 8-ch LPCM and the SPDIF interface supports 2-ch LPCM or compressed audio, both at maximum 192 KHz sample rate.
The device is capable of automatic operation which is enabled by an integrated microprocessor that uses an embedded SPI flash for firmware storage. System control is also available through the configuration I2C slave interface.
LT6911GX is fabricated in advanced CMOS process and implemented in 9mmx9mm BGA169 package.
2. Features
• HDMI2.1 Receiver
• Four-Port MIPI® DSI/CSI Transmitter
• Four-Port LVDS Transmitter
• Digital Audio Output
3. Applications
• Display
• VR九黎科技是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!
Email:bcxu.jl@foxmail.com
地址:深圳市宝安区新桥街道中心路新桥三路19号宏海汇盈大厦6楼602
深圳市九黎科技有限公司QQ1124763084  发表于 2022-3-29 16:02
