龙讯LT9611 MIPIDSI/CSI到HDMI1.4可提供免费技术支持
929|0
JLKJ18338421851|  楼主 | 2022-3-24 11:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1. 描述
LT9611 MIPIDSI/CSI到HDMI1.4桥具有双端口MIPID-PHY接收器前端配置,每个端口4个数据通道,每个数据通道运行2Gbps,最大输入带宽为16Gbps。
2.桥接器提供HDMI数据输出,可选SPDIF或8通道I2S串行音频输入。 它的高保真8通道I2S可以传输高达192khz采样率的音频。 该SPDIF可以携带立体声LPCM音频或压缩音频,包括杜比数字和DTS。
3.LT9611是在先进的CMOS工艺制造和实现在一个小轮廓7.5mmx7.5mm QFN64封装。 该封装符合RoHS标准,可在-40°C至+85°C范围内工作。
2特性
双端口MIPIDSI/CSI接收器
HDMI1.4发射机
杂项
.应用程序
移动系统
手机
数码摄像机
数码静止相机
个人媒体播放器
游戏
相机系统
Description
The LT9611 MIPI® DSI/CSI to HDMI1.4 Bridge features a dual-port MIPI® D-PHY receiver front-end configuration with 4 data lanes per port operating at 2Gbps per data lane and a maximum input bandwidth of 16Gbps.
The bridge provides a HDMI data output with optional SPDIF or 8-channel I2S serial audio input. Its high fidelity 8-channel I2S can transmit audio up to a 192 kHz sampling rate. The SPDIF can carry stereo LPCM audio or compressed audio, including Dolby® Digital and DTS®.
The LT9611 is fabricated in advanced CMOS process and implemented in a small outline 7.5mmx7.5mm QFN64 package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
2. Features
• Dual-Port  MIPI® DSI/CSI Receiver
• HDMI1.4 Transmitter
• Miscellaneous
3. Applications
• Mobile systems
• Cellular handsets
• Digital video cameras
• Digital still cameras
• Personal media players
• Gaming
• Camera systems
