[PCB] wallys Routerboard/Linux-PCIe WiFi-modules-PCIe-adapter-support-AX200NGW
965|0
 楼主| wirelesswifi6 发表于 2022-3-28 09:55 | 显示全部楼层 |阅读模式
DR3G11
Adapter Card,1 x M.2 Card
support AX200NGW support DR9074-6E
Features
Support 1 pcs M.2 card
Support AX200NGW
SupportDR9074-6E
RoHS compliance ensure a high level protection of human health and the
environment from risks that can be posed by chemicals
Product Description
DR3G11 is an adapter card with one  M.2 slot. It can be used in a PC with a PCIe slot. Use this new adapter to expand your connectivity and upgrade y**ice to use the latest  m.2 interface cards. Each comes with both low and regular profile brackets.
Brackets include holes for mounting SMA connectors, or for using as cable exit holes.
    Specifications
    Parameter
    Rating
    Unit
    Input voltage
    V
    Output Voltage
    3.3
    V
    Operating Temperature
    -40 to +70
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    ROHS Compliance
    YES
    Outline
    Parameter
    Rating
    Unit
    Length
    110
    Mm
    Width
    66
    Mm
    WEB:https://www.wallystech.com/
    wifi6 router
    Wi-Fi 6E
    WiFi 6
    802.11ac
    QCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024
    IPQ4029/IPQ4019
    panel antenna
    omni  antenna
    Wireless Access Point
