龙讯LT6911GXC高性能HDMI2.1到MIPI或LVDS芯片,用于VR/Display应用
1220|0
 楼主| JLKJ18338421851 发表于 2022-4-1 15:22 | 显示全部楼层 |阅读模式
1 描述
LT6911GXC是一款高性能HDMI2.1到MIPI或LVDS芯片,用于VR/Display应用。
HDCP RX作为HDCP中继器的上游,可以与其他芯片的HDCP TX配合实现中继器功能。
对于HDMI2.1输入,LT6911GXC可配置为3/4 lanes。自适应均衡使其适合长电缆应用,最大带宽可达32Gbps。
对于MIPI输出,LT6911GXC具有可配置的单端口或双端口或四端口MIPI®DSI/CSI,具有1个高速时钟通道和1~4个高速数据通道,工作在最大2.5Gbps/lane与D-PHY,可支持四个端口的总带宽高达40Gbps。还支持5.7Gbps/lane与C-PHY,可支持总带宽高达68.4Gbps的四个端口。
对于LVDS输出,LT6911GXC可配置为单端口、双端口或四端口LVDS, 1条高速时钟通道,3~5条高速数据通道,每条通道最大工作带宽为1.2Gbps,可支持总带宽高达24Gbps。LT6911GXC支持灵活的视频数据映射路径的2D和3D应用程序。
提供两个数字音频输出接口I2S和SPDIF。I2S接口支持8通道LPCM, SPDIF接口支持2通道LPCM或压缩音频,采样率均为192khz。
该设备能够自动操作,这是由一个集成的微处理器,使用嵌入式SPI闪存固件存储。系统控制也可通过配置I2C从接口。
LT6911GXC采用先进的CMOS工艺制作,在9mmx9mm BGA169封装中实现
2. 特性
•HDMI2.1接收机
•四端口MIPI®DSI/CSI发射机
•四端口LVDS发射机
•数字音频输出
3.应用程序
•显示
•虚拟现实
1. Description
The LT6911GXC is a high performance HDMI2.1 to MIPI or LVDS chip for VR/Display application.HDCP RX as the upstream of HDCP repeater, can cooperate with HDCP TX of other chips to realize the repeater function.For HDMI2.1 input, LT6911GXC can be configured as 3/4 lanes. Adaptive equalization makes it suitable for long cable application and the maximum bandwidth is up to 32Gbps.For MIPI output, LT6911GXC features configurable single-port or dual-port or quad-port MIPI®DSI/CSI with 1 high-speed clock lane and 1~4 high-speed data lanes operating at maximum 2.5Gbps/lane with D-PHY, which can support a total bandwidth of up to 40Gbps for four port. Also support 5.7Gbps/lane with C-PHY, which can support a total bandwidth of up to 68.4Gbps for four port.For LVDS output, LT6911GXC can be configured as single, dual or quad-port LVDS with 1 high-speed clock lane, and 3~5 high-speed data lanes, operating at maximum 1.2Gbps per lane, which can support a total bandwidth of up to 24Gbps. LT6911GXC supports flexible video data mapping path for 2D and 3D applications.Two digital audio output interfaces are available I2S and SPDIF. The I2S interface supports 8-ch LPCM and the SPDIF interface supports 2-ch LPCM or compressed audio, both at maximum 192 KHz sample rate.The device is capable of automatic operation which is enabled by an integrated microprocessor that uses an embedded SPI flash for firmware storage. System control is also available through the configuration I2C slave interface.LT6911GXC is fabricated in advanced CMOS process and implemented in 9mmx9mm BGA169 package.
2. Features
• HDMI2.1 Receiver
• Four-Port MIPI® DSI/CSI Transmitter
• Four-Port LVDS Transmitter、
• Digital Audio Output
3. Applications
• Display
• VR
深圳市九黎科技有限公司是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!
