请教APP和bootloader合并编译
7187|0
 楼主| procat 发表于 2022-4-6 18:56 | 显示全部楼层 |阅读模式
按Bootloader GeneratorUser’s Guide中操作分别建立APP PROJECT 和BOOTLOAD PROJECT,且通过宏定义,将BOOTLOADER中的配置位注释掉,编译后错误为:error: unable to rename temporary 'build/default/production/mcc_generated_files\mcc.i-88103138' to output file 'build/default/production/mcc_generated_files\mcc.i': 'Permission denied'
1 error generated.
(908) exit status = 1
nbproject/Makefile-default.mk:243: recipe for target 'build/default/production/mcc_generated_files/mcc.p1' failed
make[2]: *** [build/default/production/mcc_generated_files/mcc.p1] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory 'E:/mydoc/myProject/my_doc/20220316ForceTest/PRO/20220316TestForce16F18424/20220316TestForce16F18424.X'
nbproject/Makefile-default.mk:91: recipe for target '.build-conf' failed
make[1]: Leaving directory 'E:/mydoc/myProject/my_doc/20220316ForceTest/PRO/20220316TestForce16F18424/20220316TestForce16F18424.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
不知什么情况?请各路好汉帮助看看,MPLAB X5.5。不会贴图啊。
