[MM32软件] 请教MM32SPIN05 ADC采样PWM中心点问题
6284|10
 楼主| 剑指蓝天 发表于 2022-4-7 11:27 | 显示全部楼层 |阅读模式
ADCSingleChannelInit(ADCch ADC_Channel_x)
{ ADC_InitTypeDef  ADC_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    ADC_StructInit(&ADC_InitStructure);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
    //ADC prescale factor
    ADC_InitStructure.ADC_PRESCARE = ADC_PCLK2_PRESCARE_6;//12M
    //Set ADC mode to continuous conversion mode
    ADC_InitStructure.ADC_Mode =ADC_Mode_Scan; //单周期转换
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;               //右对齐
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_TRIG;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_x, 0, ADC_CFGR_SAMCTL_7_5  );
    ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigConv_T1_TRIG );
    ADC_ExternalTrigConvCmd(ADC1, ENABLE);              //ADC外部触发使能
   ADC_Cmd(ADC1, ENABLE);
void TIM1_PWM_Init(void)
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
    TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
    TIM_TimeBaseStructure.TIM_Period    =   arr;
    TIM_TimeBaseStructure.TIM_Prescaler =   psc;
    //Setting Clock Segmentation
    TIM_TimeBaseStructure.TIM_ClockDivision = (TIMCKD_TypeDef)0;
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1;//中心对齐;
    TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
     /**  通道 1              **/
    TIM_OCStructInit(&TIM_OCInitStructure);
    //Select Timer Mode: TIM Pulse Width Modulation Mode 2
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
    TIM_OCInitStructure.TIM_OutputState =  TIM_OutputState_Enable;   //OC*输出
    TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable; // 互补输出关闭。关闭OC*N输出
    TIM_OCInitStructure.TIM_Pulse = 200;                    //占空比
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//匹配时输出高电平
    TIM_OC1Init(TIM1, &TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Disable);
   TIM_SelectOutputTrigger(TIM1,TIM_TRGOSource_Update );  //TRGO更新触发ADC
    TIM_ARRPreloadConfig(TIM1, ENABLE);                      //重装载ARR
    TIM_Cmd(TIM1, ENABLE);
    TIM_CtrlPWMOutputs(TIM1, ENABLE);
为什么采样不是PWM中心点。
foxsbig 发表于 2022-4-8 15:40 | 显示全部楼层
什么叫pwm中心点
 楼主| 剑指蓝天 发表于 2022-4-8 19:22 | 显示全部楼层
ADC采样时刻是PWM波形的中心.
kiwis66 发表于 2022-4-12 17:44 | 显示全部楼层
这不是方波么,为什么一定要中心
tpgf 发表于 2022-5-2 18:35 | 显示全部楼层
如何确定它的中心点呢
观海 发表于 2022-5-2 18:52 | 显示全部楼层
什么是它的中心点啊
guanjiaer 发表于 2022-5-2 18:59 | 显示全部楼层
就是它的对称点吗
heimaojingzhang 发表于 2022-5-2 19:07 | 显示全部楼层
这个点的意义何在呀
keaibukelian 发表于 2022-5-2 19:15 | 显示全部楼层
一个周期的中间吗
labasi 发表于 2022-5-2 19:28 | 显示全部楼层
能介绍一下什么是中心点吗
duo点 发表于 2022-5-17 10:58 来自手机 | 显示全部楼层
这都是来问问题的了
