[PIC®/AVR®/dsPIC®产品] PIC1867j11引脚被提示弃用
869|13
 楼主| zhanglli 发表于 2022-4-7 19:45 | 显示全部楼层 |阅读模式
【】查阅资料PIC的PORT引脚是可用的,为什么还出现这么多提示?
../I2C.c:39: warning: (1385) variable "_RC3" is deprecated (declared at D:\MPLABX\xc8\v1.41\include\pic18f67j11.h:14866)
../I2C.c:41: warning: (1385) variable "_RC4" is deprecated (declared at D:\MPLABX\xc8\v1.41\include\pic18f67j11.h:14868)
../I2C.c:56: warning: (1385) variable "_RC4" is deprecated (declared at D:\MPLABX\xc8\v1.41\include\pic18f67j11.h:14868)
../handing.c:30: warning: (1385) variable "_RD6" is deprecated (declared at D:\MPLABX\xc8\v1.41\include\pic18f67j11.h:14918)
../handing.c:36: warning: (1385) variable "_RD7" is deprecated (declared at D:\MPLABX\xc8\v1.41\include\pic18f67j11.h:14920)
../handing.c:57: warning: (1385) variable "_RD5" is deprecated (declared at D:\MPLABX\xc8\v1.41\include\pic18f67j11.h:14916)
【】翻了下头文件,PORT引脚都被_DEPRECATED了,如下(我用的MPLAB X IDE V5.15,XC V1.41),什么原因呀?
extern volatile __bit _DEPRECATED       RA0                 @ (((unsigned) &PORTA)*8) + 0;
#define                                 RA0_bit             BANKMASK(PORTA), 0
extern volatile __bit _DEPRECATED       RA1                 @ (((unsigned) &PORTA)*8) + 1;
#define                                 RA1_bit             BANKMASK(PORTA), 1
extern volatile __bit _DEPRECATED       RA2                 @ (((unsigned) &PORTA)*8) + 2;
#define                                 RA2_bit             BANKMASK(PORTA), 2
extern volatile __bit _DEPRECATED       RA3                 @ (((unsigned) &PORTA)*8) + 3;
#define                                 RA3_bit             BANKMASK(PORTA), 3
extern volatile __bit _DEPRECATED       RA4                 @ (((unsigned) &PORTA)*8) + 4;
#define                                 RA4_bit             BANKMASK(PORTA), 4
extern volatile __bit _DEPRECATED       RA5                 @ (((unsigned) &PORTA)*8) + 5;
#define                                 RA5_bit             BANKMASK(PORTA), 5
extern volatile __bit _DEPRECATED       RA6                 @ (((unsigned) &PORTA)*8) + 6;
#define                                 RA6_bit             BANKMASK(PORTA), 6
extern volatile __bit _DEPRECATED       RA7                 @ (((unsigned) &PORTA)*8) + 7;
#define                                 RA7_bit             BANKMASK(PORTA), 7
extern volatile __bit _DEPRECATED       RB0                 @ (((unsigned) &PORTB)*8) + 0;
#define                                 RB0_bit             BANKMASK(PORTB), 0
extern volatile __bit _DEPRECATED       RB1                 @ (((unsigned) &PORTB)*8) + 1;
#define                                 RB1_bit             BANKMASK(PORTB), 1
extern volatile __bit _DEPRECATED       RB2                 @ (((unsigned) &PORTB)*8) + 2;
#define                                 RB2_bit             BANKMASK(PORTB), 2
extern volatile __bit _DEPRECATED       RB3                 @ (((unsigned) &PORTB)*8) + 3;
#define                                 RB3_bit             BANKMASK(PORTB), 3
extern volatile __bit _DEPRECATED       RB4                 @ (((unsigned) &PORTB)*8) + 4;
#define                                 RB4_bit             BANKMASK(PORTB), 4
extern volatile __bit _DEPRECATED       RB5                 @ (((unsigned) &PORTB)*8) + 5;
#define                                 RB5_bit             BANKMASK(PORTB), 5
extern volatile __bit _DEPRECATED       RB6                 @ (((unsigned) &PORTB)*8) + 6;
#define                                 RB6_bit             BANKMASK(PORTB), 6
extern volatile __bit _DEPRECATED       RB7                 @ (((unsigned) &PORTB)*8) + 7;
kangzj 发表于 2022-4-7 19:57 | 显示全部楼层
PIC18F67J11
renyaq 发表于 2022-4-7 20:05 | 显示全部楼层
是这种写法过时了,早就在用PORTCbits.RC3 这种结构体的写法了
kangzj 发表于 2022-4-7 20:09 | 显示全部楼层
编译器瞬间洁净了好多
jlyuan 发表于 2022-4-7 20:12 | 显示全部楼层
代码风格更新换代了
juventus9554 发表于 2022-4-7 20:14 | 显示全部楼层
要跟谁潮流的步伐哦..
kangzj 发表于 2022-4-7 20:16 | 显示全部楼层
其实还是不大明白,我再琢磨琢磨吧,多谢了哈先
pzsh 发表于 2022-4-20 11:01 | 显示全部楼层
MCC配置试一试
tpgf 发表于 2022-5-2 10:35 | 显示全部楼层
什么叫弃用啊
wowu 发表于 2022-5-2 11:21 | 显示全部楼层
现在应该不这样写了
xiaoqizi 发表于 2022-5-2 11:28 | 显示全部楼层
语法应该没有问题啊
木木guainv 发表于 2022-5-2 11:36 | 显示全部楼层
没有这个引脚了吗
磨砂 发表于 2022-5-2 11:45 | 显示全部楼层
第一次看见这种提示
晓伍 发表于 2022-5-2 11:54 | 显示全部楼层
是老牌芯片了吧
