gd32启动文件
923|7
 楼主| yeluu 发表于 2022-4-15 21:44 | 显示全部楼层 |阅读模式
有使用过这个启动文件的吗?
芯片是GD32F305
;    \file    startup_gd32f30x_cl.s
;    \brief   start up file
;    \version 2018-10-10, V1.1.0, firmware for GD32F30x
;    \version 2020-09-30, V2.1.0, firmware for GD32F30x
;    Copyright (c) 2020, GigaDevice Semiconductor Inc.
;    Redistribution and use in source and binary forms, with or without modification,
;are permitted provided that the following conditions are met:
;    1. Redistributions of source code must retain the above copyright notice, this
;       list of conditions and the following disclaimer.
;    2. Redistributions in binary form must reproduce the above copyright notice,
;       this list of conditions and the following disclaimer in the documentation
;       and/or other materials provided with the distribution.
;    3. Neither the name of the copyright holder nor the names of its contributors
;       may be used to endorse or promote products derived from this software without
;       specific prior written permission.
;    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
;AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
;WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
;IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
;INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
;NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
;PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
;WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
;ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
;OF SUCH DAMAGE.
        MODULE  ?cstartup
        ;; Forward declaration of sections.
        SECTION CSTACK:DATA:NOROOT(3)
        SECTION .intvec:CODE:NOROOT(2)
        EXTERN  __iar_program_start
        EXTERN  SystemInit
        PUBLIC  __vector_table
        DATA
__vector_table
        DCD     sfe(CSTACK)                         ; top of stack
        DCD     Reset_Handler                       ; Vector Number 1,Reset Handler
        DCD     NMI_Handler                         ; Vector Number 2,NMI Handler
        DCD     HardFault_Handler                   ; Vector Number 3,Hard Fault Handler
        DCD     MemManage_Handler                   ; Vector Number 4,MPU Fault Handler
        DCD     BusFault_Handler                    ; Vector Number 5,Bus Fault Handler
        DCD     UsageFault_Handler                  ; Vector Number 6,Usage Fault Handler
        DCD     0                                   ; Reserved
        DCD     0                                   ; Reserved
        DCD     0                                   ; Reserved
        DCD     0                                   ; Reserved
        DCD     SVC_Handler                         ; Vector Number 11,SVCall Handler
        DCD     DebugMon_Handler                    ; Vector Number 12,Debug Monitor Handler
        DCD     0                                   ; Reserved
        DCD     PendSV_Handler                      ; Vector Number 14,PendSV Handler
        DCD     SysTick_Handler                     ; Vector Number 15,SysTick Handler
        ; External Interrupts
        DCD     WWDGT_IRQHandler                    ; 16:Window Watchdog Timer
        DCD     LVD_IRQHandler                      ; 17:LVD through EXTI Line detect
        DCD     TAMPER_IRQHandler                   ; 18:Tamper through EXTI Line detect
        DCD     RTC_IRQHandler                      ; 19:RTC through EXTI Line
        DCD     FMC_IRQHandler                      ; 20:FMC
        DCD     RCU_CTC_IRQHandler                  ; 21:RCU and CTC
        DCD     EXTI0_IRQHandler                    ; 22:EXTI Line 0
        DCD     EXTI1_IRQHandler                    ; 23:EXTI Line 1
        DCD     EXTI2_IRQHandler                    ; 24:EXTI Line 2
        DCD     EXTI3_IRQHandler                    ; 25:EXTI Line 3
        DCD     EXTI4_IRQHandler                    ; 26:EXTI Line 4
        DCD     DMA0_Channel0_IRQHandler            ; 27:DMA0 Channel0
        DCD     DMA0_Channel1_IRQHandler            ; 28:DMA0 Channel1
        DCD     DMA0_Channel2_IRQHandler            ; 29:DMA0 Channel2
        DCD     DMA0_Channel3_IRQHandler            ; 30:DMA0 Channel3
        DCD     DMA0_Channel4_IRQHandler            ; 31:DMA0 Channel4
        DCD     DMA0_Channel5_IRQHandler            ; 32:DMA0 Channel5
        DCD     DMA0_Channel6_IRQHandler            ; 33:DMA0 Channel6
        DCD     ADC0_1_IRQHandler                   ; 34:ADC0 and ADC1
        DCD     CAN0_TX_IRQHandler                  ; 35:CAN0 TX
        DCD     CAN0_RX0_IRQHandler                 ; 36:CAN0 RX0
        DCD     CAN0_RX1_IRQHandler                 ; 37:CAN0 RX1
        DCD     CAN0_EWMC_IRQHandler                ; 38:CAN0 EWMC
        DCD     EXTI5_9_IRQHandler                  ; 39:EXTI5 to EXTI9
        DCD     TIMER0_BRK_TIMER8_IRQHandler        ; 40:TIMER0 Break and TIMER8
        DCD     TIMER0_UP_TIMER9_IRQHandler         ; 41:TIMER0 Update and TIMER9
        DCD     TIMER0_TRG_CMT_TIMER10_IRQHandler   ; 42:TIMER0 Trigger and Commucation and TIMER10
        DCD     TIMER0_Channel_IRQHandler           ; 43:TIMER0 Channel Capture Compare
        DCD     TIMER1_IRQHandler                   ; 44:TIMER1
        DCD     TIMER2_IRQHandler                   ; 45:TIMER2
        DCD     TIMER3_IRQHandler                   ; 46:TIMER3
        DCD     I2C0_EV_IRQHandler                  ; 47:I2C0 Event
        DCD     I2C0_ER_IRQHandler                  ; 48:I2C0 Error
        DCD     I2C1_EV_IRQHandler                  ; 49:I2C1 Event
        DCD     I2C1_ER_IRQHandler                  ; 50:I2C1 Error
        DCD     SPI0_IRQHandler                     ; 51:SPI0
        DCD     SPI1_IRQHandler                     ; 52:SPI1
        DCD     USART0_IRQHandler                   ; 53:USART0
        DCD     USART1_IRQHandler                   ; 54:USART1
        DCD     USART2_IRQHandler                   ; 55:USART2
        DCD     EXTI10_15_IRQHandler                ; 56:EXTI10 to EXTI15
        DCD     RTC_Alarm_IRQHandler                ; 57:RTC Alarm
        DCD     USBFS_WKUP_IRQHandler               ; 58:USBFS Wakeup
        DCD     TIMER7_BRK_TIMER11_IRQHandler       ; 59:TIMER7 Break and TIMER11
        DCD     TIMER7_UP_TIMER12_IRQHandler        ; 60:TIMER7 Update and TIMER12
        DCD     TIMER7_TRG_CMT_TIMER13_IRQHandler   ; 61:TIMER7 Trigger and Commucation and TIMER13
        DCD     TIMER7_Channel_IRQHandler           ; 62:TIMER7 Channel Capture Compare
        DCD     0                                   ; 63:Reserved
        DCD     EXMC_IRQHandler                     ; 64:EXMC
        DCD     0                                   ; 65:Reserved
        DCD     TIMER4_IRQHandler                   ; 66:TIMER4
        DCD     SPI2_IRQHandler                     ; 67:SPI2
        DCD     UART3_IRQHandler                    ; 68:UART3
        DCD     UART4_IRQHandler                    ; 69:UART4
        DCD     TIMER5_IRQHandler                   ; 70:TIMER5
        DCD     TIMER6_IRQHandler                   ; 71:TIMER6
        DCD     DMA1_Channel0_IRQHandler            ; 72:DMA1 Channel0
        DCD     DMA1_Channel1_IRQHandler            ; 73:DMA1 Channel1
        DCD     DMA1_Channel2_IRQHandler            ; 74:DMA1 Channel2
        DCD     DMA1_Channel3_IRQHandler            ; 75:DMA1 Channel3
        DCD     DMA1_Channel4_IRQHandler            ; 76:DMA1 Channel4
        DCD     ENET_IRQHandler                     ; 77:Ethernet
        DCD     ENET_WKUP_IRQHandler                ; 78:Ethernet Wakeup through EXTI Line
        DCD     CAN1_TX_IRQHandler                  ; 79:CAN1 TX
        DCD     CAN1_RX0_IRQHandler                 ; 80:CAN1 RX0
        DCD     CAN1_RX1_IRQHandler                 ; 81:CAN1 RX1
        DCD     CAN1_EWMC_IRQHandler                ; 82:CAN1 EWMC
        DCD     USBFS_IRQHandler                    ; 83:USBFS
;; Default interrupt handlers.
        THUMB
        PUBWEAK Reset_Handler
        SECTION .text:CODE:NOROOT:REORDER(2)
Reset_Handler
        LDR     R0, =SystemInit
        BLX     R0
        LDR     R0, =__iar_program_start
        BX      R0
        PUBWEAK NMI_Handler
        SECTION .text:CODE:NOROOT:REORDER(1)
NMI_Handler
        B NMI_Handler
        PUBWEAK HardFault_Handler
HardFault_Handler
        B HardFault_Handler
        PUBWEAK MemManage_Handler
MemManage_Handler
        B MemManage_Handler
        PUBWEAK BusFault_Handler
BusFault_Handler
        B BusFault_Handler
        PUBWEAK UsageFault_Handler
UsageFault_Handler
        B UsageFault_Handler
        PUBWEAK SVC_Handler
SVC_Handler
        B SVC_Handler
        PUBWEAK DebugMon_Handler
DebugMon_Handler
        B DebugMon_Handler
        PUBWEAK PendSV_Handler
PendSV_Handler
        B PendSV_Handler
        PUBWEAK SysTick_Handler
SysTick_Handler
        B SysTick_Handler
        PUBWEAK WWDGT_IRQHandler
WWDGT_IRQHandler
        B WWDGT_IRQHandler
        PUBWEAK LVD_IRQHandler
LVD_IRQHandler
        B LVD_IRQHandler
        PUBWEAK TAMPER_IRQHandler
TAMPER_IRQHandler
        B TAMPER_IRQHandler
        PUBWEAK RTC_IRQHandler
RTC_IRQHandler
        B RTC_IRQHandler
        PUBWEAK FMC_IRQHandler
FMC_IRQHandler
        B FMC_IRQHandler
        PUBWEAK RCU_CTC_IRQHandler
RCU_CTC_IRQHandler
        B RCU_CTC_IRQHandler
        PUBWEAK EXTI0_IRQHandler
EXTI0_IRQHandler
        B EXTI0_IRQHandler
        PUBWEAK EXTI1_IRQHandler
EXTI1_IRQHandler
        B EXTI1_IRQHandler
        PUBWEAK EXTI2_IRQHandler
EXTI2_IRQHandler
        B EXTI2_IRQHandler
        PUBWEAK EXTI3_IRQHandler
EXTI3_IRQHandler
        B EXTI3_IRQHandler
        PUBWEAK EXTI4_IRQHandler
EXTI4_IRQHandler
        B EXTI4_IRQHandler
        PUBWEAK DMA0_Channel0_IRQHandler
        B DMA0_Channel0_IRQHandler
        PUBWEAK DMA0_Channel1_IRQHandler
        B DMA0_Channel1_IRQHandler
        PUBWEAK DMA0_Channel2_IRQHandler
        B DMA0_Channel2_IRQHandler
        PUBWEAK DMA0_Channel3_IRQHandler
        B DMA0_Channel3_IRQHandler
        PUBWEAK DMA0_Channel4_IRQHandler
        B DMA0_Channel4_IRQHandler
        PUBWEAK DMA0_Channel5_IRQHandler
        B DMA0_Channel5_IRQHandler
        PUBWEAK DMA0_Channel6_IRQHandler
        B DMA0_Channel6_IRQHandler
        PUBWEAK ADC0_1_IRQHandler
ADC0_1_IRQHandler
        B ADC0_1_IRQHandler
        PUBWEAK CAN0_TX_IRQHandler
CAN0_TX_IRQHandler
        B CAN0_TX_IRQHandler
        PUBWEAK CAN0_RX0_IRQHandler
CAN0_RX0_IRQHandler
        B CAN0_RX0_IRQHandler
        PUBWEAK CAN0_RX1_IRQHandler
CAN0_RX1_IRQHandler
        B CAN0_RX1_IRQHandler
        PUBWEAK CAN0_EWMC_IRQHandler
        B CAN0_EWMC_IRQHandler
        PUBWEAK EXTI5_9_IRQHandler
EXTI5_9_IRQHandler
        B EXTI5_9_IRQHandler
        PUBWEAK TIMER0_BRK_TIMER8_IRQHandler
        B TIMER0_BRK_TIMER8_IRQHandler
        PUBWEAK TIMER0_UP_TIMER9_IRQHandler
        B TIMER0_UP_TIMER9_IRQHandler
        PUBWEAK TIMER0_TRG_CMT_TIMER10_IRQHandler
        B TIMER0_TRG_CMT_TIMER10_IRQHandler
        PUBWEAK TIMER0_Channel_IRQHandler
        B TIMER0_Channel_IRQHandler
        PUBWEAK TIMER1_IRQHandler
TIMER1_IRQHandler
        B TIMER1_IRQHandler
        PUBWEAK TIMER2_IRQHandler
TIMER2_IRQHandler
        B TIMER2_IRQHandler
        PUBWEAK TIMER3_IRQHandler
TIMER3_IRQHandler
        B TIMER3_IRQHandler
        PUBWEAK I2C0_EV_IRQHandler
I2C0_EV_IRQHandler
        B I2C0_EV_IRQHandler
        PUBWEAK I2C0_ER_IRQHandler
I2C0_ER_IRQHandler
        B I2C0_ER_IRQHandler
        PUBWEAK I2C1_EV_IRQHandler
I2C1_EV_IRQHandler
        B I2C1_EV_IRQHandler
        PUBWEAK I2C1_ER_IRQHandler
I2C1_ER_IRQHandler
        B I2C1_ER_IRQHandler
        PUBWEAK SPI0_IRQHandler
SPI0_IRQHandler
        B SPI0_IRQHandler
        PUBWEAK SPI1_IRQHandler
SPI1_IRQHandler
        B SPI1_IRQHandler
        PUBWEAK USART0_IRQHandler
USART0_IRQHandler
        B USART0_IRQHandler
        PUBWEAK USART1_IRQHandler
USART1_IRQHandler
        B USART1_IRQHandler
        PUBWEAK USART2_IRQHandler
USART2_IRQHandler
        B USART2_IRQHandler
        PUBWEAK EXTI10_15_IRQHandler
        B EXTI10_15_IRQHandler
        PUBWEAK RTC_Alarm_IRQHandler
        B RTC_Alarm_IRQHandler
        PUBWEAK USBFS_WKUP_IRQHandler
        B USBFS_WKUP_IRQHandler
        PUBWEAK TIMER7_BRK_TIMER11_IRQHandler
        B TIMER7_BRK_TIMER11_IRQHandler
        PUBWEAK TIMER7_UP_TIMER12_IRQHandler
        B TIMER7_UP_TIMER12_IRQHandler
        PUBWEAK TIMER7_TRG_CMT_TIMER13_IRQHandler
        B TIMER7_TRG_CMT_TIMER13_IRQHandler
        PUBWEAK TIMER7_Channel_IRQHandler
        B TIMER7_Channel_IRQHandler
        PUBWEAK EXMC_IRQHandler
EXMC_IRQHandler
        B EXMC_IRQHandler
        PUBWEAK TIMER4_IRQHandler
TIMER4_IRQHandler
        B TIMER4_IRQHandler
        PUBWEAK SPI2_IRQHandler
SPI2_IRQHandler
        B SPI2_IRQHandler
        PUBWEAK UART3_IRQHandler
UART3_IRQHandler
        B UART3_IRQHandler
        PUBWEAK UART4_IRQHandler
UART4_IRQHandler
        B UART4_IRQHandler
        PUBWEAK TIMER5_IRQHandler
TIMER5_IRQHandler
        B TIMER5_IRQHandler
        PUBWEAK TIMER6_IRQHandler
TIMER6_IRQHandler
        B TIMER6_IRQHandler
        PUBWEAK DMA1_Channel0_IRQHandler
        B DMA1_Channel0_IRQHandler
        PUBWEAK DMA1_Channel1_IRQHandler
        B DMA1_Channel1_IRQHandler
        PUBWEAK DMA1_Channel2_IRQHandler
        B DMA1_Channel2_IRQHandler
        PUBWEAK DMA1_Channel3_IRQHandler
        B DMA1_Channel3_IRQHandler
        PUBWEAK DMA1_Channel4_IRQHandler
        B DMA1_Channel4_IRQHandler
        PUBWEAK ENET_IRQHandler
ENET_IRQHandler
        B ENET_IRQHandler
        PUBWEAK ENET_WKUP_IRQHandler
        B ENET_WKUP_IRQHandler
        PUBWEAK CAN1_TX_IRQHandler
CAN1_TX_IRQHandler
        B CAN1_TX_IRQHandler
        PUBWEAK CAN1_RX0_IRQHandler
CAN1_RX0_IRQHandler
        B CAN1_RX0_IRQHandler
        PUBWEAK CAN1_RX1_IRQHandler
CAN1_RX1_IRQHandler
        B CAN1_RX1_IRQHandler
        PUBWEAK CAN1_EWMC_IRQHandler
        B CAN1_EWMC_IRQHandler
        PUBWEAK USBFS_IRQHandler
USBFS_IRQHandler
        B USBFS_IRQHandler
        END
cooldog123pp 发表于 2022-4-16 16:19 | 显示全部楼层
虽然我不是很明白,但是路过了就帮忙楼主顶贴一下,希望楼主问题早日解决。
tpgf 发表于 2022-5-4 13:53 | 显示全部楼层
启动文件的来源是哪里啊
nawu 发表于 2022-5-4 14:07 | 显示全部楼层
没有见过这个启动文件
aoyi 发表于 2022-5-4 14:17 | 显示全部楼层
这个启动文件的作用是什么呢
zljiu 发表于 2022-5-4 14:39 | 显示全部楼层
这个是什么编程语言写的啊
gwsan 发表于 2022-5-4 14:48 | 显示全部楼层
启动文件是必需的吗
tfqi 发表于 2022-5-4 15:00 | 显示全部楼层
demo自带的文件吗
