HC32L110 定时器怎么进不了中断?
1206|0
 楼主| liboguang 发表于 2022-4-25 13:07 | 显示全部楼层 |阅读模式
使用官方的代码HC32L110_DDL_Rev1.1.4。也是进不去。这是问什么?/*******************************************************************************
* BT1中断服务函数
void BtInt(void)
    if (TRUE == Bt_GetIntFlag(TIM1))
        Bt_ClearIntFlag(TIM1);
                                RunUart0FrameOut();
* BT定时功能测试 (重载模式)
void Init_Timer1(void)
    stc_bt_config_t   stcConfig;
    en_result_t       enResult = Error;
    uint16_t          u16ArrData = 0x10000 - 100;
    uint16_t          u16InitCntData = 0x10000 - 100;//100us
                Clk_SetPeripheralGate(ClkPeripheralBt,TRUE); //使能定时器时钟
    stcConfig.pfnTim1Cb = BtInt;
    stcConfig.enGateP = BtPositive;
    stcConfig.enGate  = BtGateEnable;
    stcConfig.enPRS   = BtPCLKDiv8; //时钟为PCLK 8分频
    stcConfig.enTog   = BtTogDisable;
    stcConfig.enCT    = BtTimer;
    stcConfig.enMD    = BtMode2;
    //Bt初始化
    if (Ok != Bt_Init(TIM1, &stcConfig))
        enResult = Error;
    //设置重载值和计数值,启动计数
                Bt_ARRSet(TIM1, u16ArrData);
    Bt_Cnt16Set(TIM1, u16InitCntData);
    //TIM1中断使能
    Bt_EnableIrq(TIM1);
    EnableNvic(TIM1_IRQn, 1, TRUE);
    Bt_Run(TIM1);
