[应用相关] STM32F2——ADC多通道DMA采集时AD值大于4095的问题解决方法
2354|49
 楼主| t60yz 发表于 2022-4-30 18:23 | 显示全部楼层 |阅读模式
前言
  最近在调试STM32F2XX系列ADC多通道DMA采集时,发现采集的AD值大于4095,有的65000多了,这是什么节奏?adc不是12位吗,最大才0xfff,即4095,怎么会出现这种情况呢?难到是adc数据对齐方式出现问题了,adc的对齐明明设置的是右对齐啊,神马情况?
ADC结构体参数分析   百思不得adc之姐,只能keil单步调试,一步一步查看adc结构体的参数。我使用的是adc dma方式采集,共9个通道。初始化程序如下:
  1. void ADC_DMA_Config(void)
  3.     ADC_InitTypeDef       ADC_InitStructure;
  4.     ADC_CommonInitTypeDef ADC_CommonInitStructure;
  5.     DMA_InitTypeDef       DMA_InitStructure;
  6.     GPIO_InitTypeDef      GPIO_InitStructure;
  7.     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOC, ENABLE);
  8.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  9.     DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  10.     DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC1->DR;
  11.     DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC_ConvertedValue;
  12.     DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  13.     DMA_InitStructure.DMA_BufferSize = Sample_Num*Channel_Num;
  14.     DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  15.     DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  16.     DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  17.     DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  18.     DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  19.     DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  20.     DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  21.     DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  22.     DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  23.     DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  24.     DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  25.     DMA_Cmd(DMA2_Stream0, ENABLE);
  26.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_2 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7;
  27.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  28.     GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  29.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  30.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_3 | GPIO_Pin_5;
  31.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  32.     GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  33.     GPIO_Init(GPIOC, &GPIO_InitStructure);
  34.     /* ADC Common Init **********************************************************/
  35.     ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  36.     ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  37.     ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  38.     ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  39.     ADC_CommonInit(&ADC_CommonInitStructure);
  40.     ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  41.     ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  42.     ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  43.     ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  44.     ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  45.     ADC_InitStructure.ADC_NbrOfConversion = 9;
  46.     ADC_Init(ADC1, &ADC_InitStructure);
  47.     ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_3Cycles);
  48.     ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_3Cycles);
  49.     ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_3Cycles);
  50.     ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 4, ADC_SampleTime_3Cycles);
  51.     ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 5, ADC_SampleTime_3Cycles);
  52.     ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 6, ADC_SampleTime_3Cycles);
  53.     ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 7, ADC_SampleTime_3Cycles);
  54.     ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 8, ADC_SampleTime_3Cycles);
  55.     ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 9, ADC_SampleTime_3Cycles);
  56.     ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
  57.     ADC_DMACmd(ADC1, ENABLE);
  58.     ADC_Cmd(ADC1, ENABLE);
  59. }
 楼主| t60yz 发表于 2022-4-30 18:25 | 显示全部楼层
其中涉及adc的初始化结构体代码部分如下:
  1.     ADC_InitTypeDef       ADC_InitStructure;
  2.     ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  3.     ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  4.     ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  5.     ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  6.     ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  7.     ADC_InitStructure.ADC_NbrOfConversion = 9;
  8.     ADC_Init(ADC1, &ADC_InitStructure);
 楼主| t60yz 发表于 2022-4-30 18:26 | 显示全部楼层
一步一步调式发现结构体有一项ADC_ExternalTrigConv是0x08002d54,这一项并没有初始化对其赋值,忘记给结构体的这一项赋值了。最后这个值通过ADC_Init函数赋值给CR2的时候,第11位(也就是数据对其位)是1了,左对齐了!!!!!
 楼主| t60yz 发表于 2022-4-30 18:27 | 显示全部楼层
下面来重点分析下adc初始化结构体中的各项参数的意义:
  对于STM32,在使用ADC的时候需要配置几个参数。
 楼主| t60yz 发表于 2022-4-30 18:30 | 显示全部楼层
(1) 第一个参数是ADC_Mode,这里设置为独立模式:
  1. ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
在这个模式下,双ADC不能同步,每个ADC接口独立工作。所以如果不需要ADC同步或者只是用了一个ADC的时候,就应该设成独立模式了。
 楼主| t60yz 发表于 2022-4-30 18:31 | 显示全部楼层
(2) 第二个参数是ADC_ScanConvMode,这里设置为DISABLE。
如果只是用了一个通道的话,DISABLE就可以了,如果使用了多个通道的话,则必须将其设置为ENABLE。
 楼主| t60yz 发表于 2022-4-30 18:32 | 显示全部楼层
(3) 第三个参数是ADC_ContinuousConvMode,这里设置为ENABLE,即连续转换。
如果设置为DISABLE,则是单次转换。两者的区别在于连续转换直到所有的数据转换完成后才停止转换,而单次转换则只转换一次数据就停止,要再次触发转换才可以。所以如果需要一次性采集1024个数据或者更多,则采用连续转换。
(4) 第四个参数是ADC_ExternalTrigConv,即选择外部触发模式。这里只讲三种:
1、第一种是最简单的软件触发,参数一般为ADC_ExternalTrigConv_None(注意STM32F2XX系列这个有点蹊跷,后面会讲这个)。设置好后还要记得调用库函数:
 楼主| t60yz 发表于 2022-4-30 18:33 | 显示全部楼层
  1. ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  2. void ADC_SoftwareStartConv(ADC_TypeDef* ADCx)
  3. {
  4.   /* Check the parameters */
  5.   assert_param(IS_ADC_ALL_PERIPH(ADCx));
  6.   /* Enable the selected ADC conversion for regular group */
  7.   ADCx->CR2 |= (uint32_t)ADC_CR2_SWSTART;
  8. }
  9. #define  ADC_CR2_SWSTART                     ((uint32_t)0x40000000)
  10. /*!<Start Conversion of regular channels */
 楼主| t60yz 发表于 2022-4-30 18:34 | 显示全部楼层
ADC_SoftwareStartConv函数里直接置位CR2的ADC_CR2_SWSTART位,这样触发就启动了。
 楼主| t60yz 发表于 2022-4-30 18:35 | 显示全部楼层
2、第二种是定时器通道输出触发。共有这几种:ADC_ExternalTrigConv_T1_CC1、ADC_ExternalTrigConv_T1_CC2、ADC_ExternalTrigConv_T2_CC2、
ADC_ExternalTrigConv_T3_T以及ADC_ExternalTrigConv_T4_CC4。定时器输出触发比较麻烦,还需要设置相应的定时器。
 楼主| t60yz 发表于 2022-4-30 18:36 | 显示全部楼层
以ADC_ExternalTrigConv_T2_CC2触发为例设置相应的定时器:
  1. void TIM2_Configuration(void)
  3. TIM_TimeBaseInitTypeDef   TIM_TimeBaseStructure;
  4. TIM_OCInitTypeDef         TIM_OCInitStructure;
  5. TIM_TimeBaseStructure.TIM_Prescaler = 4;
  6. TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  7. TIM_TimeBaseStructure.TIM_Period = 0XFF;
  8. TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  9. TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  10. TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  11. TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  12. TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  13. TIM_OCInitStructure.TIM_Pulse = 0X7F;
  14. TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  15. TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  16. //配置CC2的属性。若CC3作为ADC的触发源,则应改为TIM_OC3Init(TIM2, &TIM_OCInitStructure);
  17. TIM_OC2Init(TIM2, &TIM_OCInitStructure);
  18. TIM_Cmd(TIM2, ENABLE);
  19. TIM_CtrlPWMOutputs(TIM2, ENABLE);
  20. }
这样设置之后就可以用定时器2的输出触发了,至于触发的周期,设置TIM2的时间即可。这里不再赘述。
 楼主| t60yz 发表于 2022-4-30 18:37 | 显示全部楼层
3、第三种是外部引脚触发,对于规则通道,选择EXTI线11和TIM8_TRGO作为外部触发事件;而注入通道组则选择EXTI线15和TIM8_CC4作为外部触发事件。
 楼主| t60yz 发表于 2022-4-30 18:38 | 显示全部楼层
(5) 第五个参数是ADC_DataAlign,这里设置为ADC_DataAlign_Right右对齐方式。建议采用右对齐方式,因为这样处理数据会比较方便。当然如果要从高位开始传输数据,那么采用左对齐优势就明显了。
 楼主| t60yz 发表于 2022-4-30 18:39 | 显示全部楼层
(6) 第六个参数是ADC_NbrOfChannel,顾名思义:通道的数量。要是到多个通道采集数据的话就得设置一下这个参数。
 楼主| t60yz 发表于 2022-4-30 18:40 | 显示全部楼层
  1.       ADC_RegularChannelConfig(ADC1,ADC_Channel_13,1,ADC_SampleTime_13Cycles5);
  2.       ADC_RegularChannelConfig(ADC1,ADC_Channel_14,2,ADC_SampleTime_13Cycles5);
 楼主| t60yz 发表于 2022-4-30 18:41 | 显示全部楼层
 多通道数据传输时有一点还要注意:若一个数组为ADC_ValueTab[4],且设置了两个通道:通道1和通道2,则转换结束后,ADC_ValueTab[0]和ADC_ValueTab[2]存储的是通道1的数据,而ADC_ValueTab[1]和ADC_ValueTab[3]存储的是通道2的数据。如果数组容量大则依次类推。
补充一点:在使用DMA传输数据的时候,需要设置外设地址和存储器地址,外设地址当然就是ADC的地址了,而存储器的地址如果使用8位数据的话,存储器必须定义为8位缓冲区;如果使用16位数据格式的话,存储器则为16位缓冲器,不可定义为32位或更多,否则,数据将出错。
 楼主| t60yz 发表于 2022-4-30 18:42 | 显示全部楼层
问题的解决方法
  上面分析了adc结构体的参数,下面再来单独看看ADC_ExternalTrigConv这一项。
  在stm32f2xx_adc.h文件中有这个成员的参数定义,发现里面并没有ADC_ExternalTrigConv_None这个常见的定义。
