[PCB]
G 17dBi panel antenna 802.11ac/802.11ax, mmcx connector
908|0
AX200NGW/IPQ6010/IPQ6018/IPQ6000/IPQ8072/IPQ5018/IPQ8074/IPQ8072A/IPQ4029/IPQ4019/AR9344
5G 17dBi panel antenna  802.11ac/802.11ax, mmcx connector
1. Feature
* 17dBiDual Polarized Micro strip  Antenna Array
* 5GHz of frequency
* MMCX connector
* Support 802.3 11AX/AC/AN
* RoHS compliance
2. Application
* 5GHz Wireless Communication
* WLAN device, WLAN Router, e.g., AP, PIC Wireless Card
3. Description
This antenna array is designed for 5GHz applications and can be easily built-in portable devices with MHF processes. It has excellent stability and sensitivity to consistently provide high signal reception efficiency.
    General Data
    Product Name
    Part No.
    DR5G17_A
    DR5G17_H
    Frequency
    5.1GHz-5.9GHz
    5.1GHz-5.9GHz
    V.S.W.R
    <1.85
    <1.65
    Gain (dBi)
    17dbi
    18dbi
    Polarization
    Vertical & horizontal
    Isolation
    >40db
    >40db
    Storage Temp
    -20°C~70°C
    -20°C~70°C
    Operating Temperature
    -20°C~60°C
    -20°C~60°C
    Antenna Type
    Antenna Array
    Antenna Array
    Dimension
    200*105mm
    200*105mm
    Weight
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
