[技术问答] [M480] M4 DSP Convolution
815|0
 楼主| 两只袜子 发表于 2022-5-19 11:00 | 显示全部楼层 |阅读模式
  • Application: This sample code uses the M4 DSP to calculate Convolution.
  • BSP Version: M480 Series BSP CMSIS V3.04.000
  • Hardware: NuMaker-PFM-M487 Ver 3.0
This sample code uses the CMSIS DSP library to calculate Convolution, user can use these functions to implement mathematical equations. The sample code compares the difference between using the DSP calculation time and calculates the efficiency improvement ratio.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0725135219
