[PCB] wallys//IPQ6000/IPQ6018/IPQ6010 openwrt 802.11ax 2x2 2.4G 2x2 5G 1.7Gbps
1395|0
 楼主| wirelesswifi6 发表于 2022-5-27 10:12 | 显示全部楼层 |阅读模式
Qualcomm-Atheros IPQ6000
Quad-core ARM 64 bit A53s 1.2GHz processor
2.4GHz, 2x2 MU-MIMO OFDMA Technology, up to 573Mbps
5GHz, 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps
2 on board radios (Dual Band Concurrent Radio)
Supports Dynamic Frequency Selection (DFS)
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    V
    Operating Temperature Range
    -20 to +70
    ºC
    Storage Temperature Range
    -45 to +90
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.2GHz processor
    System Memory
    DDR3L 512MB 16-bit interface
    Nand Flash
    128MB
    NOR Flash
    16MB
    Ethernet Port
    2x 1Gbps Ethernet Ports
    DC Jack Input
    1x DC Jack Connector: 12V
    Power Consumption(Board Only)
    1TD
    On Board Radio
    2 radios (Dual band concurrent radio)
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 20dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 2x U.FL Connectors, diplexer allows dual band concurrent operation
    Frequency Range
    2.412~2.472GHz, 5.150~5.825GHz
    2.4GHz Data Rate
    5GHz Data Rate
    Modulation Techniques
    OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM,1024QAM
    LED
    4x LED Indicators
    USB /Header
    1x MicroUSB 2.0 Port
    Serial Port
    1x Serial Interface 12 Pin Connectors
    Certification
    TBD
    Humidity
    Operating: 5% to 95% (non-condensing) Storage: Max. 90% (non-condensing)
    Temperature Range
    Operating: TBD Storage: -40ºC to 90ºC
    Dimension (Diameter x Height)
    100mm x 23.5mm (Without Heatsink)
    Radio TX Specifications For 2.4GHz
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    2.4GHz
       802.11b
    1Mbps
    20dBm
    23dBm
    ±2dB
    2Mbps
    20dBm
    23dBm
    ±2dB
    5.5Mbps
    20dBm
    23dBm
    ±2dB
    11Mbps
    20dBm
    23dBm
    ±2dB
    2.4GHz
       802.11g
    6Mbps
    20dBm
    23dBm
    ±2dB
    9Mbps
    20dBm
    23dBm
    ±2dB
    12Mbps
    20dBm
    23dBm
    ±2dB
    18Mbps
    20dBm
    23dBm
    ±2dB
    24Mbps
    20dBm
    23dBm
    ±2dB
    36Mbps
    20dBm
    23dBm
    ±2dB
    48Mbps
    20dBm
    23dBm
    ±2dB
    54Mbps
    18dBm
    21dBm
    ±2dB
    2.4GHz
       802.11n HT40
    MCS 0
    19dBm
    22dBm
    ±2dB
    MCS 1
    19dBm
    22dBm
    ±2dB
    MCS 2
    19dBm
    22dBm
    ±2dB
    MCS 3
    19dBm
    22dBm
    ±2dB
    MCS 4
    19dBm
    22dBm
    ±2dB
    MCS 5
    19dBm
    22dBm
    ±2dB
    MCS 6
    18dBm
    21dBm
    ±2dB
    MCS 7
    17dBm
    20dBm
    ±2dB
    2.4GHz
       802.11n HT40
    MCS 0
    18dBm
    21dBm
    ±2dB
    MCS 1
    18dBm
    21dBm
    ±2dB
    MCS 2
    18dBm
    21dBm
    ±2dB
    MCS 3
    18dBm
    21dBm
    ±2dB
    MCS 4
    18dBm
    21dBm
    ±2dB
    MCS 5
    18dBm
    21dBm
    ±2dB
    MCS 6
    17dBm
    20dBm
    ±2dB
    MCS 7
    16dBm
    19dBm
    ±2dB
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
