[PCB] wallys/IPQ45018/IPQ4018/IPQ4019 12V-56VDCPassive 24V-56V
1262|0
 楼主| wirelesswifi6 发表于 2022-5-31 09:40 | 显示全部楼层 |阅读模式
Featuring with industrial-grade IPQ4018 chipset
Integrated with 2x 2 5G Radio module and 2x2 Radio module
Support 5.180GHz to 5.825GHz Frequency Range
Support 2.412GHz to2.482GHz
Support 2 x 5G UFL Connectors and 2x2.4G UFL
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/802.11AC wave2 mode
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    V
    Operating Temperature Range
    -40 to +70
    ºC
    Storage Temperature Range
    -65 to +105
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    IPQ4018
    Antenna Connector
    4xUFL
    10/100/1000Mbps Gigabit Ethernet
    5xRJ45
    SFP connector
    NO
    3G/4G connector
    NO
    USB connector
    1xUSB 3.0 connector
    POE
    NO
    DC Jack
    12 power supply
    ROHS Compliance
    YES
    Dimension
    NA
    Max Power
    15W
    Radio TX Specifications(5180MHz-5825MHz)
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    802.11a
    6 Mbps
    20dBm
    23dbm
    ±2dB
    54 Mbps
    18dBm
    21dbm
    ±2dB
    802.11n HT20
    MCS0, MCS8
    19dBm
    22dbm
    ±2dB
    MCS7, MCS15
    17dBm
    20dbm
    ±2dB
    802.11n HT40
    MCS0, MCS8
    19dBm
    22dbm
    ±2dB
    MCS7, MCS15
    17dBm
    20dbm
    ±2dB
    802.11ac
    MCS0, MCS10,MCS20
    19dBm
    22dbm
    ±2dB
    MCS9,MCS19,MCS29
    16dBm
    19dbm
    ±2dB
    Radio RX Specifications(5180MHz-5825MHz)
    Operating Mode
    Data Rate
    Sensitivity
    802.11a
    6 Mbps
    -93dBm
    54 Mbps
    -78dBm
    802.11n HT20
    MCS0, MCS8
    -92dBm
    MCS7, MCS15
    -73dBm
    802.11n HT40
    MCS0, MCS8
    -90dBm
    MCS7, MCS15
    -70dBm
    802.11AC HT40
    MCS0, MCS10,MCS20
    -90dBm
    MCS9,MCS19,MCS29
    -67dBm
    802.11AC HT80
    MCS0, MCS10,MCS20
    -88dBm
    MCS9,MCS19,MCS29
    -62dBm
