[MM32软件]
printf的使用
1084|3
xixi2017|  楼主 | 2022-5-31 18:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "delay.h"
#include "sys.h"
#include "led.h"
**函数信息 :main(void)
**功能描述 :
**输入参数 :无
**输出参数 :无
int fputc(int ch, FILE *f)
    while((UART1->CSR&UART_IT_TXIEN)==0);//循环发送,直到发送完毕
    UART1->TDR = (ch & (uint16_t)0x00FF);
    return ch;
int main(void)
        unsigned int x=0;
        UART_InitTypeDef UART_Uart1;
        UART_Uart1.UART_BaudRate                                                =115200;
        UART_Uart1.UART_HardwareFlowControl        =UART_HardwareFlowControl_None;
        UART_Uart1.UART_Mode        =UART_Mode_Rx | UART_Mode_Tx;
        UART_Uart1.UART_Parity                                                        =UART_Parity_No;
        UART_Uart1.UART_StopBits                                                =UART_StopBits_1;
        UART_Uart1.UART_WordLength                                        =UART_WordLength_8b;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_UART1, ENABLE);        //使能UART1,GPIOA时钟
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);  //开启GPIOA,GPIOB时钟
        //UART 初始化设置
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_1);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1);
        UART_DeInit(UART1);
        UART_Init(UART1,&UART_Uart1);
        UART_Cmd(UART1, ENABLE);
                //UART1_TX   GPIOA.9
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //复用推挽输出
        GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
        //UART1_RX          GPIOA.10初始化
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
        GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
  delay_init();
        LED_Init();
    while(1)
                        delay_ms(2000);
                        printf("Hello Blink.....%d\n",x++);
                        LED1_TOGGLE();
printf移植还是非常容易的,我看很多大佬分享了经验。
星辰大海不退缩| | 2022-10-15 14:48 | 只看该作者
其实讲解的还是不太细,咱们只是会用了而已,仅此而已
sadicy| | 2022-10-17 20:26 | 只看该作者
只是调试的时候,有些用,实际开发几乎不会用这printf
Stahan| | 2022-11-2 20:58 | 只看该作者
只要是会用了就行
