[ISE] Linux环境下安装Xilinx ISE 14.6
3173|2
 楼主| gaochy1126 发表于 2022-5-31 21:08 | 显示全部楼层 |阅读模式
1、从官网下载ISE
到官网注册,然后下载linux版本的ISE14.7。
链接:http://www.xilinx.com/support/do ... v/design-tools.html
到官网注册,然后下载linux版本的ISE。
2、解压
一定要在linux下解压
[python] view plaincopy
$ sudo tar xvf Xilinx_ISE_DS_Lin_14.6_P.68d_3.tar
[sudo] password for yunz:
#unpakging......
$ cd Xilinx_ISE_DS_Lin_14.6_P.68d_3/
$ ls
bin     data  idata  labtools  msg        planahead_wp  webpack  xsetup
common  edk   ise    lib       planahead  sysgen        xinfo
$ sudo chmod +x xsetup     //用这种方法反复安装都不对,最后采用另外一个xsetup文件就可以了(bin目录下的32位安装)。
$ ./xsetup
#unpakging......
$ ls
$ ./xsetup
3、安装
下面就是图形界面安装了,和windows下没什么不同
但要注意到这里的时候
不要点选
Install cable drivers
直接点Next
记下Install summary
[plain] view plaincopy
Install Location(s):
/usr/14.6/ISE_DS
Edition : ISE Design Suite System Edition
Option: Acquire or Manage a License Key
ISE DS Common
Install Location: /usr/14.6/ISE_DS/common
Module: ISE DS Common
EDK
Install Location: /usr/14.6/ISE_DS/EDK
Module: EDK
PlanAhead Analysis Tool
Install Location: /usr/14.6/ISE_DS/PlanAhead
Module: PlanAhead Common Files
Option: setupEnv.sh
ISE
Install Location: /usr/14.6/ISE_DS/ISE
Module: Design Environment Tools
Module: WebPACK Devices
Module: Edition Devices
Option: Ensure Linux System Generator Symlinks
Option: Install Linux System Generator Info XML
Option: Configure WebTalk
Option: Enable WebTalk to send software, IP and device usage statistics to Xilinx (Always enabled for WebPACK license)
System Generator
Install Location: /usr/14.6/ISE_DS/SysGen
Module: System Generator
Option: Version Equalizer
/usr/14.6/ISE_DS
ISE DS Common
EDK
Module: EDK
Option: setupEnv.sh
ISE
System Generator
4、注册Xilinx帐号,申请licence
      licence会自动发到注册邮箱里,下载下来,记住路径。
5、打开ISE,要先运行一个shell
$ cd ~/Xilinx_ISE_14_6/14.6/ISE_DS
$ ls
common  EDK  ISE  PlanAhead  settings32.csh  settings32.sh  SysGen
$ source settings32.sh
. /home/yunz/Xilinx_ISE_14_6/14.6/ISE_DS/common/.settings32.sh /home/yunz/Xilinx_ISE_14_6/14.6/ISE_DS/common
. /home/yunz/Xilinx_ISE_14_6/14.6/ISE_DS/EDK/.settings32.sh /home/yunz/Xilinx_ISE_14_6/14.6/ISE_DS/EDK
. /home/yunz/Xilinx_ISE_14_6/14.6/ISE_DS/PlanAhead/.settings32.sh /home/yunz/Xilinx_ISE_14_6/14.6/ISE_DS/PlanAhead
. /home/yunz/Xilinx_ISE_14_6/14.6/ISE_DS/ISE/.settings32.sh /home/yunz/Xilinx_ISE_14_6/14.6/ISE_DS/ISE
$ ise
$ ls
$ ise
(忽略出现的关于 licence 的 error。)
6、导入licence
Help >> Manage License >> Manage Xilinx License >> Load License   我安装14.2的时候,在该对话框中会显示添加该license的路径,要添加到它提示的路径中才可以,linux系统添加到usr/local中即可,提示的是添加到usr/local/flexlm,flexlm文件没找到,我直接添加到上一路径,经验证,可用。
还有一个问题,我的ISE HELP中的命令都用不了,总是达不到license添加的对话框,最后在ISE_DS\COMMON\BIN\..\xlcm 中打开了license添加的对话框。
把刚才下好的 licence 导入。
至此,ISE 安装就告一段落。
(4、5步的顺序可以随机应变,也可以先打开ISE 然后根据 license 的提示 先 获取(acq)再管理(man)导入(load))
7、可能出现的错误及其他问题
1)运行 ./setup 时可能出现以下问题:
$ cd Downloads/
$ ls
TLF-SOFT-Mathworks.Matlab.R2010a.UNIX.ISO-TBE.iso   Xilinx_ISE_DS_Lin_14.6_P.68d_3
$ ls
bin data idata labtools msg planahead_wp webpack xsetup common edk ise lib planahead sysgen xinfo
$ ./xsetup
./xsetup: 30: ./xsetup: ./bin/lin/xsetup: Permission denied
$ cd Downloads/
$ ls
$ ls
$ ./xsetup
以下是从Xilinx社区找到的
Q:
Hi all
I made all procedure mentioned by acleone, but it dosenot work.
Here is my script as mentioned in this post:
cd Xilinx_ISE_DS_Lin_12.1_M.53d.0.4/
sudo ./xsetup
sudo: ./xsetup: command not found
Then I tried:
sudo bash xsetup
xsetup: line 25: ./bin/lin/xsetup: Permission denied
And also tried:
sudo dash xsetup
xsetup: 32: ./bin/lin/xsetup: Permission denied
I am using Ubuntu 10.04 LTS on 32-bit machine.can anyone help me?
Q:
Hi all
sudo ./xsetup
Then I tried:
sudo bash xsetup
And also tried:
sudo dash xsetup
A1:Are you doing this from a section of your drive where you have write permission?
The Xilinx setup software needs to be able to write to wherever it
is being launch from. This makes for a hard time installing from the CD directly :) If that's what you were trying to do, copy the contents of the
CD/DVD to your hard drive first.
A2(他自己找到了原因和方法):
A2(他自己找到了原因和方法):
Thank you  jonathan.ross.
I've found the error finally.
I had to extract the tar file "Xilinx_ISE_DS_Lin_12.1_M.53d.0.4.tar" in the linux platform in order to keep all files properties and permissions, then
setup the ISE.
Instead, I extracted it using winrar in Windows platform and then tried to setup the ISE (but the Wimdows did not keep the files' special permissions a
nd properties used by linux systems),so I was not able to setup the ISE.
setup the ISE.
 楼主| gaochy1126 发表于 2022-5-31 21:09 | 显示全部楼层
2)如果在安装时选了 Install cable driver 会报错
#Driver installation failed. Please check the /.xinstall/install.log file for
原因如下:
ISE在很多其他版本的LINUX上的安装和运行其实是毫无问题的,唯一的问题就是下载线的驱动在有些LINUX上无法工作。继续深入研究,发现,下载线的驱动在某些linux下不工作的唯一原因是:目前,下载线的驱动依赖于一个叫windrvr的文件。 而该文件目前只有linux 内核2.4的二进制版本,因此遇到2.6内核的linux发布版,如高版本的CentOS或高版本的ubuntu, 就不工作了。
好在一个叫Michael Gernoth的德国人,大公无私地写了一个windrvr的替代版本,并且开放源码,这样,无论碰到什么版本的内核,
现场编译一个驱动并安装, 就能解决linux内核版本匹配的问题。 源代码包在这里: git.zerfleddert.de/cgi-bin/gitweb.cgi/usb-driver
解开压缩包,编译的时候,只需要make就行了,当然,第一次make八成是不过的,因为一般人都不会在ubuntu上预装usb开发包,
需要装一下,只需要这样就可以了: sudo apt-get install libusb-dev make完了以后,应该看到libusb-driver.so被生成了。
当然,编译完还需要设环境量, 命令是,export LD_PRELOAD=/你的路径/libusb-driver.so ,为简单起见,
可以把这个命令加你的.bashrc里,这样,下一次开一个终端时,就不用手工设了。 你的linux用户需要进入lp组以便有权限,
最简单的方法是编辑/etc/group, 把你的用户名加到lp组后面就可以了。 这样,在纯ubuntu上跑xilinx 的问题基本宣告解决。
Installing Cable Drivers
1、Install the prerequisite
On 32-bit
$ sudo apt-get install gitk git-gui libusb-dev build-essential libc6-dev fxload
On 64-bit
$ sudo apt-get install gitk git-gui libusb-dev build-essential libc6-dev-i386 fxload
On 32-bit
On 64-bit
2、Download the driver source and install
$ sudo sudo git clone git://git.zerfleddert.de/usb-driver
Cloning into 'usb-driver'...
$ cd cd usb-driver/
$ sudo make
$ cd cd usb-driver/
$ sudo make
(未完待续)
参考:                  终于搞定ISE在虚拟机Virtualbox上ubuntu的下载线XILINX Platform Cable USB II的驱动
                             Linux操作系统下三种配置环境变量的方法
                             linux-fpga系列文章之——如何在ubuntu下安装FPGA usb cable的驱动
                             Xilinx ISE WebPack 12.2 on Ubuntu 10.04 LTS
                             Ubuntu下运行XILINX ISE
                             ubuntu上安装xilinx 14.1及注意事项
                             Ubuntu 12 下面安装Xilinx ISE 14.1
                             在Ubuntu 11.04 上安装Xilinx ISE 13.1指南,附出错的改正方法
                             Ubuntu 12.04下给xilinx ISE 12.04加了个launcher
                             Ubuntu上跑XILINX的ISE/EDK以及petalinux的总结
                             Install Xilinx ISE on the Ubuntu
个人签名:这个社会混好的两种人:一是有权有势,二是没脸没皮的。
1235
