[无线通信] DR-AP-6018-S-A/QCN9074 Wi2x2 2.4G&5G
2152|0
 楼主| wallysJane 发表于 2022-6-1 16:10 | 显示全部楼层 |阅读模式
<span]
Description
DR-AP6018-S-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x  DR6018(IPQ6010) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);
1 x Enclosure.
Dipole antenna
■  2 x 2.4G&5G Antenna
■  5dBi 2.4GHz/5Ghz
■ SMA Plug interface
■ Plastic rod of black
■ RoHS compliance
Enclosure
■  Dimension: 133x 128 x 44 mm
■  Aluminum alloy material
■ Two Version:
DR-AP6018-S-AB (color black)
DR-AP6018-S-AO (color orange)
■  Support Wally DR6018-S
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48V(DC Jack)
    V
    Operating Temperature Range
    -40 to +70
    ºC
    Storage Temperature Range
    -45 to +105
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm-Atheros IPQ6010
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
    SD Card Slot
    1x SD Card Slot(Option)
    USB /header
    1x USB 3.0 Port(Option)
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V~48V power supply
    LED header
    2.0 pitch pin header
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    Nor Flash
    8MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension
    133mm x 128mm x 44mm
https://www.wallystech.com/Industrial_Wireless_AP/DR-AP6018-S-A-wifi6-Access-Point-Qualcomm-IPQ6010-2T2R-supporting-QCN9074-wifi-card-aluminum-body.html
Wallys Communications (Suzhou ) Co., LTD(http://www.wallystech.com) is a professional supplier of wireless communication products and has a complete industrial chain in China. Our biggest advantage is our independent research and development ability, which can support you in the later period.
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344/AR9531
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:​ sales1@wallystech.com
